Get a better antenna at the receiver. You can build a very simple but very good one from plans on my web page.Any solid copper insulated wire will work (the bigger the wire diameter, the better) or you can even use copper tubing if you can insulate it, and you can cheat by using 75-ohm coax for the phasing line. If you still need more range, then add a wideband preamp between the receiving antenna and receiver - it's the Ten-Tec 1001.Ignore the picture - it's the wrong one.
And try without pacing.
