High voltage transistor
Results 1 to 7 of 7
    Default Re: High voltage transistor
    Thanks Ron, although the project was canelled. It is been two years now...
    It was a switching controller for high voltage low current load.
    Loveland CO USA
    That does not tell me much.
    High voltage transistors (NPN) are slow!! An 800 Volt transistor is faster than a 1000V part. The 1500 volt parts I used are dog slow.
    My experiance is from switching power supplies, solar/wind, CRT monitors and TV sets. A 1500 volt transistor will not run at 200khz. Maybe not at 100khz. Your AC loss will be huge! Not knowing what you are doing....you may need a 1500 V. diode that may burn 5 watts alone.
    Most high voltage junction transistors were made for CRT monitors. They are not in production! I used a high voltage J-FET that I liked. (Silicon Carbide) I can't get the part number from my head.
    It doesn't matter anymore Ron.
    The project is cancelled over 1 and a half year now.
    I do not know what exactly my customer would do, but asked me to make a 200KHz, 1,5KV switch for as much as 100mA.
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. high voltage high frequency H-Bridge
    By George in forum Off Topic
    Last Post: - 27th April 2009, 12:50
  3. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  5. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
