Fixed voltage regulator to take input voltage between 40-60V
Results 1 to 8 of 8
    Nov 2009
    London
    Default Fixed voltage regulator to take input voltage between 40-60V
    Can anyone please advise any widely available fixed voltage regulator to take input voltage between 40-60V and output 24V or 12V? Thanks
    Aug 2008
    Portugal
    Default Re: Fixed voltage regulator to take input voltage between 40-60V
    Quote Originally Posted by Megahertz View Post
    Hi;
    The Input/Output Voltage Differential of the LM338 is about 40V, so see if it will be able to work in your project.
    Thanks and Regards;
    Gadelhas
    Nov 2009
    London
    What is the MAX Input Voltage in this regulator? I am sorry, I am not so good in reading and understanding datasheets
    Aug 2008
    Portugal
    From the datasheet;
    "Since the regulator is “floating” and sees only the input-to-output differential voltage, supplies of several hundred volts can be regulated as long as the maximum input to output differential is not exceeded,"
    Thanks and Regards;
    Gadelhas
    Jan 2006
    Istanbul
    Lm2576hv-12 : 0.5a ≤ iload ≤ 3a : 15v ≤ vin ≤ 60v
    lm2576hv-15 : 0.5a ≤ iload ≤ 3a : 18v ≤ vin ≤ 60v
    lm2576hv-adj : 0.5a ≤ iload ≤ 3a : 4v ≤ vin ≤ 60v
    Sep 2005
    Campbell, CA
    You can always pre-regulate. Just use an NPN transistor that has a Vce that is 150% of your input voltage, and put two resistors across the device. One from GND to Base, the other from Collector to Base. Choose resistors that give a current flow of about 5% of the output current. Connect the Emitter to the input of your regulator. Put a small capacitor (1uF) on the input of the regulator to GND.
    If you choose your resistors properly, you can drop as much or as little voltage across the transistor as you wish. Now you can use a 20V max regulator, if that is what you have.
    The transistor and resistors will, of course dissiplate some power and should be sized accordingly.
    Charles Linquist
