I2C with 8564 RTC
Results 1 to 6 of 6
    Apr 2005
    Auckland/New Zealand
    Default I2C with 8564 RTC
    I'm using I2C command with 8564 RTC .
    I2Cwrite is working ok.
    I2CREAD is not giving me what I want.
    ADCON1=127
    sda var portb.4
    scl var portb.5
    dt var byte
    I2Cwrite sda,scl,$A2,$0D,[80] 'write 80 hex in register 0D.
    I2Cread sda,scl,$A3,$0D,$A2,[dt] 'This command should put 80 hex in dt
    write 0,dt 'this puts dt i.e.80 hex in EEPROM location 0.
    according to the datasheet of 8564 I2CREAD should be written as above control address (read) ,reg address ,control address (write).
    When compiling the above patch, no error appears in PBP.
    Can you suggest where the problem is or how I can modify/rewrite/rearrange I2CREAD.
    Processor is 18F1320. PBPv2.46 ,IDE MCSP
    Suded.
    Apr 2005
    RTC is RX-8564 EPSON with built in XTAL 32.768 kHz.
    This might help ...
    I2CRead & I2CWrite not working as expected
    http://www.picbasic.co.uk/forum/showthread.php?t=587
    Apr 2005
    Default I2cread
    Hi Darrel,
    Thanks for your reply.
    I checked the thread you suggested it has only I2Cwrite.
    I aslo found some good software in Reynolds(Rentron) website for I2C comm. but that uses individual subroutines SHIFTIN,SHIFTOUT it will be good if the I2CREAD command can do the job by itself & will be more compact.
    The Reynolds software deals with the same sitution that I have.
    Regards.
    Suded.
    Quote Originally Posted by suded View Post
    That's true, she only used I2CWRITE in the examples.
    But the problem she was describing applies to both I2CWRITE and I2CREAD.
    And that problem is also in your code. (along with some extra stuff)
    May 2008
    Florida
    Talking
    This might help ...
    Darrel
    You pointed me to the answer to my question before I asked. Man are you GOOD!
    1. It pays to read all threads even if they are not about something you are doing or your own thread.
    Was going to ask how to capture a broken wire, missing I2C device in a I2CRead.
    F1CHF asked and answered it in the #2 post.
    THANK YOU Darrel and F1CHF. and suded too.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  4. X1226 RTC - Help
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 18:54
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
