Tws 434/ Rws 434
Results 1 to 11 of 11
    Default Tws 434/ Rws 434
    I am trying to incorporate wireless technology into my pic projects and got the TWS 434 and RWS 434 transmitter and reciever modules.
    From what i understand in the datasheet and a couple of examples I found, is that you can use serial communication to communicate between these 2 modules.
    my problem is that i don't get any communication. I tried my program directly from pic to pic and it works fine, the problem is when i add these 2 modules then it doesn't work. I am using the 12F683 with a 4 MHZ internal osc. here is my code and hopefully someone can shed some light on how to get these things working
    ===========Reciever===============
    Define OSC 4 'OSC at 4 MHZ
    TRISIO = %000001 'Set PORTA.0 as input rest output
    ANSEL = 0 '0 analog inputs
    CMCON0 = 7 'Disable analog comparator
    option_reg.7 = 0 'enable pullups
    LCD VAR PORTA.1 'lcd output
    rx var PORTA.0 'Serial Input
    baud con 396 '2400 baud
    synch CON "a"
    dat VAR BYTE
    dummy VAR BYTE
    dummy = 0
    dat = 0
    begin:
    serin2 rx, baud, [WAIT(synch), dat] 'receive "a" then get dat
    dummy = dat
    pause 5:serout2 LCD, baud, ["start", 1, DEC (dummy), 0] 'send out to LCD
    goto begin
    '===========transmitter============
    Define OSC 4 'osc at 4 MHZ
    TRISIO = %000000 'all output
    CMCON0 = 7 'comparators off
    option_reg.7 = 0
    tx var PORTA.0
    junk VAR BYTE
    synch CON "a"
    dat VAR BYTE
    dat = 0
    junk = "j"
    loopa:
    serout2 tx, baud, [junk, junk, junk, junk, junk, junk, junk, junk, junk, junk] 'wait to synch oscillator
    for dat = 1 to 255
    serout2 tx, baud, [synch, dat] 'send data
    next dat
    goto loopa
    Bombay, India
    Try baud rate 1200 instead of 2400. Most of these modules are good at this frequency.
    Two things:
    First, the junk data transmitted has to be a certain type of junk. The receiver has to be put into a “middle” state in order to work. Think of a capacitor that is charged to its maximum of 25 volts. Adding a 25 volt signal to it will not have a change on its state. The same goes for one that is zero charged, 0 volts will not change its state. In order for either 0 or 25 volts to have the same effect the capacitor has to have an initial charge of 12.5 volts.
    To put the receiver in a “middle” state send $55 five times. Then send the synch then your data all on one line.
    'transmitted
    junk = $55
    synch = a
    SEROUT PIN,N2400,[junk,junk,junk,junk,junk,synch, data]
    'received
    SERIN PIN, N2400,[“a”],data
    Notice I used the SERIN/SEROUT , not SERIN2/SEROUT2.
    Jan 2006
    Toronto
    These modules require all data to be encoded using the Manchester code. Search this forum for it and you will find lots of examples.
    Dec 2005
    Quote Originally Posted by PJALM View Post
    Manchester encoding is not a requirement. They are used extensively without it.
    Agreed. When I was having my problems with SERIAL, tested RF by simply sending a high bit.
    Kind of like Morse code. Instead of "..._ _ _..." it was "... ..."
    DOTS = HIGH
  1. Replies: 2
    Last Post: - 29th September 2007, 07:49
