Another question RE port line indexing
Results 1 to 2 of 2
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default Another question RE port line indexing
    Hello again everyone.
    Some weeks ago I was put on the right track to indexing port lines as far as outputting HIs and LOs was concerned.
    It was all about the standard setting of the PORTH = ??? and PORTL = ??? referring these to ports and then being able to simply say "HIGH 1" for instance to set PORB.1 HI
    Todays brain teaser is: Is there a similar method to read the pins for indexing input data. There is a "INPUT 1" in the book, and I thought "Hmm that's pretty obvious" but on RTFM it seems that that is for setting the TRIS for a particular line to be an input. So the question remains: is there a way to read an input line with "BLAHBLAH 1" for instance (or something similar), or am I stuck with "IF PORTB.0 = ?? THEN .... " type of thing?
    Thanks, as always.
    Peter Moritz.
    Peter Moritz.
    New South Wales,
    Australia.
    See this thread http://www.picbasic.co.uk/forum/showthread.php?t=4074
    It shows a number of ways to access port pins.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Question Regarding Port A on 16F876A
    By jevert in forum mel PIC BASIC Pro
    Last Post: - 26th February 2009, 15:00
  2. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
