How to Read 6 Inputs anytime ?
Results 1 to 10 of 10
    Jan 2006
    Istanbul
    In order to understand the question properly,
    1. Do you need to know which one of the inputs caused the interrupt? or it does not matter?
    2. When you say "...I don't know the change in these inputs", do you need an interrupt when there is a "change" on at least one pin?
    - PORTB7:4 gives you four pins but you need six.
    oky I want to know which input is pressed so I decide what to do ?
    Jan 2006
    Istanbul
    So, you do not need a "change" on the pins.
    You have buttons and they can only be pressed, right?
    "Change" means =>
    If the button is pressed, there is a change. While the button is being pressed, there is no change.
    If the button is released, there is also a change.
    Are you sure you need interrupt to do this? any particular reason? Many people can solve their issues without using interrupt; simple pin readings can be more then good enough. This may be true in your case, may be.
    You may want to check the status of a port for all six pins.
    Hi Sayzer,
    Looks like he wants an assembly interrupt to jump out of any running process.
    "beacuse our system entering in multiple sub routines so using polling way in main code not visible when our programm entering in another subroutine"
    looks like a job for instant interrupts.
    I think sayzer understand what I mean, but I think without interrupt we can't know what button is presesd due to busy of my porgramm in other sub routines than main code
    Sep 2005
    Campbell, CA
    It sounds like you have more inputs than you have PORTB interrupt pins - or maybe your switches aren't connected to PORTB at all.
    In that case, you could write an interrupt routine on a timer. The interrupt would read all ports connected to the buttons into variables, then return from the ISR.
    Your main program can then (bitwise) AND the variables with a mask to pick out
    which button was pushed.
    Charles Linquist
    iugmoh, Why not use 1 interrupt pin with a pullup resistor tied to as many diodes as you have switches. Then have 1 port change interrupt read the switch inputs and give the results? Why make it so complicated? Just a thought......
  1. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  3. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
  4. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
