Simple RF Transmit and Receive
Results 1 to 40 of 43
    Dec 2005
    The test circuit shown on p6 of http://www.radiometrix.com/pdf/tx2rx2.pdf shows how to use the CD pin. You'll need to modify your receiver schematic to add the transistor, resistor and cap. Then, just monitor the /CD signal to determine when a signal is being received. Depending on the response time, you may need to prepend a non-data byte to all messages. FSK signalling is much more reliable than ASK. If you add manchester encoding to FSK, you get a really robust system.
    Thank you very much Dave, I will add the manchester encoding!!
    What will hapen when 2 or 3 transmitters, transmit at the same time?
    Like here, at home ...
    The door bell will ring when it recognizes " something known " in the wheather station transmission !!!
    so, think to add a checksum to valid your message ...
    Thank you, I will build in a checksum.
    I am fairly new to RF and PICs, and want to understand what I am doing.
    What is the reason for using the CD Pin signal detection, why doesn't it work if I only monitor the input?
    Dec 2005
    Quote Originally Posted by koossa View Post
    Most likely you'll receive a nonsense transmission if they indeed transmit at the same exact time. You need to embed a transmitter ID within the transmission packet and add a CRC or checksum to determine whether the data packet is valid and, if so, from whence it came. Also, there are limits on how often a transmitter can transmit. Adding a bit of randomness to the transmission schedules will minimize collisions. What's the application?
    Thank you very much Dave.
    I want to build my own simple wireless motion detector for outdoor security.
    Could you please tel me what is the reason for using the CD Pin signal detection, why doesn't it work if I only monitor the RF input?
    Dec 2005
    With the FSK modules, a logic 1 is represented by one frequency and a logic 0 is represented by a slightly different frequency. the Carrier Detect (CD) output indicates when either frequency (or any frequency close to them) is present and that's a fairly strong indication that a signal is present. Just monitoring the RF input (which really should be labelled Antenna Input) will give you a lot of ultralow level random noise as it is before any tuned circuits - it's equivalent to throwing away the receiver and just attaching the antenna to a PIC input. There are two data output pins - both are demodulated so they are in the audio frequency range. The AF pin is an analog output. Its amplitude can be usually used as an indication of received signal strength. The RXD pin is a digital output of the logical ONES and ZEROS. Use CD to tell you when to monitor RXD.
    My web page is down right now due to a mixup with a new hosting service I've moved to. As soon as it's back up (later today, hopefully), you can see how to use your soundcard like an oscilloscope to record the audio frequency output signals as wave files. It's much easier to grasp the basics when you can see the signals output by the receiver.
    EDIT: My page is back up. The second section - Wireless Application Notes may help you.
    Thank you very much Dave, I really appreciate your help!!
  1. rf problem
    By -Dan- in forum General
    Last Post: - 20th November 2007, 17:05
  2. 16F876 Usart Receive
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 16:43
  3. Help with CC1100 RF Modules.
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 27th November 2006, 21:58
  4. USB Interface using PIC
    Last Post: - 22nd May 2006, 17:04
  5. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 17:34
