Electronic DICE for PIC10F or anything else!
View Poll Results: So how did you rate this Project?
Voters
14. You may not vote on this poll
  • Great, just what I wanted
    8 57.14%
  • Something to consider when I'm bored
    6 42.86%
  • You have nothing better to do with your time?
    0 0%
  • It sucks!
    0 0%
Results 1 to 5 of 5
    Default Electronic DICE for PIC10F or anything else!
    I concede to Bruce as the first person on this forum to do something useful as a stand-alone application with a PIC10F series. These PICs are really designed for use as 'electronic glue' sticking together other electronics that might otherwise not be compatible, or to replace chunks of discrete logic in larger designs.
    However… not wishing to be outdone… here's something for one and all to enjoy... electronic DICE... yeah, I know, it's been done before and will be done again until the end of time… But has it been done with a microprocessor that boasts all of a massive three and a half I/O's?
    How do you connect seven (or in our case eight) LEDs, have a User switch-On, Generate a Random Number and have Auto switch-Off all inside a PIC with those impressive three and half I/O's – and use only around a dozen parts (of which eight are LEDs)? And (topically) how do you do it in MeLabs PBP and not cheat by using Assembler?
    Now's your chance to find out… grab your samples of PIC10F's and start rolling that Dice...
    Given some time I'll probably throw together a PCB and a nice silk-screened professional enclosure if there's any interest.
    Enjoy...
    Vote option are a bit limited but i voted 'something to consider when i'm bored'... not the project is boring. No seems great. Let's say i'll interpret it like
    I'll consider 10F when i'll be bored with any other project on the shelf
    Maybe a 10F project contest could be add somewhere here
    Hurry up everybody, let's show what we can do with only 3-4 i/o and really limited code space AND only in PBP if possible.
    Nov 2004
    Saskatchewan Canada
    Hmmm, I can't open this file from here or after I download it. Is something up with it?
    Bart
    It's a straightforward Adobe pdf file... opens up just fine.... anyone else have problems?
    Nov 2004
    Saskatchewan Canada
    After the fifth attempt today it finally opened after I downloaded it. Don't know why it wouldn't work the first four, but now maybe I can glean some knowledge.
    Bart
  1. Replies: 5
    Last Post: - 12th December 2007, 17:47
  2. The 10 Electronic Commands
    By Acetronics2 in forum Off Topic
    Last Post: - 2nd February 2007, 11:21
  3. pic part models for electronic workbench
    By vacpress in forum Off Topic
    Last Post: - 17th January 2007, 23:42
  4. Round Dial, Electronic Combination Lock
    By Pic_User in forum Off Topic
    Last Post: - 6th July 2006, 14:34
  5. Electronic Key
    By Carl0701 in forum mel PIC BASIC Pro
    Last Post: - 16th February 2004, 11:01
