4x4 keypad Help
Results 1 to 7 of 7
Thread: 4x4 keypad Help
    Apr 2008
    Exclamation 4x4 keypad Help
    Hi all
    i am using a 18f452 with the 4 x4 keypad connected to portB
    this is on the proton Development board and the connections are as the attachment below
    All is get displayed on my lcd is
    " Keypad Test "
    "Press any key"
    I have ran the program on micro studio ICD and the program seems to be struck
    in this loop
    getkeyu:
    ' Wait for all keys up
    PORTB = 0 ' All output pins low
    TRISB = $f0 ' Bottom 4 pins out, top 4 pins in
    If ((PORTB >> 4) != $f) Then getkeyu ' If any keys down, loop
    Pause 50 ' Debounce
    Is there something i am missing
    i have the complete code below and
    DEFINE LOADER_USED 1 ' uses a bootloader
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
    Define OSC 20
    clear
    DEFINE LCD_DREG PORTD ' Use Portd for LCD Data
    DEFINE LCD_DBIT 4 ' Use Upper(4) 4 bits of Port
    ' PORTD-4 thru PORTD-7 connects to
    ' LCD DB4 thru LCD DB-7 respectively
    DEFINE LCD_RSREG PORTE ' PORTE for RegisterSelect (RS) bit
    DEFINE LCD_RSBIT 0 ' PORTE-0 pin for LCD's RS line
    DEFINE LCD_EREG PORTE ' PORTE for Enable (E) bit
    DEFINE LCD_EBIT 1 ' PORTE-1 pin for LCD's E line
    DEFINE LCD_BITS 4 ' Using 4-bit bus
    DEFINE LCD_LINES 2 ' Using 2 line Display
    DEFINE LCD_COMMANDUS 2000 ' Command Delay (uS)
    DEFINE LCD_DATAUS 50 ' Data Delay (uS)
    ' ** Define LCD Control Constants **
    I CON 254 ' Control Byte
    Clr CON 1 ' Clear the display
    Line1 CON 128 ' Point to beginning of line 1
    Line2 CON 192 ' Point to beginning of line 2
    Line3 CON 148 ' Point to beginning of line 3
    Line4 CON 212 ' Point to beginning of line 4
    ' Initialise Hardware
    TRISA=%00000000
    TRISB=%00000000
    TRISC=%10000000
    TRISD=%00000000
    INTCON2.7 = 1 ' Enable PORTB pullups
    ADCON1 = 7 ' Make PORTA and PORTE digital
    Low PORTE.2 ' LCD R/W low (write)
    Pause 1000 ' Wait for LCD to start
    lcdout I,Clr:Pause 30
    lcdout I,Line1," Keypad TEST "
    lcdout I,Line2,"..Power On.. !!"
    ' Define program variables
    col var byte ' Keypad column
    row var byte ' Keypad row
    key var byte ' Key value
    lcdout I,Line1," Keypad Test "
    lcdout I,Line2, "Press any key" ' Display sign on message
    loop: Gosub getkey ' Get a key from the keypad
    lcdout I,Line3, #key
    Pause 50
    Goto loop ' Do it forever
    ' Subroutine to get a key from keypad
    getkey:
    Pause 50 ' Debounce
    getkeyu:
    Pause 50 ' Debounce
    getkeyp:
    ' Wait for keypress
    For col = 0 to 3 ' 4 columns in keypad
    TRISB = (dcd col) ^ $ff ' Set one column pin to output
    row = PORTB >> 4 ' Read row
    If row != $f Then gotkey ' If any keydown, exit
    Next col
    Goto getkeyp ' No keys down, go look again
    gotkey: ' Change row and column to key number 1 - 16
    key = (col * 4) + (ncd (row ^ $f))
    Return ' Subroutine over
    Best Regards
    Sabu
    Yes it will stuck, you need some pull-up resistors in that. You can enable the PIC internal one
    INTCON2.7=0
    Just saw you already did.. just the wrong way
    AND you WILL have erratic results with this routine... add a PAUSEUS 5 in this section
    PAUSEUS 5
    Apr 2008
    Question
    Thank mister_e for your reply
    i am a bit confused by what you mean by
    just the wrong way
    Also without doing anything else to the program apart from changing the Enable PORTB pullups line when i used a 16f877a
    OPTION_REG.7 = 0 ' Enable PORTB pullups for 16f877a
    'INTCON2.7 = 1 ' Enable PORTB pullups for 18f452
    the program works fine could it be my pic?
    Best Regards
    Sabu
    In your first post you used...
    INTCON2.7=1
    But this actually DISABLE the internal pull-up...
    Use
    INTCON2.7=0
    instead, and the problem will disapear
    Apr 2008
    Oops silly me
    it works fine
    thanks a lot
    Sabu
    andymarrole's Avatar
    andymarrole Guest
    Default warning unable to include keypas.bas and lcd.bas
    i using pic18f4550 and PICBASIC PRO version 1.0 as my compiler..
    while i compile my program below, there is warning which is
    unable to include file keypad.bas
    unable to include file lcd.bas..
    this is my source code...
    '*  Notice  : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 10/5/2010                                         *
    Include "modedefs.bas"
    DEFINE PIC18F4550
    INCLUDE "KeyPad.bas" ' ( mister_e 's great keypad include file )
    INCLUDE "lcd.bas"
    CMCON = 7
    ADCON1 = 7
    TRISD  = %00000000
    TRISB  = %11111111
    '// Declare Variables...
    Col_A     VAR PORTB.0
    Col_B     VAR PORTB.1
    Col_C     VAR PORTB.2
    Col_D     VAR PORTB.3
    Row_A     VAR PORTB.4
    Row_B     VAR PORTB.5
    Row_C     VAR PORTB.6
    Row_D     VAR PORTB.7
    Scan_Col  VAR BYTE       ' Counter - current col
    Key_Press VAR BYTE       ' Value of key (0-9) & * + # + A + B + C + D
    Key_Down  VAR BYTE       ' Flag set true when key is depressed
    Allow_Key VAR BYTE       ' Flag - disallow multiple keys being pressed
    I         VAR byte       ' General working var
    Scan_Keypad:
      @ incf _Scan_Col, 1   ' Inc col pos...
      SELECT CASE Scan_Col  ' Col (1-4)
             CASE 1
                  Col_A = 0 ' Switch on col (active low)
                  Col_B = 1 ' Col off
                  Col_C = 1 ' Col off
              Col_D = 1 ' Col off
                  '// 1 Key
                           IF Row_A = 0 THEN        ' Key down? ...
                              IF Allow_Key = 0 THEN ' Any other key down?
                                 Key_Press = 1      ' Load var w/value of key
                                 Allow_Key = 1      ' Disallow other keys
                  '// 4 Key
                           IF Row_B = 0 THEN
                                 Key_Press = 4
                                 Allow_Key = 1
                  '// 7 Key
                           IF Row_C = 0 THEN
                                 Key_Press = 7
                                 Allow_Key = 1
            '// * Key
                           IF Row_D = 0 THEN
                                 Key_Press = 42
                                 Allow_Key = 1
             CASE 2
                  Col_A = 1
                  Col_B = 0
                  Col_C = 1
                  Col_D = 1
                  '// 2 Key
                           IF Row_A = 0 THEN
                                 Key_Press = 2
                                 Allow_Key = 1
                  '// 5 Key
                           IF Row_B = 0 THEN
                                 Key_Press = 5
                                 Allow_Key = 1
                  '// 8 Key
                           IF Row_C = 0 THEN
                                 Key_Press = 8
                                 Allow_Key = 1
                  '// 0 Key
                           IF Row_D = 0 THEN
                                 Key_Press = 0
                                 Allow_Key = 1
             CASE 3
                  Col_A = 1
                  Col_B = 1
                  Col_C = 0
                  Col_D = 1
                  '// 3 Key
                           IF Row_A = 0 THEN
                                 Key_Press = 3
                                 Allow_Key = 1
                  '// 6 Key
                           IF Row_B = 0 THEN
                                 Key_Press = 6
                                 Allow_Key = 1
                   '// 9 Key
                          IF Row_C = 0 THEN
                                 Key_Press = 9
                                 Allow_Key = 1
                  '// # Key
                           IF Row_D = 0 THEN
                                 Key_Press = 35
                                 Allow_Key = 1
             CASE 4
                  Col_A = 1
                  Col_B = 1
                  Col_C = 1
                  Col_D = 0
                  '// A Key
                           IF Row_A = 0 THEN
                                 Key_Press = 65
                                 Allow_Key = 1
                  '// B Key
                           IF Row_B = 0 THEN
                                 Key_Press = 66
                                 Allow_Key = 1
                   '// C Key
                          IF Row_C = 0 THEN
                                 Key_Press = 67
                                 Allow_Key = 1
                  '// D Key
                           IF Row_D = 0 THEN
                                 Key_Press = 68
                                 Allow_Key = 1
                  Scan_Col = 0
    END SELECT
    LCDOUT $fe,1
     LCDOUT " Key_Press "
    '// Check for key release, all cols on (active low) ...
    Col_A = 0
    Col_B = 0
    Col_C = 0
    Col_D = 0
    IF Row_A = 1 THEN
      IF Row_B = 1 THEN
         IF Row_C = 1 THEN
            IF Row_D = 1 THEN
               Allow_Key = 0
               Key_Down = 0
               Key_Press = 255
    GOTO Scan_Keypad
    please help me...
    thank you...
    Do you have those two files, KeyPad.bas and lcd.bas in the same folder as your source file that you're trying to compile?
    With that said, PBP1.0 sounds REALLY old, are you sure that is the cirrect version. And lastly, there's really no need to post the same question in three different threads, one would've been enough.
  1. connecting a 4X4 keypad
    By fadibasic in forum Schematics
    Last Post: - 12th November 2008, 17:52
  2. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 13:16
  3. 4x4 Keypad and LCD sharing port B
    By msnm4 in forum mel PIC BASIC Pro
    Last Post: - 9th May 2008, 08:13
  4. I2C PCF8574 4X4 Keypad routine
    By RFsolution in forum mel PIC BASIC Pro
    Last Post: - 28th January 2007, 21:25
  5. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 03:54
