The best editor ?
Results 1 to 12 of 12
    May 2008
    Italy
    Default Re: The best editor ?
    Norm, you will get my vote too, but before you must tell me how do you select a device in your nice editor?
    Do you have a "USER MANUAL" ?
    Cheers
    Al.
    Quote Originally Posted by aratti View Post
    Cheers
    Al.
    Add:
    'XFL_PIC18F2550X' (replace the X's with a a less than and a greater than)
    with correct PIC to code or
    select from the "select a device" drop down box which appears when PicBasicPro is selected in options.
    No users manual at this time.
    Norm
        'Selects the Chip
        '<FL_PIC18F2550>'
        'Selects PBPL
        '<FL_PBPL>'
    Sep 2005
    Campbell, CA
    I go back and forth between MCS and FineLine. FineLine is fantastic when you have huge IF THEN ELSE structures..
    Charles Linquist
    Jul 2011
    This is the first I've heard of FineLine. I just gave it a try, and see that it's having trouble with these:
    @ __CONFIG _CONFIG1H, _OSC_ECIO6_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    @ __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOREN_ON_2L & _BORV_1_2L
    @ __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    @ __CONFIG _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    @ __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
    How do you deal with these? Must the .INC fine be modified instead?
    Is there documentation available for FineLine?
    Jul 2011
    Thumbs up Re: The best editor ?
    Oops. It works fine. Just a syntax error on my part.
    Jul 2011
    If you've got multiple files open, how do you CLOSE individual files??????
    The round red button with an X in it on the right hand side of the tab bar works for me.
