To place the 1307 in 12-hour mode, you set bit 6 in the Hours register. To select AM at the
same time, you would clear bit 5. If you wanted to set it for PM, then you would set bit 5.
You have to include these bits with the Hour time when you first write to the 1307. After the
first write, then you only test the AM/PM bit to determine AM or PM. In 12-hour mode, only
bits 4,3,2,1 and 0 of the Hours register are used to indicate the hour.
This should be easy to convert over to the PIC you have. Look at the comments in the
Write_1307 sub-routine side-by-side with the 1307 data sheet, and it will be a lot clearer.
@ DEVICE PIC16F627A,INTRC_OSC,LVP_OFF,WDT_OFF,MCLR_ON,PROTECT_OFF
' Note: use 10K pull-up resistors on both SDA and SCL lines.
' DS1307 control pins
SDA Var PORTB.0 ' DS1307 SDA pin #5
SCL Var PORTB.1 ' DS1307 SCL pin #6
' Variables
DB       Var BYTE[8] ' Data byte array
RTCSec   Var DB[0]   ' alias individual bytes in array
RTCMin   Var DB[1]
RTCHour  Var DB[2]
RTCDay   Var DB[3]
RTCDate  Var DB[4]
RTCMonth Var DB[5]
RTCYear  Var DB[6]
RTCCtrl  Var DB[7]
AMPM     Var BIT
AM       Con 0
PM       Con 1
' Port configuration
TRISB   =   0
TRISA   =   0
CMCON   =   %00000111 ' Comparators = off
    ' 12-hour mode clock routine for the DS1307 RTC
    GOSUB Write_1307 ' Write time & date on power-up
    GOSUB Read_1307  ' Read the time & date
    ' Now display it
    HSEROUT ["Time: "]
    HSEROUT [DEC((RTCHour>>4)& $01), DEC(RTCHour & $0f),":"]
    HSEROUT [DEC((RTCMin>>4)& $0f), DEC(RTCMin & $0f),":"]
    HSEROUT [DEC((RTCSec>>4)& $0f), DEC(RTCSec & $0f)]
    AMPM = RTCHour.0[5] ' Bit 5 of RCTHour indicates AM or PM
    IF AMPM = AM THEN        ' If RTCHour.bit5 = 0 it's AM
       HSEROUT [" AM",13,10] ' Print AM
    ELSE                     ' Else it's PM
       HSEROUT [" PM",13,10] ' Print PM
    HSEROUT ["Day: ", DEC(RTCDay & $07),13,10]
    HSEROUT ["Date: ", DEC((RTCMonth>>4)& $01), DEC(RTCMonth & $0f),":"]
    HSEROUT [DEC((RTCDate>>4)& $03), DEC(RTCDate & $0f),":"]
    HSEROUT [DEC(((RTCYear>>4)& $0f)*100),DEC(RTCYear & $0f),13,13,10]
    PAUSE 1000
    GOTO Main
Read_1307:
    ' Read order is in Secs,Mins,Hours,Day,Date,Month,Year,Control
    I2CRead SDA,SCL,$D0,$00,[STR DB\8]  ' Read string of 8 bytes from DS1307
Write_1307:
    ' $71 in the Hours register would make it 11 PM
    ' $51 in the Hours register would make it 11 AM
    ' Example:
    ' $51 = %0101 0001 <-- 1's position of hour
    '        ||||_________ 10's position of hour. 10+1 = 11 O-clock
    '        |||__________ 1 = PM, 0 = AM (in 12-hour mode)
    '        ||___________ 1 = 12-hour mode, 0 = 24-hour mode
    '        |____________ ignore this bit
    ' Set time & date to  11:59:00, Day 2, Date:Month:Year 30:08:2007
    I2CWRITE SDA,SCL,$D0,$00,[$00,$59,$51,$02,$30,$08,$27,$90] ' Write to DS1307
    RETURN                  ' Sec Min  Hr Day  D   M   Y  Control
