Sorry arch, I edited it to simplify it and may have messed that up. Let me check it and I'll post again.
I fixed it and it still does the same thing. In addition, it seems that if I even get close to it sometimes it goes off. Is there a pin I should ground or have I really screwed something up?
I tossed the code into MicroCode Studio to get a better look - think I see the problem...
No matter which pin is interrupted, the code jumps back to "Iloop", which is in the middle of the "IF NEWPORTA.5 <> OLDPORTA.5 THEN" test. It loops there until done, blinking the LED as if A.5 were interrupted, no matter which pin actually caused it.Code:IF NEWPORTA.5 <> OLDPORTA.5 THEN ILOOP: I = I + 1 IF I = 5 THEN resume BASE ENDIF LOW LED : PAUSE 1000 : HIGH LED PAUSE 1000 GOTO ILOOP ENDIF IF NEWPORTA.4 <> OLDPORTA.4 THEN I = I + 1 IF I = 4 THEN resume BASE ENDIF LOW LED : PAUSE 1000 : HIGH LED PAUSE 1000 GOTO ILOOP ; <<<<<<<<<< JUMPS BACK TO Iloop ENDIF
Arch
PS - on the erratic triggering, make sure your programmer is actually setting MCLR off, and check for 'floating' inputs.
What value pullup/pulldowns are you using?
I wasn't using anything but internals on this Arch. I'll check out what you posted and give it a whirl. Thanks for the help. I think my brain began to die after I passed 50.
Had a few extra minutes and rewrote the code - I think it should work - I don't have any 16F676's to try it on.
(yer way ahead of me... my brain died off around 5 or so)...
Code:@ DEVICE PIC16F676,INTRC_OSC_NOCLKOUT,WDT_ON,PWRT_OFF,BOD_OFF,PROTECT_OFF,CPD_OFF,MCLR_OFF LED var PORTA.0 BlinkCount var byte CounterA var byte OLDPORTA VAR byte NEWPORTA VAR byte ; DISABLE ANALOG INPUT, COMPARATOR ON PORTA, A/D reference... ANSEL = 0 : CMCON = 7 : VRCON = 0 TRISA = %00111110 ; PortA In/Out states WPUA = %00000110 INTCON = %10000000 : IOCA = %00111000 : OPTION_REG = %00001000 LED = 0 : PAUSE 1000 : LED = 1 GOTO BASE ; ; SUBROUTINES MYINT: NEWPORTA = PORTA ; read current PortA state INTCON = %10000000 ; IF NEWPORTA.5 <> OLDPORTA.5 THEN BlinkCount = 3 ; Set up for 4 blinks ENDIF ; IF NEWPORTA.4 <> OLDPORTA.4 THEN BlinkCount = 2 ; Set up for 3 blinks ENDIF ; IF NEWPORTA.3 <> OLDPORTA.3 THEN BlinkCount = 1 ; Set up for 2 blinks ENDIF ; for CounterA = 0 to BlinkCount LED = 0 : PAUSE 1000 : LED = 1 : PAUSE 1000 next CounterA RESUME Base ; The above section could have an error trap in case none of the IF's are true for some reason. ; A "Select Case" might use less code space. ; ; Start main program loop here ; BASE: BlinkCount=0 : OLDPORTA = PORTA ; ON INTERRUPT GOTO MYINT INTCON = %10001000 ; LOOP: SLEEP 240 : GOTO LOOP end
Arch
Arch, once again I'd like to thank you. That was it. At one time programing was one of my strong points, but it seems I get lost pretty easy these days. Thanks for helping me out again.
Well, that definately looks better, and it may work better for now, but it still needs a couple things.
The Interrupt "Handler" should be enclosed within DISABLE/ENABLE statements to keep the Interrupt Handler itself from being interrupted again.
The clearing of the Flag should be done in the handler, not the point that execution resumes. If you RESUME without clearing the flag first, you can end up right back in the Handler again.
And, "resume BASE" should only be "RESUME".
When specifying a location to RESUME to, it essentially does a GOSUB to that routine when the Handler is finished. However, in this program, the PIC is told to go to Sleep, without ever returning from that GOSUB. So on each interrupt, it pushes another address on the stack, which overflows after 8 interrupts. For a 16F, the Stack will wrap around to the beginning again without causing a reset, so you may never see the problem right now, but if there are any other subroutines involved, they will never get a chance to RETURN, or will return to the wrong place.
Because of the "Spaghetti" nature of this program, these problems may not be evident because it just falls back into the program and continues on, but when you start adding things later, you will lose a large portion of whatever hair you may have left trying to figure it out.
