RF Transmitter/Reciver
Results 1 to 40 of 76
    Jan 2008
    Yes i will inform how it goes, and maybe i will come with some questions on the PBP program for the recivers and transmitter.
    Jan 2008
    Are the Linx RF modules FM och AM?
    Can´t find anything in the datasheet?
    Neither, More like CM.
    From the data sheet
    When a logic ‘1’ is present on the DATA line and the PDN line is high, then the
    Power Amplifier (PA) will be activated and the carrier frequency will be sent to
    the antenna port. When a logic ‘0’ is present on the DATA line or the PDN line is
    low, the PA is deactivated and the carrier is fully suppressed.
    So, the only thing they can transmit is bits, think of Morse Code. ON OFF
    That is why they work so well for serial communications.
    Also, that is the reason for sending a "train" signal (010101010101) allows the receiver to balance the internal capacitor before receiving the real data.
    I think the correct way of saying it is Carrier Present - Carrier Absent
    Dec 2005
    Or OOK (On-Off Keying), ASK (Amplitude Shift Keying) or AM (Amplitude Modulation). And FSK (Frequency Shift Keying) works much better but costs much more.
    Jan 2008
    Talking
    Thank you.
    Now i have recived the Parallax RF modules and write this test programs
    Transmitter PIC16F628A whit Internal RC OSC at 4 MHz
    <html>
    <head></head>
    <body><!--StartFragment--><pre><code><font color="#008000"><i>
    </i></font>CMCON = <font color="#808080">7 </font><font color="#008000"><i>'Alla I/O Digitala
    </i></font>LEDPin <font color="#000080">VAR </font>PORTB.<font color="#808080">0
    </font>TransmitterPIN <font color="#000080">VAR </font>PORTB.<font color="#808080">4
    </font><font color="#000080">INCLUDE </font><font color="#FF0000">&quot;modedefs.bas&quot;
    </font>Counter <font color="#000080">VAR BYTE
    </font>Synk <font color="#000080">VAR BYTE
    </font>Synk = <font color="#808080">$55
    </font><font color="#000080">DEFINE </font>CHAR_PACING <font color="#808080">1000
    </font>Counter = <font color="#808080">0
    </font>Main:
        <font color="#000080">HIGH </font>LEDPin
        <font color="#000080">PAUSE </font><font color="#808080">100
        </font><font color="#000080">LOW </font>LEDPin
        </font><font color="#000080">SEROUT </font>TransmitterPIN,T1200,[Synk,Synk,Synk,Synk,Synk,Synk,<font color="#808080">9</font>,Counter]
        </font>Counter = Counter + <font color="#808080">1
        </font><font color="#000080">PAUSE </font><font color="#808080">600
    </font><font color="#000080">GOTO </font>Main
    <font color="#000080">END
    </font></code></pre><!--EndFragment--></body>
    </html>
    Reciver PIC16F872 with 20 MHz OSC
    <html>
    <head></head>
    </i></font><font color="#000080">DEFINE </font>OSC <font color="#808080">20
    </font><font color="#000080">DEFINE </font>LCD_COMMANDUS <font color="#808080">3000   </font><font color="#008000"><i>'Set command delay time in us
    </i></font><font color="#000080">DEFINE </font>LCD_DATAUS <font color="#808080">200       </font><font color="#008000"><i>'Set data delay time in us
    </i></font><font color="#000080">INCLUDE </font><font color="#FF0000">&quot;modedefs.bas&quot;
    </font>Counter <font color="#000080">VAR WORD
    </font>ReciverPIN <font color="#000080">VAR </font>PORTC.<font color="#808080">0
    </font>ADCON1 = <font color="#808080">7 </font><font color="#008000"><i>' Alla digitala
    </i></font><font color="#000080">PAUSE </font><font color="#808080">500
    </font>Main:
        <font color="#000080">SERIN </font>ReciverPIN,T1200,[<font color="#808080">9</font>],Counter
        <font color="#000080">GOSUB </font>LCD
    LCD:
        <font color="#000080">LCDOUT </font><font color="#808080">$FE</font>,<font color="#808080">1
        </font><font color="#000080">LCDOUT </font><font color="#808080">$FE</font>,<font color="#808080">$80</font>,#Counter
    </font><font color="#000080">RETURN
    </html>
    It´s working very well whit in the rance of 50 - 60 meters whit the transmitter indoors and the reciver outdoors, but when i take the reciver also indoors in a house 50 - 60 meters away from the transmitter the counter on the reciver display starts to show wrong numbers sometimes but it´s still counting... but whit the reciver outdoors it does not miss a single number whit in 50 - 60 meters.
    Any idé how i can to improve my code?
    I´going to do some more tests to tomorrow, it´s soon time to sleep here in sweden...
    Quote Originally Posted by Fredrick View Post
    RF is tricky, no matter what you do. Just too many variables for the average joe to account for, circuit layout, power stability, sunspot cycle, and so on and so on...
    My experiences: (which are far outweighted by a number of people on these forums when it comes to RF)
    -Try changing the number of sync bytes in the transmitter...6 sync's is a good start. Try 2, try 10, try anything, see what happens.
    -Try changing the baud rate. I had a TX434 from Rentron. The datasheets say it's only good for 4800bps. I got it to work very reliably at 9,600 and fairly decent up to 19,200, but it didn't like 2400bps. Try 2400, try 9600, try 4800...
    -Change the PACING length. You have it set at 1000, a decent number. But...maybe the RF module wants less. If you have 1ms between each character, that also means that you have 1ms between each sync character, which may be screwing up your sync'ing, which may mean that the data slicer isn't being balanced completely. Try leaving out the PACING altogether, sending your sync bytes as fast as possible, then manually PACING your sent bytes with a slight pause in between each character.
    Dec 2005
    Get a better antenna at the receiver. You can build a very simple but very good one from plans on my web page.Any solid copper insulated wire will work (the bigger the wire diameter, the better) or you can even use copper tubing if you can insulate it, and you can cheat by using 75-ohm coax for the phasing line. If you still need more range, then add a wideband preamp between the receiving antenna and receiver - it's the Ten-Tec 1001.Ignore the picture - it's the wrong one.
    And try without pacing.
    Jan 2008
    When i disconnect the power from the transmitter the reciver display still shows numbers, but does not count from 0 to 255, it´s shows 1, 244, 34, 55, 23, 99, 138, 232, 233 and so on.... where does this numbers come from?
  1. Generic RF Receiver
    By dhouston in forum Code Examples
    Last Post: - 8th September 2009, 15:35
  2. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 13:52
  3. Help with CC1100 RF Modules.
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 27th November 2006, 21:58
  4. RF designs
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 14th June 2006, 08:50
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 23:27
