How can a battery powered PIC turn itself off?
Results 1 to 9 of 9
    Thoranaga's Avatar
    Thoranaga Guest
    Default Power OFF
    I use this small addon circuit to my PIC :
    May 2008
    Italy
    This circuit is capable of very high current, and I use it several times!
    Feb 2005
    Kolkata-India
    Default If your circuit is not powering other blocks
    If your circuit is not powering other blocks having higher quiescent current you may use the PICs sleep mode. Nanowatt PICs with internal or LP oscillator works great and never lets me down.
    Advantage : You might end up using a single CR2032 for your circuit. Cause your circuit drops out at least 0.6 volts and PICs works from 2 volts.
    Sougata
    Jan 2007
    Default Re: How can a battery powered PIC turn itself off?
    Had the same problem, then I looked carefully at the circuit and laughed my head off!
    Like you I switched the POSITIVE side of the power....BAD MOVE..put the FET in the NEGATIVE rail so the circuit you want to power is effectively the LOAD use a pull down resistor of 10K or so and ALL will be well.
    Took me a while to figure this out, but if you look at what is happening then it's obvious.
    Hope this helps.
  1. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  2. Help with PIC project
    By davekav in forum General
    Last Post: - 18th April 2008, 00:15
  3. PIC powered by capacitor for 0,5 second
    Last Post: - 25th August 2007, 10:23
  4. LCD will not start
  5. 12F683 battery powered remote - energy consumption question
    By silentwol in forum mel PIC BASIC Pro
    Last Post: - 13th April 2007, 14:23
