10F206 Problem
Results 1 to 6 of 6
Thread: 10F206 Problem
    I can program the PIC, checked voltage etc.
    Thank you for the input. I tried first to copy and paste the entire 'Dice' program. I am using MicroCode Studio Plus 3.0 with PBP 2.47. I received three 'Warnings' (Illegal OpCode) and three 'Errors' (Found label after column1) when I tried to compile for a 10f206. I commented out the three @ Device pic10f206 lines and the code then compiled ok. Is there a setup option to allow these statements to compile?
    And you have of course verified that your PIC is actually working, you've got volts where you should have them, and you've programmed it for the correct Oscillator and MCLR usage?
    Here's an example of PBP code that works for you to compare in case you've missed anything in the PICs initialisation... btw... it's a good idea to use TRISIO to configure your PICs pin I/O before you use it.
    http://www.picbasic.co.uk/forum/showthread.php?t=3510
    I don't use Microcode studio... generally find these things more of a pain than they are help... the program will compile with the command line...
    pbp -p10f206 dice -v
    The @ device statements only apply if you're using the native MeLabs assembler.
  1. USART Problem , but don't know where, in pc? or in PIC?
  2. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  3. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. PORTA.PinNo = 1 ' problem
    By frank small in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 15:30
