help please...!
Results 1 to 13 of 13
Thread: help please...!
    Default Re: help please...!
    Can you find a P16F877a.inc file here: C:\Program Files\Microchip\MPASM Suite
    And under MCS compile and program options is your mpasm path pointed to it?
    Feb 2011
    there is no that include file in MPSAM suite
    m not sure if i understand that,but in compile and program option in MCS at assembler category,use MPASAM is checked although the path is pointed to
    C:\Program Files\labcenter electronic\proteus
    what should i do?
    That's why you are getting the symbol not found errors. It needs to find the file. Sounds like you need to try re-installing mplab ide. And then either manually set the path, or have MCS find it.
    Quote Originally Posted by bwaxing View Post
    Feb 2011
    thank you,now it is well working after re-installing MPLAB
