Multiple Combinations
Results 1 to 3 of 3
    Apr 2011
    Default Multiple Combinations
    I'm making a yahtzee game and trying to determine when someone has a three-of-a-kind, four-of-a-kind, full house, small straight, large straight, and yahtzee. The yahtzee part is easy since all five of the numbers are the same, but the others aren't so easy. Is there a better way to determine when I have three-of-a-kind than using a ton of IF THENS to check all possible ways of getting three of the same numbers?
    Default Re: Multiple Combinations
    Dice VAR BYTE[5]    'Array of 5 bytes, one for each dice.
    Results VAR BYTE[6]  'Array of six bytes containing the number of ones, twos, threes etc
    i VAR BYTE
    For i = 0 to 5
      Results[i] = 0   'Clear counters
    Next
    For i = 0 to 4     'Itterate thru the five dices
      Select Case Dice[i]
        Case 1
          Results[0] = Results[0] + 1   'Ones
        Case 2
          Results[1] = Results[1] + 1   'Twos
        Case 3
          Results[2] = Results[2] + 1   'Threes
        Case 4
          Results[3] = Results[3] + 1   'Fours
        Case 5
          Results[4] = Results[4] + 1   'Fives
        Case 6
          Results[5] = Results[5] + 1   'Sixes
      End Select
    NEXT
    Now you know how MANY of each you've got, perhaps that's a start?
    Apr 2011
    i VAR BYTE
    For i = 0 to 5
    Next
      Select Case Dice[i]
        Case 1
        Case 2
        Case 3
        Case 4
        Case 5
        Case 6
      End Select
    NEXT
    This actually worked out really well, I got it checking for each one. Thanks for your help!
