Hello all,
Still learning all there is to know about microcontrollers...
I assume that it is good practice to use a WDT in Picbasic programs, ie to reset the PIC if things go pear shaped.
I'm using a PIC 16F628, and IC-Prog 1.05C to set the Code protect registers.
Few questions,
1. Generally , how often should the WDT be cleared in the program?
2. Is the Pause instruction effected by the WDT?
3. Is it possible that a PIC can get caught up in a WDT loop that causes it to stop executing code?
I have written a simple program to test the WDT and it is hard to tell if it is working properly... maybe answers to the above will help...
Cheers
