I2C with External Eeprom
Results 1 to 16 of 16
    Just finished assembling a small code and still cannot work with the eeprom
    this is the code i used :
    SSPCON.5 = 0                ; Disable SSP Module
    TXSTA.5 = 0                 ; Disable AUSART Tx
    RCSTA.7 = 0                 ; Disable Serial Port
    OSCCON = %01111110 'Internal RC w/ I/Os
    INTCON=0
    PIE1     = 0
    'PIE2    = 0
    PIR1 = 0   	'off
    CMCON= 7   	'COMPARATOR OFF
    CVRCON= 0 	'Vref Off
    CCP1CON= 0
    T1CON= 0
    'T2CON = %00000100
    osctune=0
    'DEFINEs
    @ DEVICE INTRC_OSC
    @ DEVICE MCLR_OFF
    @ DEVICE PROTECT_OFF
    DEFINE osc 8
    @ DEVICE CPD_OFF
    @ DEVICE LVP_OFF
    @ DEVICE BOD_OFF
    @ DEVICE PWRT_OFF
    @ DEVICE WDT_OFF
    'ADC parameters
    ADCON1  =%10000000      'right justify
    ANSEL   =%00000001 	'PORTA.0 ANALOG
    ADCON0  =%11000001
    INCLUDE "modedefs.bas"
    'settings for serial comm
    DEFINE debug_reg PORTB
    DEFINE debug_bit 7
    DEFINE debug_baud 9600
    DEFINE debug_mode 1
    'I/O's
    PORTA=0
    PORTB=0
    TRISA=%00000001		'PORTA.0 AS INPUT
    TRISB=%00000111		'SDA,SCL AND BUT1 AS INPUTS
    'PINS
    A0    	var PORTA.0
    a1     	var PORTA.1
    A2    	var PORTA.2
    A3      var PORTA.3
    A4      var PORTA.4
    MCLR    var PORTA.5
    a6    	var PORTA.6
    a7    	var PORTA.7
    SDA    	var 	PORTB.0   'I2C DATA PIN
    SCL    	var 	PORTB.1   'I2C CLOCK PIN
    but1    var 	PORTB.2   'BUTTON FOR LOOP
    b3     	var 	PORTB.3
    B4    	var PORTB.4
    B5    	var PORTB.5
    B6    	var PORTB.6
    out    	var PORTB.7
    ' variables
    mem      var 	byte
    ADDR    var 	word
    m1      var 	word
    m2      var 	word
    CTW	VAR	WORD
    CTW=$A0
    m1=0
    m2=0
    start:
    I2CREAD SDA,SCL,CTW,$1,[m1]
    pause 10
    debug " value IN EEPROM address 1 =  ",dec m1,13,10
    I2CREAD SDA,SCL,CTW,$10,[m2]
    pause 10
    debug " value IN EEPROM address 10 =  ",dec m2,13,10
    I2CWRITE SDA,SCL,CTW,$1,[5]
    PAUSE 10
    debug " WROTE 5 at address 1 =  ",13,10
    I2CWRITE SDA,SCL,CTW,$10,[6]
    PAUSE 10
    debug " WROTE 6 at address 10 =  ",13,10
    loop:
    if but1=1 then
    goto start
    goto loop
    The value returned for both addresses is 257
    Just as a note, with the first code ( showned in post #4 ) the returned value was always 8 ( for any address ) and 0 when removing the pullups.
    EDIT:
    Changed the lines:
    to
    ADDR=$1
    I2CWRITE SDA,SCL,CTW,ADDR,[5]
    ( as seen in Melanie's post about I2C )
    http://www.picbasic.co.uk/forum/showthread.php?t=587
    but the return value is the same
    DEFINE OSC 8
    @ DEVICE INTRC_OSC
    @ DEVICE MCLR_OFF
    @ DEVICE CPD_OFF
    @ DEVICE LVP_OFF
    @ DEVICE BOD_OFF
    @ DEVICE PWRT_OFF
    @ DEVICE WDT_OFF
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 1
    osccon=$7e:cmcon=7:adcon1=$80:ansel=1:adcon0=$c1:porta=0:portb=0:trisa=1
    trisb=7:sda var portb.0:scl var portb.1:addr var word:dat var byte
    dat2 var byte:ctw con $a0
    start:     dat=dat+1:addr=addr+1
    i2cwrite sda,scl,ctw,addr.highbyte,addr.lowbyte,[dat]:pause 10
    debug "Wrote: ",dec addr," with ",dec dat,13,10
    i2cread sda,scl,ctw,addr.highbyte,addr.lowbyte,[dat2]
    debug " Read: ",dec addr," val: ",dec dat2 , 13 , 10
    if dat = dat2 then
    debug "Write/Read Successful at ",dec5 addr," with ",dec3 dat,13,10
    debug "Write/Read Error at ",dec5 addr,"-Wrote:",dec3 dat," - Read:",dec dat2,13,10
    pause 500:goto start
    OR un-COLONized...
    DEFINE OSC 8
    @ DEVICE INTRC_OSC
    @ DEVICE MCLR_OFF
    @ DEVICE CPD_OFF
    @ DEVICE LVP_OFF
    @ DEVICE BOD_OFF
    @ DEVICE PWRT_OFF
    @ DEVICE WDT_OFF
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_MODE 1
    osccon = $7e
    cmcon = 7
    adcon1 = $80
    ansel = 1
    adcon0 = $c1
    porta = 0
    portb = 0
    trisa = 1
    trisb = 7
    sda var portb.0
    scl var portb.1
    addr var word
    dat var byte
    dat2 var byte
    ctw con $a0
    start:
    dat = dat + 1
    addr = addr + 1
    i2cwrite sda , scl , ctw , addr.highbyte , addr.lowbyte , [ dat ]
    pause 10
    debug "Wrote: " , dec5 addr , " with " , dec3 dat , 13 , 10
    i2cread sda , scl , ctw , addr.highbyte , addr.lowbyte , [ dat2 ]
    debug " Read: " , dec5 addr , " val: " , dec3 dat2 , 13 , 10
    if dat = dat2 then
    debug "Write/Read Successful at " , dec5 addr , " with " , dec3 dat , 13 , 10
    debug "Write/Read Error at " , dec5 addr , "-Wrote:" , dec3 dat , " - Read:" , dec dat2 , 13 , 10
    goto start
    Hi skimask,
    i'm pleased to say that your code worked. Thank you very much for your help
    Will re-write my entire code from scratch.
    I have some notes here and i will see what happens.
    Cool
    Quote Originally Posted by ruijc View Post
    Hi skimask,
    Really?
    That's amazing...because I did a quick search a couple days ago for 24LC512 here on THESE forums and, except for COLON-izing the one listing, practically did a cut-and-paste.
    Search engine must've been broken that day...huh?
    I guess i missed that one, sorry.
    But thanks anyway for your help
    Greetings,
    While reviewing my code i changed the I2C lines from :
    I2Cread SDA,SCL,CTW,mem,[x]
    to
    I2Cread SDA,SCL,CTW,mem.highbyte,mem.lowbyte,[x]
    to make it work.
    Sorry if i'm a bit stubborn ( just trying to learn ), but i re-made ( yes... re-made ) the search and as before almost every one mentions the I2C lines as follows :
    I2cwrite SDA,SCL,CONTROL,ADDR,[DATA]
    Posts like:
    http://www.picbasic.co.uk/forum/show...hlight=24lc512
    Including melanie's post
    The only one that mentions to separate the address in high and low somehow did not worked in that case
    My question is just to try to understand
    Why is that the i2c line ( I2cwrite SDA,SCL,CONTROL,ADDR,[DATA] ) works with other pics ( yes...all my programs with 12F675 work ) and with the 16F88 does not ? Why with this pic i need to have the address separated with high and low byte ?
    Also ( question for skimask )
    In post # 7 you mention :
    'cause I see a few flaws in your logic in the code written a few posts back.
    Can you please point where the flaws are so i can take a look at them ?
    Quite frankly, if it works, who cares?
    Actually, I don't remember the answer to that at the moment. I'll remember eventually...
    You'll figure it out... Suffice to say there's just MUCH better ways to do some things, more reliable, faster, longer, stronger, and so on...
  1. I2C Master/Slave 16F88/16F767 working code
  2. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  3. Replies: 1
    Last Post: - 28th January 2010, 22:15
  4. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  5. HARDWARE I2C SAMPLE CODE question
