I2Cwritge - array
Results 1 to 4 of 4
    Sep 2006
    Venezuela - Caracas
    Default I2Cwritge - array
    i write 4 time 100% no error, after 4 many caracters wrong
    if i use "for" work 100%, but is slow
    for i = 0 to 38
    I2CWRITE MData, MClock, Controle, Posicao_Memoria, [Letra_2(i)]
    Posicao_Memoria = Posicao_Memoria + 1
    PAUSE 5
    next i
    my code
    I var byte
    Controle var Byte
    Posicao_Memoria VAR WORD
    Letra_2 var byte[38]
    Controle = $A0
    WRITE 8, 0
    WRITE 9, 0
    for i = 0 to 38
    Letra_2(i) = i
    next i
    loop:
    ' read adress
    READ 8, Posicao_Memoria.HighByte
    READ 9, Posicao_Memoria.LowByte
    I2CWRITE MData, MClock, Controle, Posicao_Memoria, [STR Letra_2\38]
    Posicao_Memoria = Posicao_Memoria + 38
    PAUSE 5
    ' write adress
    WRITE 8, Posicao_Memoria.HighByte
    WRITE 9, Posicao_Memoria.LowByte
    goto loop
    Aug 2004
    Default I2C write
    Hi:
    What EEPROM are you using.?. I think it is a 24LC32 or bigger,because the word address.
    You must make the pause for each Write of 10 ms. Some memories do not like only 5.
    Greetings...
    Ruben de la Pena
    Jul 2007
    Default Pages write problem, I think.
    Most EEPROM use a cache page of 8 bytes. You may encounter all kinds of problems if you try to write the same page in two subsequent write operations.Thus, I think it will be better to go with multiples of 8. Meaning you will use 40 instead of 38 in this statement: "Posicao_Memoria = Posicao_Memoria + 38". And the rest of the code should obviously go according to this. And yes, you probably need 10ms pause anyways.
    Have a look at the datasheet to understand the difference between page write and byte write. You will find some other valuable informations too!
    J-P
    Sep 2006
    Venezuela - Caracas
    thanks brothers for help
    i'll try multiples of 8
    Last Post: - 14th June 2016, 08:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. Array values changing
    By MyBuddy in forum mel PIC BASIC Pro
    Last Post: - 30th October 2009, 00:13
  4. RS232 receive an array (packet)
    Last Post: - 12th February 2008, 06:02
  5. If Then Array Oddity
    By atillotson in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 18:46
