Multiple HPWM question
Results 1 to 3 of 3
    Jun 2007
    Default Multiple HPWM question
    Hello,
    I just made an experiment with 18F4431 again.
    The blinky program works, and now I want to have multiple / simultanous HPWM
    My code did not work, How to setup so the RB0,1,2,3 become PWM PORT ? Is there any other register to modify ? Thanks
    DEFINE OSC 8            ' Oscilator HS
    TRISA = %00000000               ' Set PORTA to all output
    TRISB = %00000000               ' Set PORTB to all output
    TRISC = %00000000               ' Set PORTC to all input
    TRISD = %00000000               ' Set PORTD to all output
    TRISE = %00000000               ' Set PORTE to all output
    ANSEL0= %00000000               ' Analog channel AN0-AN7 off
    ANSEL1= %00000000               ' Analog channel AN8 off
    hpwm 0, 100, 7000    'RB0 as hpwm output
    hpwm 1, 180, 7000    'RB1  as hpwm output
    hpwm 2, 250, 7000    'RB2  as hpwm output
    See the example in this thread http://www.picbasic.co.uk/forum/showthread.php?t=7095
    Between that & the data sheet you should be able to get it going.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2007
    Thumbs up
    Thank you Bruce,
    It works
  1. General Question About Multiple Interrupts
    By grzeh666 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2008, 18:09
  2. Newbie HPWM / ADC question
    By Johan in forum mel PIC BASIC Pro
    Last Post: - 25th June 2007, 13:52
  3. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  4. HPWM and A to D interaction question 18F252
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 10th May 2006, 04:50
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
