The Best Solution
Results 1 to 18 of 18
    deuhhh, if my Sunday's brain and logic is still good... the conditions could be reduced a little bit, but multiple IF-THENs still execute faster
    START:
    @   SIZESTART
        if (ML_Value[0] > $5A) and (ML_Value[0] < $82) then
            Summe_Alarm.0 = 0
                summe_alarm.0 = 1
        if (ML_Value[1] > $5A) and (ML_Value[1] < $82) then
            Summe_Alarm.1 = 0
                summe_alarm.1 = 1
        if (ML_Value[2] > $5A) and (ML_Value[2] < $82) then
            Summe_Alarm.2 = 0
                summe_alarm.2 = 1
        if (ML_Value[3] > $5A) and (ML_Value[3] < $82) then
            Summe_Alarm.3 = 0
                summe_alarm.3 = 1
        if (ML_Value[4] > $5A) and (ML_Value[4] < $82) then
            Summe_Alarm.4 = 0
                summe_alarm.4 = 1
        if (ML_Value[5] > $5A) And (ML_Value[5] < $82) then
            Summe_Alarm.5 = 0
                summe_alarm.5 = 1
        if (ML_Value[6] > $5A) and (ML_Value[6] < $82) then
            Summe_Alarm.6 = 0
                summe_alarm.6 = 1
        if (ML_Value[7] > $5A) and (ML_Value[7] < $82) then
            Summe_Alarm.7 = 0
                summe_alarm.7 = 1
    @   SIZEEND "IF-THEN-ELSE"
    @   SIZESTART
        for temp = 0 to 7
            if (ML_Value[temp] > $5A) and (ML_Value[temp] < $82) then
                Summe_Alarm.0[temp] = 0
                    Summe_Alarm.0[temp] = 1
            next temp
    @   SIZEEND "FOR-TO-NEXT"
    @   SIZESTART
        temp = 0
        repeat
                    summe_Alarm.0[temp]=1
            temp=temp+1
            until temp = 8
    @  SIZEEND "REPEAT - UNTIL"
    @   SIZESTART
        temp = 0
        while temp!=8
            temp=temp+1
            wend
    @   SIZEEND "WHILE - WEND"
    Quote Originally Posted by BenchMark Report
    IF-THEN-ELSE: 248 WORDS, 827 UsEC
    FOR-TO-NEXT: 70 WORDS, 1380 UsEC
    REPEAT - UNTIL: 66 WORDS, 1339 UsEC
    WHILE - WEND: 68 WORDS, 1364 UsEC
    Darrel may recognize some of his tricks
    Ha,
    I knew that stuff would come in handy some day.
    Nice comparisons.
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Thanks for sharing those figures with us Steve. Repeat is the same as a conditional (DO Loop) ? Main reason DO's are faster is because unlike For Nexts, they don't have counters. In VB, (For Nexts) are idiot proof making them relatively bloated & slow.
    <br/>
    Yes indeed.
    mmm yes and no. Here what reduce the speed is more likely the .0[Temp] stuff. Let's see
    @   SIZESTART
        for temp = 0 to 7
            next temp
    @   SIZESTART
        temp = 0
        repeat
            temp=temp+1
            until temp = 8
    FOR-TO-NEXT: 13 WORDS, 113 UsEC
    REPEAT - UNTIL: 9 WORDS, 72 UsEC
    about the same code space, 41uSec of difference in the speed for the whole thing.
    But now, have a look at this
    @   SIZESTART
        Summe_Alarm.0 = 0
    @   SIZEEND "Direct Bit Addressing"
    @   SIZESTART
        temp = 0
        summe_Alarm.0[temp] = 0
    @  SIZEEND ".0[Temp] stuff"
    Direct Byte Addressing: 1 WORDS, 1 UsEC
    .0[Temp] stuff: 10 WORDS, 47 UsEC
    That's 46 uSec BY single instructions/lines like that. So... much revealant when you use them a loop that the loop itself.
    Ha,
    yup, kinda REALLY handy stuff. I use it a lot here in a custom INCLUDE FILE! YES you heard me, STEVE USE INCLUDE FILES NOW
    (refer to those http://www.picbasic.co.uk/forum/showthread.php?t=2108 and http://www.picbasic.co.uk/forum/showthread.php?t=2400 )
    So it's a kind of personal mix of old and pretty old previous thread
    Those wanting to know where the idea came from, i think those bellow are the main resources
    See what you have done with me !
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    IF (ml_value[temp]-$5B)<$27 THEN
        Summe_alarm.0[temp]=0
        summe_alarm.0[temp]=1
    When used with FOR NEXT or any of the others, this should further cut time and code space .....
    ASM anyone?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Worth to measure it... do we need to start a 'coding challenge' here... if so, i'll warn Darrel, he like that
    Feb 2003
    Smile
    I didn't take the time to check everything except code words for a few cases. It looks like it saves some; the amount depends on what it is inserted between.
    you might want to warn Bruce as well
    Last edited by paul borgmeier; - 28th May 2007 at 05:23. Reason: added more detail
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Yes but first, we have to get rid of the .0[temp] for speed (see previous post).
    i'm thinking of some kind of aliasing... but, i keep thinking...
    Yeah, it's getting interesting
  1. Strange I2C problem (and solution)
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2008, 19:14
  2. Replies: 6
    Last Post: - 20th September 2008, 12:28
  3. Replies: 7
    Last Post: - 7th February 2008, 09:46
  4. Need PC software solution
    By mister_e in forum Off Topic
    Last Post: - 27th November 2005, 02:18
  5. Battery Solution
    By Keith in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2005, 06:07
