Manchester coding question
Results 1 to 10 of 10
    Mar 2007
    Default Manchester coding question
    I have been using manchester coding, $55 as the preamble and $aa as the leader bit for PIC to PIC RF transmission and everything is working. I would like to know the technical reason why I am using manchester coding and $55 as the preamble.
    Mar 2005
    Iowa, USA
    This thread has some pretty good information in it.
    http://www.picbasic.co.uk/forum/showthread.php?t=4285
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Mar 2007
    I just want to confirm my code, am I using the GE Thomas Convention where "1" is "10" or am I using the IEEE convention where "1" is "01" because it seems like I'm encoding it the IEEE convention way but at serout I invert it so it becomes the GE Thomas Convention.
    Include "Modedefs.bas"
    u var byte : counter var byte : encode var byte : u = %1101
    'Manchester encoding
    For counter = 0 to 3
    If u.0[counter]=0 Then
    encode.0[counter*2]=0 : encode.0[counter*2+1]=1 'If it is a zero make the first bit 0 and second bit 1
    Else
    encode.0[counter*2]=1 : encode.0[counter*2+1]=0 'If not then make first bit 1 and second bit 0
    EndIf
    Next counter
    serout PORTB.0, n2400, [ $55 , $55 ,$55, $55, $aa , encode ] '
    Mar 2005
    Iowa, USA
    uggg.... you're making my brain hurt! Just kidding!
    I can see why you would want clarification for documentation. The way it is coded appears to be the GE method. Physically, if I remember correctly, since it in inverted it idles high. So electrically I think it becomes the other method. Maybe I'm way off here..... gonna need some verification from someone smarter than me.
    Ryan Miller
    Quote Originally Posted by oneohthree View Post
    I wouldn't think it would matter a whole lot as long as you're using the same thing at both ends. And if the TX and RX like one combo better than the other, well, there ya go... Can't really say for sure, I haven't tried both ways.
    Mar 2007
    I know that it is working and that it doesn't really matter but I want to check my oscilloscope readings correspond with the correct convention.
    USA - Arizona
    Well, this is sure a strange question. I would think you would know why you are using it, since you have it in your code. I think the link rhino provided is good. But if you absolutley must know and have no clue why it is in your code, I would look at http://www.ottawarobotics.org/articles/rf/rf.html.
    Another strange one, how about using MPLAB (or the simulator of your choice) and see how the code runs. Then, compare this to what you see in the oscilloscope and see what happens. They should match, and you should be able to tell how the bits are done and how the code treats them.
    I agree with skimask, I do not think it matters (as long as it is the same in both TX and RX).
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. Manchester Coding / Decodeing for RF Modules
    By charudatt in forum Code Examples
    Last Post: - 31st January 2009, 11:51
  3. Replies: 8
    Last Post: - 22nd July 2008, 21:31
  4. 433MHz RF PIC2PIC connection
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 5th February 2006, 16:44
  5. Manchester coding
    By micro in forum General
    Last Post: - 13th January 2006, 04:40
