Keypad unlock (as in garage door possibly)
Results 1 to 6 of 6
    Mar 2006
    Default Keypad unlock (as in garage door possibly)
    '* Name : garage door unlock *
    '* Author : Fred *
    '* Date : 07/12/2006 *
    '* Version : 1.A.5 *
    '* Notes : this code will unlock after the correct code *
    '* : sequence. It will remember the code even if *
    '* : power goes out by writing the unlock code to *
    '* : EEPROM. It uses the standard 12 key - keypad *
    '* : but can be easily modified to use any keypad. *
    '* : There are a lot of LCD commands I used to *
    '* : debug but they can be take out easily. If *
    '* : someone improves this GREAT!! That's the idea *
    '* : You enter the correct code then press * to *
    '* : to unlock. # resets the sequence. You program *
    '* : by grounding the PortA.2 pin then enter code *
    '* : followed by * then unground pin. It makes a *
    '* : relay for 1/2 second which connects to door *
    '* : switch to open or close garage door when you *
    '* : correct code number *
    'Pin 1 RA2 - Switch to progam code
    'Pin 2 RA3 - Relay 1 output
    'Pin 3 RA4 - Relay 2 output
    'Pin 4 RA5/MCLR - Hard reset switch
    'Pin 5 VSS - Grd
    'Pin 6 RB0 - Row 1
    'Pin 7 RB1 - Row 2
    'Pin 8 RB2 - Row 3
    'Pin 9 RB3 - Row 4
    'Pin 10 RB4 - Col 1
    'Pin 11 RB5 - Col 2
    'Pin 12 RB6 - Col 3
    'Pin 13 RB7 - LED output
    'Pin 14 VDD - +5
    'Pin 15 RA6 - Clock in
    'Pin 16 RA7 - Clock
    'Pin 17 RA0 - Serial data out
    'Pin 18 RA1 - output to spkr connection
    INCLUDE "modedefs.bas"
    DEFINE OSC 20
    Col VAR BYTE ' Keypad column
    Row VAR BYTE ' Keypad row
    Key VAR BYTE ' Key value
    SerPin VAR PortA.0 ' Serial output pin
    KeyCode var byte
    LED VAr PortB.7
    Relay1 var PortA.3
    Relay2 var PortA.4
    CMCON = 7 ' PortA = digital I/O
    VRCON = 0 ' Voltage reference disabled
    OPTION_REG.7 = 0 ' Enable PORTB pull-ups
    SetCode VAR BYTE
    OldCode VAR BYTE[11]
    NewCode VAR BYTE[10]
    LoopCount VAR BYTE
    NumDig VAR BYTE
    Unlock VAR BYTE
    ProgramSwitch var PortA.2
    input programswitch
    Setcode = 1
    unlock = 1
    Read 100,numdig 'Read number of digits of unlock code from memory
    For loopcount = 1 to numdig ' Read unlock code from memory
    Read loopcount,oldcode[loopcount]
    Next loopcount
    Loop:
    GOSUB getkey 'Get key from keypad
    key = key - 1
    LookUp key,["123456789*0#"],keycode ' Lookup table to decode key press
    Newcode[setcode] = keycode
    IF programswitch = 1 Then ' If this port high then program unlock code
    high led
    serout serpin,N9600,[254,1] 'keycode is the number
    serout serpin,N9600,[254,128]
    SEROUT serpin,N9600,["location is "]'Send key value out
    serout serpin,N9600,[#setcode]
    serout serpin,N9600,[254,192]
    SEROUT serpin,N9600,["key is "]'Send key value out
    serout serpin,N9600,[keycode]
    IF keycode = "*" Then ' If key is a star end the program code
    numdig = (setcode - 1)
    SEROUT serpin,N9600,["numdig is "]'Send key value out
    serout serpin,N9600,[#numdig]
    pause 3000
    Write 100,(numdig) 'setcode is number of digits of unlock number
    for loopcount = 1 to Numdig
    write loopcount,newcode[loopcount]
    SEROUT serpin,N9600,[254,128] 'Send key value out
    serout serpin,N9600,["loopcount is "]
    SEROUT serpin,N9600,[#loopcount]'Send key value out
    SEROUT serpin,N9600,[254,192] 'Send key value out
    serout serpin,N9600,["new "]
    SEROUT serpin,N9600,[(newcode[loopcount])]'Send key value out
    oldcode[loopcount] = newcode[loopcount]
    serout serpin,N9600,["-old "]
    serout serpin,N9600,[(oldcode[loopcount])]
    pause 3000
    next
    Setcode = 1
    low led
    GoTo loop
    EndIF
    Setcode = setcode + 1
    GoTo Loop
    EndIF
    IF keycode = "#" Then ' Zero's the number of digits counter,
    setcode = 1 'functions as a key reset
    unlock = 1
    goto loop
    IF keycode = "*" Then ' If key is a star try to unlock door
    For loopcount = 1 to Numdig
    IF Newcode[loopcount] = oldcode[loopcount] Then
    unlock = unlock + 1
    IF unlock = Numdig Then ' If code matches unlock the door
    high led ' LED shows unlock status, 1=LED on
    high relay1 ' unlock relay on
    serout serpin,N9600,["Door Unlocked"]
    SEROUT serpin,N9600,[keycode]'Send key value out
    Pause 500
    For Loopcount = 1 to 10 ' Zero out keycode
    Newcode[loopcount] = "E"
    Next Loopcount
    unlock = 1 ' Reset unlock
    setcode = 1 ' Reset digit codes
    low led ' Unlock LED off
    low relay1 ' unlock relay off
    goto loop
    EndIF
    Else
    Setcode = 1
    Unlock = 1
    GoTo loop
    EndIF
    Next Loopcount
    EndIF
    if setcode > numdig then setcode = 1
    gosub send
    GoTo loop
    Send:
    SEROUT serpin,N9600,[#setcode]'Send key value out
    SEROUT serpin,N9600,[254,192]'Send key value out
    SEROUT serpin,N9600,[#Numdig]'Send key value out
    GetKey:
    PAUSE 50 'Debounce key-input
    GetKeyu:' Wait for all keys up
    PORTB = 0 ' All output-pins low
    TRISB = $f0 ' Bottom 4-pins out, top 4-pins in
    IF ((PORTB >> 4) != $f) THEN getkeyu'If keys down, loop
    PAUSE 50 ' Debounce key-input
    GetKeyp:' Wait for keypress
    FOR row = 0 TO 3 ' 4 rows in keypad
    TRISB = (DCD row) ^ $ff ' Set one row pin to output
    col = PORTB >> 4 ' Read columns
    IF col != $f THEN gotkey' If any keydown, exit
    NEXT row
    GOTO getkeyp ' No keys down, go look again
    GotKey: ' Change row and column to key number 1 - 16
    key = (row * 3) + (NCD (col ^ $f))
    'NOTE: for 12-key keypad, change to key = (row * 3) 16 key * 4
    RETURN ' Subroutine over
    Resume
    france
    Default tres fort
    You are very strong, really very well your program And me I am not able to make this program thank you
    Jan 2006
    Hi there, I'm trying to use your code on a 16F648A, and getting unexpected results. I've read the spec sheet till I'm blue in the face and well, maybe I've missed something. But I thought I'd ask if you've done anything other than hook the outputs of the PIC to the Keypad and then hook into the inputs. ie, have you got any resistors or anything else inline? I seem to be getting some keys read sometimes with little or no rhyme or reason.
    Mar 2006
    Default Hookups
    There is a pull up resistor from the MCLR to power and that is really the only necessary external "stuff" needed to play with it. The finished circuit has filter caps, xsistors, relays, etc. to make it functional. I used a standard 12 key keypad and the only thing I can think of is to make sure you have your rows, columns correct on the keypad. The keypad matrix code was picked up from the web, all I did was put in the stuff to lock, unlock the door. Start by removing all the extraneous code to the keypad and see if it returns the correct key sequence every time. You might need a debounce, although I have not found the need. This basic code has been running for several years with no issues at all. I did find that once I powered up the chip initially I had to do a chip clear by grounding the MCLR pin momentarily. I put a switch on the board to do that. I think it's because the power isn't real clean and I never bothered to put a cap and resistor on the chip to hold it down while the power stabilized. Other than that nothing comes to mind.
    Jan 2006
    Default Thanks
    Thanks very much for the response. I had a dodgey switch arrangement for the program switch and it was letting that pin float a bit so I changed it out and now it works great. Thanks for posting that code, very handy.
    Jan 2006
    Sorry for the double post but I thought I'd point out that if a would-be intruder applied say 12V or so to a few of the keys on the keypad the poor PIC would writhe in pain a bit then squirt some output to the garage door relay and Bobs your uncle... you're in. (assuming there are no measures taken to stop excess voltage being applied to any of the pins). I'm thinking I'll put a bunch of zeners inline.
  1. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 17:34
  2. Universal Keypad System
    By aratti in forum Code Examples
    Last Post: - 18th January 2009, 14:06
  3. Keypad input test
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 05:00
  4. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  5. novice need help for a security keypad
    By davleo in forum mel PIC BASIC Pro
    Last Post: - 17th November 2003, 22:54
