I think the delay is computed at compile time, and it would probably not be too easy to modify. However, you could simply 'lift' one of the many ASM bit-bang RS-232 routines that exist all over the net and just 'drop it in' with ASM...ENDASM. The routines are generally smaller than 256 bytes, so they should not break PBP's limit. You can define the local (to the ASM routine) vars normally, but the ones that you transfer to/from PBP should be declared as BANKA SYSTEM.
