Hello Unregistered ,
Originally Posted by mister_e In theory YES, in in reality no. You should read the following link carefully. I2CRead & I2CWrite not working as expected http://www.picbasic.co.uk/forum/showthread.php?t=587 AND THEN read also carefully your datasheet, cause you'll need to modify the way to write your ControlByte AND the Address variable to follow the exact requirement. (ie. how to access all 4 different 256 Bytes block of your EEPROM) Page 6 of this PDF http://ww1.microchip.com/downloads/e...doc/21710c.pdf Thank you!
Forum Rules
