16f687 - Where is the data stored?
Results 1 to 17 of 17
    Default Re: 16f687 - Where is the data stored?
    Written to SRAM as a variable.
    From the manual.
    Space for each variable is automatically allocated in the microcontroller=s RAM by PBP.
    Variable arrays can be created in a similar manner to variables.
    Jan 2012
    Grid EN19MV
    That's what I was afraid of..........guess there's an I2C EEPROM in my future!
    Dec 2010
    Quote Originally Posted by andywpg View Post
    I'm curious how that might help. But if it does, would the onboard EEPROM (256 bytes) not be sufficient?
    Jan 2012
    Grid EN19MV
    Quote Originally Posted by Charlie View Post
    I have a BUNCH of 16 character messages (25+) that are to be displayed on an LCD. A master sends a command to a receiver (via RF) to light certain LED's, beep a piezo, and display various messages on the two lines of the LCD.
    My idea was to have the master send just a code indicating what message each line should display in the receiver, and have the receiver unit read the associated messages from the EEPROM and display it. Since that would involve having another part in each receiver (possibly 40 or more of them), I have since decided that the master will transmit the two lines of the message, so I will only have to use an external EEPROM in the master.
    Hopefully, my rambling explains the situation sufficiently...
    Andy
    May 2007
    Why not store the messages as constant strings in program (FLASH) memory?
    Jan 2012
    Grid EN19MV
    I had sorta thought about that..........but I've always wondered how you tell what memory is not going to be used for the program. I always make the code non-relocatable when asked, but how do you..........
    Wait a minute, do you just read the chip and look at the hex dump to see what spots are left blank after the program is in it? Is it that simple? Then you just pick an area that isn't being used? Am I on the right track?
    That's a great idea! It would certainly lower the serial data overhead - from 39 bytes per transmission to 11. I know, not a lot of data either way, but less chance of errors when the receiver is in a race car!
    Lets say the number of message to be displayed comes in and gets stored in a variable called message.
    Select Case Message
       Case 1
          LCDOUT $FE, 1, "This is message 1"
       Case 2
          LCDOUT $FE, 1, "This is message 2"
       Case 3
          LCDOUT $FE, 1, "This is message 3"
       Case Else
          LCDOUT $FE, 1, "Unknown message"
       End Select
    Here the strings are stored in program flash (where else should it go?) and written to the LCD when the LCDOUT statement executes. It's not the most efficient way of doing it but it's probably the easiest. If the messages are partly "the same" (like in the above example) you can have subroutines to print just that part which you then GOSUB from within the Case section, that will save on flash since you don't have to store the same string ("This is message") more than one time
    Case 1
       GOSUB FirstPart
       LCDOUT $Fe, 1, "1"
    End Select
    FirstPart:
       LCDOUT $FE, 1, "This is message "
