PC Keyboard question
Results 1 to 14 of 14
    Question PC Keyboard question
    Hello,
    I am new to PBP and PIC’s but I am trying to learn more about PIC projects. I need to build a PS2 Keyboard with only some of the keys of a standard keyboard, i.e. 24 to 28. I have a little experience with the 16F688 and if possible I would use it again for this project. I think it will communicate through the serial out of the chip.
    Here are my questions; Is there any information on the interfacing of a PIC to the PS2 port on a PC. I have read and I believe I understand the scan codes, but what I do not fully understand is the communication to the PS2 port. Is it 9600 baud with 11 bits? Are there examples out there where someone has done this before too? Does the PBP serial I/O commands support this type of communication?
    Communicating through the PS2 port seems very interesting and all types of things could be done, if I can get my head round the basic I/O.
    Thanks for the help
    Have you seen this thread yet?
    AT/PS2 Keybord - PIC Interface?
    http://www.picbasic.co.uk/forum/showthread.php?t=2736
    Perth, Australia
    RE: the thread linked above: I did managed to get a keyboard interfaced to a PIC and it works great. Of course, what you want to do is the reverse (i.e. emulate a keyboard using a PIC).
    I'm happy to post my code if you think it will be helpful.
    Default PC Keyboard design
    DT, and KamiKaze47,
    Thanks for the info,
    I have been going through the thread, it seems somewhat difficult to get the timing correct. It looks like you can use the HserIn and HserOut commands to clock the data to the PC and depending upon what you need to send it could be easier with PBP. Did you find the 16F84A was easy to use with the internal clock, or did you have to add an external to make it work?
    If you do not mind your source would be of great help.
    Hatchethand
    Perth, Australia
    In the end I didn't use a 16F84A, but purely because the code space wasn't big enough for what i wanted to do. Also, I never ended up using any special PBP commands, opting to write a subroutine using interrupts that would get the timing perfect. I used an 18F1320 with it's 8Mhz internal clock, but I think 4Mhz would work too.
    Here's my code:
    INCLUDE             "DT_INTS-18.bas"                        ' Include base interrupt system
    INCLUDE             "ReEnterPBP-18.bas"
    ' Interrupt Aliases
    INT0IE              var INTCON.4                            ' INT0 external interrupt enable bit
    INTEDG0             var INTCON2.6                           ' INT0 external interrupt edge select bit: 1=Rising Edge 0=Falling Edge
    ' I/O
    kb_clock            var PORTB.0                             ' Keyboard clock pin
    kb_data             var PORTB.1                             ' Keyboard data pin
    ' Constants
    buffer_size         CON 32                                  ' Keyboard buffer size
    ' Variables
    packet              var word bank0                          ' Latest packet from the keyboard
    packet_index        var byte bank0                          ' Current bit in keyboard packet
    buffer              var byte[buffer_size] bank0             ' Keyboard data buffer
    buffer_i_index      var byte bank0                          ' Current buffer possition for inputs
    buffer_o_index      var byte bank0                          ' Current buffer possition for outputs
    data_received       var byte bank0                          ' Latest byte retrieved from the buffer
    n                   var word bank0                          ' Temporary variable for loops
    temp                var word bank0                          ' General temporary variable
    new_data            var bit bank0                           ' Flag to indicate there is new data from the keyboard
    parity_bit          var bit bank0                           ' Parity bit used for PIC->keyboard communication
    error               var bit bank0                           ' Flag to indicate an invalid packet
    ' Initialisation
    INPUT kb_clock                                              ' Keyboard Clock Pin = Input
    INPUT kb_data                                               ' Keyboard Data Pin = Input
    INT_LIST macro   ;  IntSource   Label           Type   Reset Flag?
        INT_Handler     INT0_INT,   _int0_handler,  PBP,   yes
        INT_CREATE
    INTEDG0=0                                                   ' INT0 Interrupt to Trigger on Falling Edge
    @ INT_ENABLE INT0_INT
    gosub check_for_new_data
    IF new_data=1 then
        ' Do whatever you want with the byte we just received. It is stored in data_received.
    ' Keyboard interrupt handler: Retrieves packet from keyboard
    int0_handler:
    packet.11=kb_data                                          ' Store bit
    packet=packet>>1                                           ' Rotate the packet so it is ready for the next bit
    packet_index=packet_index+1                                ' Increment packet bit index
    iF packet_index=11 then                                    ' If packet is complete:
        gosub check_packet_for_errors                          ' Check the packet for errors
        if error=1 then                                        ' If there was an error:
            packet=0                                           ' Discard the packet
            packet_index=0                                     ' Reset the packet bit index
            goto int_exit                                      ' Exit the interrupt
        packet_index=0                                         ' Reset Packet Index
        packet=packet>>1                                       ' Discard the start bit
        buffer[buffer_i_index]=packet.byte0                    ' Store just the recieved byte
        buffer_i_index=buffer_i_index+1                        ' Increment buffer input index
        if buffer_i_index=buffer_size then buffer_i_index=0    ' If end of buffer has been reached, reset the index
        IF buffer_i_index=buffer_o_index THEN                  ' If the buffer is full:
            INT0IE=0                                           ' Disable Interrupt
            OUTPUT kb_clock                                    ' Set the keyboard's clock as output
            low kb_clock                                       ' Set the keyboard's clock line low (tell the keyboard to stall)
    int_exit:
    @ INT_RETURN
    ' Subroutine to check to see if there is any new data waiting in the keyboard buffer
    check_for_new_data:
    IF buffer_o_index!=buffer_i_index then                      ' If the buffer is not empty:
        data_received=buffer[buffer_o_index]                    ' Get the next byte from the buffer
        new_data=1                                              ' Set the new data flag
        buffer_o_index=buffer_o_index+1                         ' Increment buffer output index
        if buffer_o_index=buffer_size then buffer_o_index=0     ' If end of buffer has been reached, reset the index
        IF INT0IE=0 THEN                                        ' If the buffer was full, its now got a space, so:
            INPUT kb_clock                                      ' Release the keyboard's clock line
            INT0IE=1                                            ' Re-enable the interrupt
        new_data=0                                              ' If the buffer is empty, clear the new_data flag
    ' Subroutine to check the incoming packet for errors
    check_packet_for_errors:
    error=0                                                     ' Reset error flag
    parity_bit=1                                                ' Set parity bit for start of calculation
    temp=packet                                                 ' Copy the packet to a temp variable so we can play with it
    if packet.0=1 then                                          ' Check that start bit = 0
        error=1
    if packet.10=0 then                                         ' Check that stop bit = 1
        error=1
    temp=temp>>1                                                ' Discard the start bit
    for n=0 to 7                                                ' Calculate what the bit parity should be
        if packet.0=1 then toggle parity_bit
        temp=temp>>1
    next n
    if packet.10!=parity_bit then                               ' Check the parity bit
        error=1
    Apr 2006
    GearSweaterMountain, The Netherlands
    Hi Hatchedhand,
    I did this (PIC -> PC PS2) a while ago to simulate keystrokes. I used a simple 12F509
    and it worked ....
    See thread : http://www.picbasic.co.uk/forum/showthread.php?t=1611
    Best Regards,
    UB
    Perth, Australia
    Your other option is to use USB.
    It is quite trivial to set up a PIC keyboard with USB PIC chip. When you plug it in, your OS detects it as a generic USB keyboard. Include the USB keyboard definitions file and its a matter of 1 or 2 lines of code to send keystrokes. Much easier than PS2.
    Default Sample PIC to PS/2 Port
    Attached is a program I have tried. I see data going out of the data pin and the clock on the scope. But I do not get anything on the dos screen (DOS 6.22).
    I strobe the switch looking for a High, and then set and LED on when I get it, for some reason I do not see any data on the screen.
    I have tried all of the modes for the shiftout command but nothing seems to work.
    I am using pins +5 and Ground on the PCB connector, and then 1 and 5 on the connector. I have even jumpered 1-2 and 5-6 thinking I am looking at the wrong end of the cable. but nothig works.
    Any help would be appreciated.
    USB would be great, but I need PS/2.
    HH
    ' PIC 16F688
    ' PortC.5 - Data
    ' PortC.4 - Clk
    ' PortA.2 - Switch in, normal low, active high
    ' PortA.0 - LED Out, high if switch pressed
    ' Circuit description
    ' 10K pull up on PortC.5 - Data
    ' 10K pull up on PortC.4 - Clk
    ' 10K pull up on /MCLR
    ' 10K pulling down on switch input, PortA.2
    'Goal of program, to send a chracter to the PC keyboard port when switch is pressed
    INCLUDE "modedefs.bas"
    DEFINE OSC 4 ' 4 Mhz
    TRISA = %00000100 ' Set PORTA.2 to input, all others are output
    TRISC = %00000000 ' set PORTC to outputs
    CMCON0 = 7 ' turn off comparitors
    ANSEL = %00000000 ' set all as digital ports, analog off
    char var word
    breakcode var word
    char = %11100011110 '/a
    breakcode = %11111000000 '/F0H
    '----- Main Loop --------------------------------
    Start: ' loop start
    low porta.0 ' turn off LED
    if PORTA.2 = 1 then ' check switch, if pushed then LED on and Char our
    high porta.0 ' LED on
    call sendchar ' send characters
    goto start ' restart loop
    sendchar:
    shiftout portc.5,portc.4,4,[(char)\11] ' LSB first, Clk High
    shiftout portc.5,portc.4,4,[(breakcode)\11]
    char=%11010010100 '/CR
    shiftout portc.5,portc.4,1,[(char)\11] ' MSB first, Clk low
    shiftout portc.5,portc.4,1,[(breakcode)\11]
    char=%11011001110 '/b
    shiftout portc.5,portc.4,1,[char\11] ' MSB first, Clk low
    shiftout portc.5,portc.4,1,[breakcode\11]
    char=%11100101110 '/t
    shiftout portc.5,portc.4,5,[(char)\11] ' MSB first, Clk high
    shiftout portc.5,portc.4,5,[(breakcode)\11]
    char=%10100101100 '/r
    shiftout portc.5,portc.4,0,[(char)\11] ' LSB first, Clk low
    shiftout portc.5,portc.4,0,[(breakcode)\11]
    char=%10011101110 '/d
  1. PC keyboard to ASCII
    By interak in forum mel PIC BASIC Pro
    Last Post: - 1st October 2009, 17:51
  2. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 16:10
  3. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 00:04
  4. Question for the PC guru's
    By Bruce in forum Off Topic
    Last Post: - 28th January 2008, 21:05
  5. Pic to PC AT keyboard caracters
    By sezgin05 in forum General
    Last Post: - 27th March 2007, 10:45
