12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Aug 2010
    Maryland, USA
    Default Re: 12f675_fuse_about_to_blow!
    Without the define, PBP will sprinkle CLTWDT through out your code. The Config tells uP not to use it, the DEFINE tells PBP not to.
    -Bert
    Without the define, PBP will sprinkle CLTWDT through out your code. ...
    I cannot Find CLTWDT in the ASM file of my latest project?
    So I went through older larger programs in code size was an issue. None of the ASM has CLTWDT either.
    Feb 2010
    I live in the UK
    Just had a breakthrough with the project
    Having modified Bruce's code to make the timing loop run & transmit. Tx 'consistancy' was a problem. The data was only recieved about 3 in 5 times. So reading the Manual, I added PACE to the program with a 5ms delay, result the data now gets Tx'd & Rx'd everytime with the delay loop.....Whoopee....!
    SEROUT2 D_OUT,BAUD,PACE,[PreAmble,Synch,DAT_OUT,DAT_OUT,CHK_SUM,VISITS.highbyte,VISITS.lowbyte]
    Mega_Chuffed tonight.
    COOL
    Can you post the complete code as is? Just to keep everything/everyone UpToDate...
    Quote Originally Posted by LEDave View Post
    Good news!
    About the checksum:
    I always thought the idea behind checksum was to confirm that a data transfer had completed successfully. As it stands, you are checking data from the front of the stream only. I would put the CHKSUM at the end of your data stream, that way you are certain you have received everything.
    It might not be necessary with the way PBP processes Serout commands, but this is from old programming habits in a business environment (you want to be sure everything made it through).
    SEROUT2 D_OUT,BAUD,PACE,[PreAmble,Synch,DAT_OUT,DAT_OUT,VISITS.highbyte,VISITS.lowbyte,CHK_SUM]
    (unless the location of CHKSUM in SEROUT is pre-determined by hardware/software)
    How did you control the Pace delay?
    I'm looking at Serout2 in PBP manual v2.60 (p.155) and only see reference of adding Pace, possibility of 1 to 65,535 ms delay, but no way of controlling delay.
    I assume Pace is a word variable that you assigned a value of 5?
    Feb 2010
    I live in the UK
    Will do mackrackit.
    Hi Demon. I hear what you're saying, makes good sense. I remember Henrik telling me that it didn't matter whether you sent Highbyte or Lowbyte first, your way kind of gives a check / checksum
    I used:
    PACE     CON 5
    Feb 2010
    I live in the UK
    Hi mackrackit.
    Here's the Tx and Rx code as is stands. The Tx program now transmits a data WORD on button press, not just the button press itself.
    Tx:
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
        DEFINE OSCCAL_1K 1
        DEFINE NO_CLRWDT 1
        SYMBOL D_OUT = GPIO.2 ' RF serial data output
        SYMBOL E_OUT = GPIO.5 ' RF transmitter enable output
        VISITS   VAR word   ' Holds total daily bird visits
        DAT_OUT  VAR BYTE   ' Holds 8-bit data byte
        DAT_OUT2 VAR BYTE   ' Holds 8-bit test byte
        LOOPS    VAR BYTE   ' Loop var
        CHK_SUM  VAR BYTE   ' Holds calculated checksum of outbound data
        I        VAR word   ' Delay loop count
        BAUD     VAR WORD   ' Holds baud rate
        ' Constants
        PreAmble CON $A5    ' 10100101 preamble
        Synch    CON "~"    ' 01111110 synch byte
        N4800    CON 188    ' 4800 bps
        N2400    CON 16780  ' 2400 bps
        GUARD    CON 5      ' 5mS guard time pause
        PACE     CON 5      ' Set CHAR transmission speed
        ' hardware init
        GPIO = 0            ' Everything off on boot
        ' GPIO.2=data out, GPIO.5=RF enable, GPIO.3,4 = Bird_visit_count / It's dark..maybe
        TRISIO = %00011011  '
        ANSEL = 0           ' Disable A/D
        INTCON = %00001000   ' Enable port change wakeup from sleep
        WPU = %00010000     ' pull-up on for GPIO.4 (external pull-up already on GPIO.3)
        IOC = %00011000     ' Wakeup on change enabled for GPIO.3,4
        VRCON = 0           ' Disable internal Vref
        CMCON = 7           ' Disable comparators
        OPTION_REG = 0      ' Pull-ups on
        D_OUT = 0           ' Idles low for inverted serial output
        E_OUT = 0           ' Enable for RF transmitter=0 (transmiter off)
        BAUD = N2400        ' Set baud rate here
        ' Read port to clear missmatch, if with no buttons pressed, then
        ' clear int-on-change flag & snooze until wake up on change. This
        ' conserves battery power on the demo board with 3V coin cell.
      IF GPIO.3= 1 AND GPIO.4= 1 THEN ' Nothing has happened so SLEEP
           E_OUT=0       ' Disable transmitter
           INTCON.0 = 0  ' No Inputs detected or it's still light so clear int on change flag
           @ SLEEP       ' and start snoozin..zzzzzzzzzzz indefinatly
           @ NOP
        ' E_OUT=1        ' Mackrackit, I moved this to (after delay loop)this to save power as I need a long
        'PAUSEUS 25      ' Delay loop 30mins so saves Transmitter power
    Delay:
         FOR I = 1 TO 2  ' Delay loop 2sec test
         PAUSe 1000
         NEXT I
         IF GPIO.3=1 and GPIO.4=1 THEN 'Button pressed then released..carry on
    Encode:
        E_OUT=1        ' Enable transmitter (+ lights RFEN LED on demo board)
        PAUSEUS 25     ' Allow RF stage to stabilize
        DAT_OUT = %10101001
        INTCON.0 = 0  ' Clear int on change flag
        'Build checksum of 2 data bytes
        CHK_SUM = (DAT_OUT * 2)
    Transmit:
        'LET VISITS = VISITS / 2  'Just VISITS too not from the box
        LET VISITS = 300 'Test data number (Bird visits)
        PAUSE GUARD ' 5mS guard time gives decoder time to respond,calculate,change,etc.
        GOTO Main
    When the 'Test Data' number arrives at the Rx the code flashes an led three times if DATA is TRUE.
    Rx:
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _PWRTE_ON
        DEFINE NO_CLRWDT 1      ' Watchdog timer is disabled, so we don't need to reset it
        SYMBOL  D_IN = PORTC.1  ' data input pin
        ' Working variables
        MATCH     VAR BYTE  ' Match variable
        DAT_OUTB  VAR BYTE  ' Holds decoded data for output
        DAT_IN1   VAR BYTE  ' 1st Data byte
        DAT_IN2   VAR BYTE  ' 2nd Data byte for verify
        CHK_SUM   VAR BYTE  ' Holds checksum received
        CheckSum  VAR BYTE  ' Computed checksum of all bytes received
        VISITS    var word  ' Test BYTE with a value of 300
        X         VAR BYTE  ' Loop counter value Byte
        ' Constants
        N2400    CON 16780  ' 2400 bps inverted
        N4800    CON 188    ' 4800 bps inverted
         ' hardware init
        PORTA = 0
        TRISA = %00111001   ' RA1 and RA2 are LED outputs
        PORTC = 0           ' Clear outputs on power-up
        TRISC = %00101110   ' RC1 = RF input
        IOC = 0             ' Interrupt on change disabled
        VRCON = 0           ' Comparator Vref disabled
        CMCON0 = 7           ' Disable comparators
        ANSEL = 0           ' disable A/D
        OPTION_REG = 128    ' Pull-ups off
        INTCON = 0
        MATCH  = 0           ' Clear match count
    MAIN:
        ' Wait for Synch byte, then get new inbound data & checksum
        SERIN2 D_IN,N2400,[WAIT(Synch),DAT_IN1,DAT_IN2,CHK_SUM,VISITS.HIGHBYTE,VISITS.LOWBYTE]
        ' / **** Begin data validation **** /
        ' Calculate checksum by adding 2 data bytes together
       CheckSum = DAT_IN1 + DAT_IN2
        ' Test new checksum against one received in CHK_SUM
        IF CheckSum != CHK_SUM THEN MAIN ' Failed checksum, return
        ' Test data bytes for match
        IF (DAT_IN1) != (DAT_IN2) THEN MAIN ' Failed data comparison, return
        MATCH = MATCH + 1        ' We have a match so increment match count
        IF MATCH = 1 THEN DECODE ' Everything matched twice, we're good
        GOTO Main                ' Else do it all over
        ' Everything looking good - so place new data on outputs
    DECODE:
        PORTA = DAT_IN1 & DAT_IN2
        DAT_IN1 = !DAT_IN2  ' Destroy the match
        MATCH = 0
        IF VISITS = 300 THEN  LED
        GOTO MAIN
    lED:
        for X = 1 to 3  'Blink led 3 times to show data has arrived (correctly)
        HIGH PORTA.1
        PAUSE 500
        LOW PORTA.1
        next X
        GOTO MAIN
    Still much to do / change but a good day today. I've sent the Tx / Rx into a continual 'Test' loop
    hasn't missed a beat so far, really pleased.
    As always thanks for everyone's help, input.
    Feb 2010
    I live in the UK
    Really pleased to say the project took a giant leap forward tonight. Have re-written some of the code to work with pull-down resistor now 0v = off, 5v = on.
    Tap a wire +5v to GPIO.0 ten times, then touch GPIO.1 once and the Tx Tx's and the Rx board flashes 5 times (simulates five visits to bird box).
    Still plenty to do I'm sure but feeling a little like Marconi this evening.
