ADC reading and configuration problem
Results 1 to 5 of 5
    Default Re: ADC reading and configuration problem
    Hello,
    I had the same problem a while back. The adcin command does not work with the
    pic18fxx31s. You have to read them manually. See this thread it may help.
    http://www.picbasic.co.uk/forum/show...ght=PIC18F2331
    Quote Originally Posted by mark_s View Post
    Hello,
    I've tried this (from Bruce's code) :
    DEFINE OSC 32
    DEFINE LCD_DREG PORTC
    DEFINE LCD_EREG PORTD
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_EBIT 0
    DEFINE LCD_RSBIT 1
    DEFINE ADC_BITS 10
      CH1 VAR WORD
        CH2 VAR WORD
        CH3 VAR WORD
        CH4 VAR WORD
        ' Analog setup
        ' Single shot, multi-channel, simultaneous Mode2, Groups A+B, then C+D
        ADCON0 = %00011101
        ' Set +/- Vref to AVdd/AVss, FIFO buffer enabled
        ADCON1 = %00010000
        ADCON2 = %11001111   ' Right justified, 24 Tad, Frc
        ADCON3 = 0           ' Disable all triggers
        ADCHS = 0            ' Channel select for AN0,1,2,3
        ANSEL0 = %00001111   ' AN0,1,2,3 analog input, rest digital
        ADCON0.1 = 1         ' Start the conversion
        WHILE ADCON0.1=1     ' Wait for it to complete (all 4 channels)
        wend
        ' FIFO buffer holds all 4 channels. Reading ADRESH & ADRESL automatically
        ' increments the buffer pointer (on read of ADRESL) to the next channels
        ' storage location.
        CH1.HighByte = ADRESH ' get result from AN0
        CH1.LowByte = ADRESL  ' Increment buffer pointer
        CH2.HighByte = ADRESH ' get result from AN1
        CH2.LowByte = ADRESL  ' Increment buffer pointer
        CH3.HighByte = ADRESH ' get result fron AN2
        CH3.LowByte = ADRESL  ' Increment buffer pointer
        CH4.HighByte = ADRESH ' get result from AN3
        CH4.LowByte = ADRESL  ' clears buffer pointer
        ' show 4 A/D channel results
        lcdout $fe,$2,DEC5 CH1," ",dec5 CH2
        lcdout $fe,$c0,DEC5 CH3," ",dec5 CH4
        GOTO Main
    The readings works, but the lower bits of the reading are unstable, and I don't know why.
    What is the source of the analog? Do you have smoothing capacitors from the ADC pins to VSS? Sometimes that helps.
    In fact I've resolved my problem. The result of the ADC was configured to be right-justified (ADCON2.7=1), I've set it to be left-justified (ADCON2.7=0), and I haven't problems anymore (the readings are perfectly stable now).
