MASM error 202 argument out of range
Results 1 to 9 of 9
    Default Re: MASM error 202 argument out of range
    If I were you I would look at the .lst file for the compiled program and find the instance "argument out of range". This will tell you what variable is the incorrect size you are trying to pass. Yes it could make for some unintended operation....
    EN82fn
    Trying to pass. Yes it could make for some unintended operation....
    Trying to pass?
    I don't have any assembler routines in my basic code.
    The error seems to relate to this code.
     HChkSum = $E4 + $06 + $02 + ImaMem + RL        'Calculate Read Chksum
    HChkSum = $100 - HChkSum                    'Calculate two's complement
    HChkSum is a byte variable and I assume must be overflowing as the additions take place or when we try to subtract 100H from it.
    Miami, Florida USA
    Try using decimal 255 in your formula instead of $100. The hex number $100 is equal to decimal 0001 0000 000. This might be a problem with your byte variable.
    Anonymous
    Miami, Florida USA
    I meant $100 equal to decimal 0001 0000 0000. Missed a zero.
    Anonymous
    100H = 256 though not 255 so won't that give the wrong checksum?
    It's two's complement asfaik. Not that means a great deal to me anyway Doh!
    Here is an example checksum with correct result. $04,$06,$04,$FF,$00,($F3 = CS)
    Miami, Florida USA
    Oh, I see what you mean. Anyways, I'm almost sure (I haven't tested it though) that combining your 9 bit number ($100) with your byte variable is what is causing the overflow problem. You might need to find a workaround.
    Good luck.
    Anonymous
