Well, that definately looks better, and it may work better for now, but it still needs a couple things.
The Interrupt "Handler" should be enclosed within DISABLE/ENABLE statements to keep the Interrupt Handler itself from being interrupted again.
The clearing of the Flag should be done in the handler, not the point that execution resumes. If you RESUME without clearing the flag first, you can end up right back in the Handler again.
And, "resume BASE" should only be "RESUME".
When specifying a location to RESUME to, it essentially does a GOSUB to that routine when the Handler is finished. However, in this program, the PIC is told to go to Sleep, without ever returning from that GOSUB. So on each interrupt, it pushes another address on the stack, which overflows after 8 interrupts. For a 16F, the Stack will wrap around to the beginning again without causing a reset, so you may never see the problem right now, but if there are any other subroutines involved, they will never get a chance to RETURN, or will return to the wrong place.
Because of the "Spaghetti" nature of this program, these problems may not be evident because it just falls back into the program and continues on, but when you start adding things later, you will lose a large portion of whatever hair you may have left trying to figure it out.
I think i'll go deeper in the .LIB when i'll be back in Canada.
