Led limiting resistor
Results 1 to 25 of 25
    Jun 2011
    Default Re: Led limiting resistor
    r2 is to turn on the opto.
    all i need is to sense if the heater is burned out when the switch is closed.
    I do nt measure current
    thanks
    Miami, Florida USA
    Quote Originally Posted by igeorge View Post
    thanks
    What about using a relay to detect if the heater is burned out?
    Anonymous
    Mar 2009
    Hello,
    I have a line where the current varies from 1 to 5 amps.
    I would like to insert a resistor which will turn on an optocoupler rated at 1.5 volts , 10 mA
    The issue here is that at 5 amps i need a 0.24ohms resistor , and at 1 amp i need a 1.2 ohm resistor.
    Assuming that i use the 1.2 ohms resistor, at 5 amps will generate 6 volts and fry my opto.
    I need help to solve this issue, which i do not know how to do it
    Ion
    iF you place a 450R resistor in series with the opto, that'll ensure the voltage doesn't exceed 1.5V/10mA at the opto for 5A through the element ....of course the opto will only then 'get' 300mV if the element current drops to 1A....but without knowing more about the opto blah blah
    Why not using a Current transformer?
    Jun 2011
    I think Mister_e solution it is something which i will consider, but i have to solve the conversion of 10 mv ac/60 hz to a decent DC voltage so i can use it with a comparator.
    As i said, analog it is a mystery for me.
    Ion
    I don't understand why the need for complicated design.
    Wouldn't an appropriately rated relay do the job just as well (isolate both sides), be easy to install and be able to withstand a lot more?
    Jun 2011
    I believe that the relay first will not withstand the 5 amps on the coil.
    The second issue is that voltage is chopped by the SSR and heat controller, and the relay will come to a point when it will go crazy ON-OFF-ON , and the signal to CPU will be a pulsating one.
    Thank you
