Bit Angle Modulation (BAM) in a PIC
Results 1 to 40 of 151
    Feb 2008
    Michigan, USA
    Default Trying to duck the mortar fire......
    Thanks Darrel for the advise.... sadly, I'm still having problems....
    To all that care to give me some advise:
    I have tried cleaning up my code so that I can check flags often enough to avoid missing the comm coming in through the USART. The PWM is fairly dynamic and seems to blow up the comm (OERR) if I enable more than one of the LED subroutines. I have tried to use low priority INTS, and didn't get it sorted out, I have tried to use a pattern similar to Darrel's in http://www.picbasic.co.uk/forum/showthread.php?t=4972 #16, but I haven't managed that yet either. Any advise would be appreciated.
    '*  Notes   : derived from Darrel Taylor & Mister E's work
    '*          : 18F1320a @ 8 mHz, PWM Freq = 95 Hz
    clear
    DEFINE OSC 8
    OSCCON  = %01110001         ' INTOSC primary, 8MHz
    INCLUDE "AllDigital.pbp"
    include "EE_Vars.PBP"       ' manipulation of EEPROM
    BAM_COUNT CON 8             ; BAM Pins are used?
    INCLUDE "MIBAM.pbp"         ;
    ;----[ MIBAM Setup ]-------------
    BAM_DUTY  VAR BYTE[BAM_COUNT]
      LED1    VAR BAM_DUTY[0]           ; array for easy access
      LED2    VAR BAM_DUTY[1]           ; with FOR loops etc.
      LED3    VAR BAM_DUTY[2]
      LED4    VAR BAM_DUTY[3]
      LED5    VAR BAM_DUTY[4]
      LED6    VAR BAM_DUTY[5]
      LED7    VAR BAM_DUTY[6]
      LED8    VAR BAM_DUTY[7]
    BAM_LIST  macro                     ; Define PIN's for BAM
         BAM_PIN (PORTB,5, LED1)        ;   and Duty variables
         BAM_PIN (PORTB,0, LED2)
         BAM_PIN (PORTA,3, LED3)
         BAM_PIN (PORTA,2, LED4)
         BAM_PIN (PORTA,1, LED5)
         BAM_PIN (PORTA,0, LED6)
         BAM_PIN (PORTA,7, LED7)
         BAM_PIN (PORTB,2, LED8)
      BAM_INIT  BAM_LIST                ; Init Pins
    DEFINE HSER_RCSTA 90h ' En serial port & cont rx
    DEFINE HSER_TXSTA 24h ' En transmit, BRGH = 1
    DEFINE HSER_SPBRG 160 ' 4800 Baud @ 8MHz, -0.08%
    SPBRGH = 1
    BAUDCTL.3 = 1         '
    address      var byte
    command      var byte
    charcnt      var byte        '
    Cnt          var byte        ' counter for ramping the display brighter
    Counter      var byte
    CyLoop       var word        ' MAY be able to combine this later
    Dly          var byte        ' used on delay loop sub
    holdoff      var word
    i            var byte
    IDloop       var byte        ' loop cntr in ID Loop
    Idx          VAR BYTE
    loop         var byte
    LoopCount    VAR WORD: LoopCount = 0        ' from Random Sub
    ModeCnt      var byte: @ EE_var _ModeCnt, BYTE, 8 ' count flashes of 1&8 LEDs when Switch
    NextLED      VAR BYTE: NextLED   = 1
    PowerOn      VAR WORD: @ EE_var _PowerOn,  WORD, 0     '
    RandVar      var word: RandVar  = 12345
    RandVar8     var byte            '
    SerialString var byte[40]         '
    Speed        VAR BYTE: @ EE_var _Speed, BYTE, 50 ' delay length /control speed
    state        var byte         ' condition bits
    state2       var byte         ' condition bits
    time         var WORD         ' delay loop sub
    temp         var byte
    value        var byte
    Sync         VAR state.0        ' Sync byte rcvd
    ForMe        VAR state.1        ' Packet is for this device
    CmdRcvd      VAR state.2        ' flag for Command  rcvd
    CntState     var state2.0       ' flag for counting pulse
    ERROR        VAR state.3        ' Sync rcvd out of order
    header       var state2.2
    tlate        VAR state.4        ' command rcvd before last one done
    ValRcvd      var state.5        ' flag: Value data rcvd
    Success      var state.6
    idle         var state.7        ' flag: idle polarity
    TraceDIR     VAR state2.1       ' cyclon
    CREN         var RCSTA.4        ' RX enable bit
    OERR         var RCSTA.1        ' Overrun  error
    RCIF         VAR PIR1.5         ' Receive  int flag (1=full , 0=empty)
    TXIF         VAR PIR1.4         ' Transmit int flag (1=empty, 0=full
    Brightness   CON 100            ; Tracers DutyCycle
    ID           CON 123            ' ID. unique to each, 255=all
    SyncByte     CON 85             ' "U" for SYNC. constant on all
    TracerSpeed  CON 15             ; Smaller = Faster L-R
    DrainSpeed   CON 30             ; Smaller = Shorter Trail
    ' once comm is figured out, Command will be used for selecting ModeCnt or speed
    ' and value will be the rate that it flashes the LEDs
    'ManMod:
    '    branch ModeCnt,[fadem,smoothm,rampm,twinklem,cyclonm,dimm,RanMainm,IDm,autom]'
    'autom:
            gosub FadeUp
            gosub SmoothUp        ' as soon as I enable more than one-
    '        gosub Fillup         ' comm starts to get erratic
    '        gosub StrobeUp
    '        gosub cyclon
    '        gosub drvdim
    '        gosub RanSub
    '        gosub shoid
    goto Main:
    '**********Sub for polled comm *********
    RX:
       IF OERR then
    hserout ["OERR", 13,10]
          CREN=0
          CREN=1
    getcomm:
          i=RCREG                  ' take it
          if header then
              if i ="#" then Discard  ' is it the end? "#" = yes
            Serialstring[Counter]=i ' Store into the array
            Counter=Counter+1
           if RCIF then getcomm     'try again of still data
          if i ="!" then header=1 ' header character? "!" = yes
          Discard:
              while RCIF
                    temp=RCREG
              wend
              if i="#" then       ' End of String character
                 Success=1        ' Yeah i got a valid string
                 header=0
       if Success then
          CREN=0                  ' Disable Receiver
          address =  Serialstring[0]   'do deciphering here
          command =  Serialstring[1]
          value   =  Serialstring[2]
          hserout ["Str rx : ",str Serialstring\Counter," Ch : ", dec Counter,13,10]
          CREN=1                  ' Enable receiver
          Counter = 0
          Success = 0
    '***** Timing Sub:   *****
    DlyTime3:                    ' longest delay loop
         for time = 0 to speed
         next time
    DlyTime2:                    ' mid delay loop
         PAUSE 2
         next time
    DlyTime1:                    ' smallest delay loop
         for Dly = speed to 0 step -1
         if RCIF then             ' check here for a comm flag r
            gosub RX              ' and get the character
            goto short            ' reduce delay, avoid blinking
         PAUSEUS 180              ' times need to be refined
    Short:
          'pauseus 5              ' times need to be refined
         next Dly
    ' Subs for patterns
    '***** Fade Sub: MODE 0  ******
    FadeUp:
           hserout ["fadeUp",13,10]
       for  cnt = 0 to Brightness      ' fade up
        gosub DlyTime1
        LED1 = Cnt: LED2 = Cnt: LED3 = Cnt: LED4 = Cnt
        LED5 = Cnt: LED6 = Cnt: LED7 = Cnt: LED8 = Cnt           '
       next Cnt                    '
    hserout ["fadeDown",13,10]
    FadeDown:
       for  Cnt = Brightness to 0  step -1 ' fade down
        gosub DlyTime1
       next Cnt                     '
    return                           'stay in fade loop
    '**** Smooth Sub: MODE 1 ******
    SmoothUp:
              hserout ["SmoothUp",13,10]
       for loop = 0 to 7
       BAM_DUTY(loop) = Brightness           ' smooth up
       gosub DlyTime2
       BAM_DUTY(loop) = 0
       next loop
    SmoothDown:
               hserout ["SmoothDown",13,10]
       for loop = 6 to 0 step -1
       gosub DlyTime2
       BAM_DUTY(loop) = 0
       next loop
    '*****  Ramp Sub: MODE 2 ******
    Bo
    Hi Bo,
    At 4800 baud, each byte takes about 2.1 mS.
    The USART has a 2.8 byte buffer, so at around 6 mS the USART buffer will overflow.
    In the DlyTime2 section, it will loop 50 times with a 2mS delay without checking the USART.
    By the time it's finished, the buffer is very likely to have overflowed.
    I think if you do the same thing you did in DlyTime1, and check the RCIF bit inside the loop, it will have a better chance.
    And as you work on the rest of the program, look for any of those Evil PAUSE statements.
    Anything more than 4ms will have to be broken in smaller loops with RCIF checks in the middle.
    Added:
    Another method might be to use ON DEBUG, with only the Delay routines ENABLEd.
    Then it would be able to check RCIF in-between each and every statement in the delay routine without actually having to write the checks into the routine.
    hth,
    Jan 2006
    Istanbul
    It would be very handy if we could use a shift register with MIBAM to multiplex the outputs.
    In that case, we could use a small PIC like 12F629 or 675, then use 74HC595 type of shift registers and get as many outputs as we want, with the possible limitations of course.
    BTW; I am getting flickering at 4Mhz even with RGB routine only.
    Jun 2007
    Default Assembler error
    I'm having problems compiling the sample code. Would you have any suggestions?
    ;----[ MIBAM Setup ]--------------------------------------------------------
    BAM_COUNT CON 3                     ; How many BAM Pins are used?
    INCLUDE "MIBAM.pbp"                 ; Mirror Image BAM module
    RED    VAR BYTE
    GREEN  VAR BYTE
    BLUE   VAR BYTE
    BAM_LIST  macro                     ; Define PIN's to use for BAM
         BAM_PIN (PORTB,0, RED)         ;   and the associated Duty variables
         BAM_PIN (PORTB,1, GREEN)
         BAM_PIN (PORTB,2, BLUE)
      BAM_INIT  BAM_LIST                ; Initialize the Pins
    ;___________________________________________________________________________
    Assembler output:
    project.asm 257: Symbol not previously defined (wsave)
    project.asm 260: Symbol not previously defined (ssave)
    project.asm 262: Symbol not previously defined (psave)
    project.asm 388: Symbol not previously defined (psave)
    project.asm 390: Symbol not previously defined (ssave)
    project.asm 392: Symbol not previously defined (wsave)
    project.asm 393: Symbol not previously defined (wsave)
    In the MIBAM thread. The second post lists the typical Error/Warning messages you might encounter.
    In your case, you need to add the wsave block shown in Post#1.
    Feb 2008
    Michigan, USA
    Sorry I didn't get back. Thank you, that was where I missed it.
    Bit of a lull as I wait for a new meLabs serial programmer. For some reason the 18F2550 decided to become a heating element instead of a processor. Alas, it lived a good life.... Couldn't be EOC, could it? (Excessive Operator Carelessness). Had to dig out an old laptop that still had a parallel port to run the EPIC programmer.
    Bo
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Cordic trig assembly code for PIC18f
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th September 2015, 06:36
  3. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 17:10
  4. MIBAM - (Mirror Imaged Bit Angle Modulation)
    Last Post: - 15th February 2009, 17:02
  5. Bit Angle Modulation
    By BH_epuk in forum mel PIC BASIC Pro
    Last Post: - 18th November 2008, 08:01
