RF Transmitter/Reciver
Results 1 to 40 of 76
    Dec 2005
    The frequency and the allowed output power differ depending on the region or country. Europe uses 433.92MHz and allows far more power than is allowed in N. America.
    Jan 2008
    Have just placed an order for 2 433.9 MHz transmitters and 2 recivers..
    The parallax manual says upp to 500+ feets and LINX says upp to 3000 Feets, what is the actul range?
    Can i make parallax 433.9 MHz transmitter to send whit more power?
    Jan 2008
    Have looked at the datasheet for the TXM-433-LR and find an intressting point.
    USING LADJ
    The Level Adjust (LADJ) line allows the transmitter’s output power to be easily
    adjusted for range control, lower power consumption, or to meet legal
    requirements. This is done by placing a resistor between VCC and LADJ. The
    value of the resistor determines the output power level. When LADJ is connected
    to VCC, the output power and current consumption will be at its maximum.
    Figure
    4 on Page 3 shows a graph of the output power vs. LADJ resistance.
    This line is very useful during FCC testing to compensate for antenna gain or
    other product-specific issues that may cause the output power to exceed legal
    limits. A variable resistor can be temporarily used so that the test lab can
    precisely adjust the output power to the maximum level allowed by law. The
    variable resistor’s value can be noted and a fixed resistor substituted for final
    testing. Even in designs where attenuation is not anticipated, it is a good idea to
    place a resistor pad connected to LADJ and VCC so that it can be used if needed.
    For more sophisticated designs, LADJ can be also controlled by a DAC or digital
    potentiometer to allow precise and digitally variable output power control.
    Itīs look like i can easy modifie my RF module to work whit the range of 3000 feet or (900 meters) by removing or replace the resitor R5 (se Picture), and i think itīs still legal i sweden to transmit at this ranges on the private 433.92 MHz band.
    http://www.parallax.com/Portals/0/Im...79/27980-L.jpg
    As others have said check your local laws.
    You are reading the data sheet, did you see the part about 3 volts. Do not make the mistake of using 5 volts like you normally would with a PIC.
    Jan 2008
    The Typical voltage for the LINX module is 3 volts and the parallax module need 5 volts so i assume that there is an voltage regulator on board.
    So if i measure the voltage between GND and infront of the resistor R5 and have 3 volts it shold not be an problem to just bypass the restistor to get maximun power or?
    I just check the local law and there is no problem to run at maximun power on the 433.92 MHz band.
    Dec 2005
    The legal limits are on the radiated power not distance. Distance is heavily influenced by environment. It's impossible to say whether you are within the legal limits without some sophisticated and expensive test equipment. The tests required by the FCC for the USA cost about $US3000.
    You can see the limits here...Of course, whether the authorities will catch you and punish you if you exceed the limits is another matter.
    Jan 2008
    Ok... but in teori (legel or not) i only have to bypass or change the resistor R5 to another value.... or?
    In the doc i find the limit is Max 25 mW in sweden not 10mW.
    http://www.scanner.nu/pdf/riks.pdf (itīs i swedish)
    Quote Originally Posted by Fredrick View Post
    If R5 is connected to LADJ then you may be right. Just remember the max voltage of 3 any place on the LINX.
    Another way to get maximum distance from any radio is to use a good antenna. I doubt the , as we call them here "duckie" that is on the Parallax is very good. Most duckies are not very good for for distance.
    A quarter wave with ground plane or a half wave will work the best for distance at any power.
    I think dhouston has antenna info on his web site. Or google for a ham radio site for more info. The antenna is half of the radio in terms of performance.
  1. Generic RF Receiver
    By dhouston in forum Code Examples
    Last Post: - 8th September 2009, 15:35
  2. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 13:52
  3. Help with CC1100 RF Modules.
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 27th November 2006, 21:58
  4. RF designs
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 14th June 2006, 08:50
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 23:27
