Need help on serial rfid receive
Results 1 to 5 of 5
Threaded View
    May 2007
    Area 71
    Default Need help on serial rfid receive
    I am experimenting with id12 rfid reader with PIC18f2550, but I can not get consistent reading. id12 has a leading character ( 02h) , how to read the data after this leading character?
    I tried with WAIT modifier, but it did not gave any result
    HSERIN [ wait ($02), b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13 ]
            __CONFIG    _CONFIG1L, _PLLDIV_10_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_1_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _VREGEN_OFF_2L
            __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_ON_3H  & _CCP2MX_ON_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L  & _DEBUG_OFF_4L
    define osc 40
    DEFINE LCD_DREG PORTB     ' LCD data port
    DEFINE LCD_DBIT 0         ' LCD data starting bit
    DEFINE LCD_RSREG PORTB    ' LCD register select port
    DEFINE LCD_RSBIT 4        ' LCD register select bit
    DEFINE LCD_EREG PORTB     ' LCD enable port
    DEFINE LCD_EBIT 5        ' LCD enable bit
    DEFINE LCD_BITS 4         ' LCD data bus size
    DEFINE LCD_LINES 2        ' Number lines on LCD
    DEFINE LCD_COMMANDUS 1500 ' Command delay time in us
    DEFINE LCD_DATAUS 44      ' Data delay time in us
    define HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 25
    define HSER_CLROERR
    b1 var byte
    b2 var byte
    b3 var byte
    b4 var byte
    b5 var byte
    b6 var byte
    b7 var byte
    b8 var byte
    b9 var byte
    b10 var byte
    b11 var byte
    b12 var byte
    b13 var byte
    clear
    porta = 0
    portb = 0
    portc = 0
    TRISA = %00000000               ' Set PORTA to all input
    TRISB = %00000000               ' Set PORTB to all output
    TRISC = %10000000               ' Set PORTC to all input
    LCDOUT $FE, 1   'clear lcd
    HSERIN [ wait ($02), b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13 ]      ' the data sequence is STX(02h), data ( 10 ASCII ),checksum (2 ASCII ),CR, LF, ETX(03h)
    LCDOUT $FE,1 , b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13
  1. Receive serial data
    Last Post: - 7th August 2008, 22:52
  2. Free Web based RFID Online Courses
    By Thirumoorthy in forum General
    Last Post: - 19th November 2007, 13:38
  3. Free web based RFID online Course
    By Lesikar in forum GPS
    Last Post: - 19th October 2007, 22:28
  4. Serial interface with RFID reader
    By brid0030 in forum Serial
    Last Post: - 23rd January 2007, 06:23
  5. PIC16F877 to RFID Module Serial Interface
    Last Post: - 17th May 2005, 06:03
