RX / TX duo
Results 1 to 20 of 20
Thread: RX / TX duo
    Jul 2006
    Default RX / TX duo
    I am fairly new to PIC's so I would love if I got some help to see if this code would work. I am making a remote control car and I have a receiver and transmitter that both use the 16f84. The four pushbuttons on the transmitter control two motors that are connected to an H-Bridge (on the receiving end) which in turn control both directions for the motors. Can someone tell me if this code is valid for the schematics? Thanks a million...
    Both schematics are attached and the code is below...
    Transmitter Code
    INCLUDE "modedefs.bas"
    output PORTB.4
    start:
    'Check if buttons are pressed
    if (PORTB.0 = 1) then one
    if (PORTB.1 = 1) then two
    if (PORTB.2 = 1) then three
    if (PORTB.3 = 1) then four
    goto start
    one:
    serout PORTB.4,N2400,["1"]
    goto start
    two:
    serout PORTB.4,N2400,["2"]
    goto start
    three:
    Serout PORTB.4,N2400,["3"]
    goto start
    four:
    serout PORTB.4,N2400,["4"]
    goto start
    Receiver Code
    output PORTA.0
    output PORTA.1
    output PORTA.2
    output PORTA.3
    start:
    in VAR BYTE
    serin PORTB.1,N2400,in
    'PORTA.0 receives signal at 2400 baud rate and places
    'input at variable in
    'Testing serial input
    if in == "1" then one
    if in == "2" then two
    if in == "3" then three
    if in == "4" then four
    goto start
    'Turn on PORTA.x for 100 milliseconds and then turn off (motors)
    one:
    high PORTA.2
    PAUSE 100
    low PORTA.2
    goto start
    two:
    high PORTA.3
    PAUSE 100
    low PORTA.3
    goto start
    three:
    high PORTA.1
    PAUSE 100
    low PORTA.1
    goto start
    four:
    high PORTA.0
    PAUSE 100
    low PORTA.0
    goto start
    Thanks again!!!
    -Mike
    skimask's Avatar
    skimask Guest
    First off, your serial input/output code won't work as it's set up. I use that particular pair of transmitter/receivers a lot, I know a bit about them. All you'll get at the output is a bunch of noise.
    Do a search on "manchester encoding" for use with this type of Tx/Rx pair.
    Basically what has to happen is this:
    You have to 'train' the receiver to 'know' what the difference between a '1' and a '0' is.
    You do this by sending a 'preamble' of 0's and 1's, a few milliseconds of each. This charges up a capacitor to 1/2 the voltage needed to detect if the input is actually a '1' or a '0'. This is actually what's called a 'data slicer'.
    After the preamble is sent, you can start sending data.
    The problem is, if the data you send has too many '1's or '0's, the capacitor in the 'data slicer' will either charge up all the way to the '1' trip-point or the '0' trip-point and pretty soon all your data is either '1's or '0's.
    The trick is to try and send an equal number of '1's and '0's. The closer you are to an equal number of each, the better the quality of the data sent.
    So, what you do is, you break apart your input byte into individual '1's and '0's, a binary '0' becomes a '01' and a binary '1' becomes a '10'. This has a side effect of doubling the amount of data you have to send, no biggie. If you only need 4 codes (actually this single byte method works up to 16 individual codes), you can just use a look up table.
    For instance:
    To send a binary 0000, send 01010101, ($55)
    To send a binary 1010, send 10011001, ($99)
    Relatively easily done. You can do it in a loop, parsing every bit out at both the Tx and Rx end, or just use bytes that have an equal number of '1's and '0's, but no more than 2 '1's or '0's in a row.
    0 = 0000 = 0101 0101
    1 = 0001 = 0101 0110
    2 = 0010 = 0101 1001
    3 = 0011 = 0101 1010
    4 = 0100 = 0110 0101
    5 = 0101 = 0110 0110
    6 = 0110 = 0110 1001
    7 = 0111 = 0110 1010
    ...and so on...
    BTW = a good preamble sequence is a bunch of $55 and $AA back to back for about 5ms with the TWS-434/RWS-434 pair.
    Have fun...break something...or make it work...
    JDG
    New Jersey
    I don't have any experience with these modules but I do have two questions about them regarding something I read a while ago:
    1. Is it true that you don't need an FCC certification to use these?
    2. What is the typical range for the pair?
    Chris
    skimask's Avatar
    skimask Guest
    You don't need an FCC certification in the U.S. as far as I know. If it's a commercial device to be sold in bulk, then you probably will, I'm not sure. I've got 10 different 'things' I've built running around the house/yard/garage, I don't have any certifications, then again, I live out in the sticks.
    Range...
    Well, it varies wildly. The best I've gotten is about 1/4 mile on 12v on the Tx at about 9600 baud (4800 if you use manchester encoding), big tuned antenna at both ends, etc. Generally, I can easily get about 100-200 feet on 5v on the Tx, 12-15 wire antennas at both ends at 2400 baud.
    JDG
    New Jersey
    FCC certification doesn't matter whether you live in the "sticks" or in a big city. I have many RF devices around my house also but they are not certified because I am not selling them. However, I have made one device that needed FCC certification because I am selling it.
    I use the Linx LR series chips and they work very well. No need for Manchester encoding and they are pretty cheap. I'm not sure how much the TWS is but you can get a pair of Linx chips for about $15 depending on where you get them. They have pretty good range (100-3000 feet) depending upon the antenna and board design, and have very little noise. Furthermore, if you want to send a decimal 1, then you send a decimal 1....no need for 10101010.
    My reason for asking the questions was money. There are many devices (quantites of 1 or 2) that I want to make for customers but I can't legally sell them because they need FCC certification. It's simply not worth it to go for a certification on a product that costs $100 to build but $5000 to certify and never sell it again. If the FCC certification is in fact not required, it would be very advantageous for me to use them.
    I was told they work on AM frequency and this is why it does not need FCC certification. If anyone knows if this is true, please let me know.
    Chris
    skimask's Avatar
    skimask Guest
    Certification - I know it doesn't matter where I live, but it doesn't hurt when what somebody doesn't know doesn't hurt them....
    The TWS/RWS-434 pair work in the 432Mhz band, On/Off keying (A.S.K.???). Still I don't think it matters. If you sell them as a commercial product, I think they have to be certified.
    Now if you sell them as a hobby/experimental type deal, that's a different story.
    Range on the TWS, I suppose I could get longer if I put more effort into the antenna efficiency at both ends. But like I said, the ranges stated above were with simple wire whip antennas, not even the stuff kind, just a chunk of wire hanging out in the wind.
    JDG
    Jul 2006
    Default I saw this done before, though
    My idea was based on this link here: http://www.rentron.com/ruf-bot.htm
    His code and schematics are all on his site. He didn't use manchester encoding but it still worked. Will my slight modifications still work with his design?
    Thanks a lot!!
    -MW
    Jul 2006
    Thanks a lot!!
    -Mike
    skimask's Avatar
    skimask Guest
    True he doesn't use manchester encoding and it does work without manchester encoding. But what the project is doing is so very simple and error tolerant, it doesn't need error correction and just ignores errors.
    I'm only saying that you'd be doing yourself a big favor by learning what manchester encoding is and why it works the way it does, and then apply those principles to your project, even if it is something as simple as turning a light on and off...or whatever.
    I can guarantee you that it will come in handy in the future if/when you actually try to send data packets back and forth and need reliability. You know how it is, projects get more and more complicated!
    JDG
    If you design a product that includes a non certified RF transmitter, and
    sell it, then it needs certification prior to the sale. If you sell an RF
    receiver with it, the receiver will need a declaration of conformity.
    If your product is Part 15 compliant, that just means the end-user won't
    need a license to operate it. Assuming they don't make any modifications
    prior to use.
    Download this: http://www.fcc.gov/oet/info/rules/pa...15-2-16-06.pdf
    Section 15.1 explains what Part 15 is about.
    For hobby projects read section 15.23 on Home-built devices
    It doesn't matter which RF modules you use. The TWS/RWS, Linx modules
    or any others that are not pre-certified. It will require certification first if you
    sell the finished product using them. It doesn't matter if you sell just 1 or
    ten million. Your transmitter still needs to be certified, and you'll need a
    declaration of conformity on the receiver.
    You can build the end product with "pre certified" modules, and antennas so
    you don't need to have it certified again. But you need to have proper labels
    fixed on the finished product.
    For example, if your using a Maxstream 9XSTREAM pre-certified module in your
    product;
    (quote from 9XSTREAM documentation)
    The 9XSTREAM module has been certified by the FCC for integration into OEM
    products without any further certification (as per FCC section 2.1091.)
    Changes or modifications not expressly approved by MaxStream could void
    the user’s authority to operate the equipment.
    In order to fulfill the certification requirements, however, the OEM must
    comply with FCC regulations:
    1. The system integrator must ensure that the external label provided with
    this device is placed on the outside of the final product.
    2. The 9XStream may be used only with Approved Antennas that have been
    tested with this module.
    Note that you may still need a 2nd certification if you use a microcontroller
    in the design. When in doubt, send it to a pre-screening lab like Linx. It's
    worth every penny you spend on making sure whatever you crank out there
    is going to have the okee-doke from the FCC.
    As for range with the TWS-434A/RWS-434 combination, you can normally
    expect between 300-500' depending on your finished circuit design or board
    layout.
    Linx LC series, 300' max normally. Linx LR series, up to 3000' line of sight.
    Range with most any RF modules is going to be determined by your finished
    design, antenna choice, operating environment, and a ton of other factors.
    For simple stuff like remote control on/off type applications, you normally
    don't need to mess with manchester encoding/decoding, but you do need to
    work out some method of synchronizing the transmitter/receiver, and
    validating all data when it's received.
    I can't share code we make money with, but I'll share a small part of what I
    use on simple encoding/decoding type apps with PIC's & inexpensive RF
    modules like the TWS/RWS, and Linx modules.
    Transmitter:
    PreAmble CON $A5    ' 10100101 preamble
    Synch    CON "~"    ' 01111110 synch byte
    SEROUT2 E_OUT,BAUD,[PreAmble,Synch,Address,DAT_OUT,Address,DAT_OUT,CHK_SUM]
    The PreAmble helps DC balance the data slicer (fancy word for a comparator).
    The synch byte is locked onto by the serin routine indicating the start of the
    address/data payload.
    I mixup my address and data bytes, and send them both twice in the same
    data stream. Address,DAT_OUT,Address,DAT_OUT which makes it very hard
    for noise on the receiver end to duplicate my actual payload like this.
    CHK_SUM is just a single byte. It contains Address + DAT_OUT where all 4
    bytes are simply added together prior to sending a packet.
    It doesn't matter that CHK_SUM overflows when adding them together. It's
    just another simple data validation byte to make sure I get a match when
    duplicate bytes of address & data are added together again on the receiving
    end.
    Partial receiver code:
       ' Wait for Synch byte, then get new inbound address and data
        SERIN2 D_IN,BAUD,[WAIT(Synch),ADD_IN1,DAT_IN1,ADD_IN2,DAT_IN2,CHK_SUM]
        ' / **** Begin data validation **** /
        ' Calculate checksum by adding all 4 address and data bytes together
        CheckSum = (ADD_IN1 + ADD_IN2)
        CheckSum = CheckSum + (DAT_IN1 + DAT_IN2)
        ' Test new checksum against one received in CHK_SUM
        IF CheckSum != CHK_SUM THEN MAIN
        ' Test address & data bytes for match
        IF (DAT_IN1) != (DAT_IN2) THEN MAIN
        IF (ADD_IN1) != (ADD_IN2) THEN MAIN
        ' Test received address against hardware address
        IF ADD_IN1 != ADDRESS THEN MAIN
        ' Do something with the data received here
    This is really simple stuff, but still very effective. It's easy to synch up both
    ends of the link. Even with really noisy receivers like the Linx LR series or
    RWS-434.
    The Ruff-Bot project works because it continuously sends the same data. It
    will definitely miss a great deal of packets, but with this particular project, it
    really is a moot point. It's also sending data at 9600 bps which is well above
    the TWS/RWS max data rate is, but it still gets enough packets through to
    do the job it was intended to do.
    -Bruce
    tech at rentron.com
    Jul 2006
    Default But schematic design is OK?
    Thanks for the responses guys. I think I will redo the code with the manchester encoding so I can make my projects much more complicated. I was wondering if I could still stick with the same schematic, though. And also, do you have any sample code to accomplish the manchester? Thanks!
    -Mike
    Jul 2006
    Default Oops...sorry about the last post
    Sorry Bruce, my browser freaked out for a second and I didn't scroll down to see the rest of your post. Thanks for the help!!
    -Mike
    skimask's Avatar
    skimask Guest
    Nothing wrong with your schematic. Same basic design I use. As far as manchester code...roll your own. You wouldn't like what I'm using, kludged up, works for me, but it's ugly.
    JDG
    I rarely use manchester, but here's a simple version you can run with a
    terminal program to see how it works. You can easily change it to work
    with serial comms between two PIC via RF.
    You still want to include a preamble & synch byte before each packet.
    The assembler routine is a slightly modified version of one done by Les
    Johnson a long time ago, and it's very fast.
    This version is for an 18F. Just make the rotate instruction change as shown
    to use it on a 12F or 16F part. You'll want to change banka to bank0 also.
    ; Compile with MPASMWIN
    X           VAR BYTE
    Y           VAR BYTE
    BitCount    VAR BYTE banka system ' Bank0 system so we don't need an underscore
    ByteIn      VAR BYTE banka system ' to access BASIC variables from assembler
    ByteOut     VAR BYTE banka system
    Manch       VAR WORD banka system ' Holds manchester encoded word
    Temp        VAR WORD banka system ' Temp var
    CRC         VAR BYTE system
    Enc_Dat     VAR WORD[6]           ' Holds 6 manchester encoded words
        GOTO Main   ' Jump over encode/decode routines
    ASM  ; Note: For 14-bit core just change Rlcf to Rlf
         ; Manchester encode routine
    _Encode
    	Movlw   8
    	Movwf   BitCount
    E_Repeat
    	Rlcf    ByteIn,F
    	Btfss   STATUS,C
    	Goto    BitClr
    BitSet
    	Rlcf    Manch,F
    	Rlcf    Manch+1,F
    	bcf     STATUS,C
    	Rlcf    Manch,F
    	Rlcf    Manch+1,F
    	Goto    E_Loop
    BitClr
    	Rlcf    Manch,F
    	Rlcf    Manch+1,F
    	bsf     STATUS,C
    	Rlcf    Manch,F
    	Rlcf    Manch+1,F
    E_Loop
    	Decfsz  BitCount,F
    	Goto    E_Repeat
        ; Manchester decode routine.
    _Decode
    	Movf    Manch+1,W
    	Movwf   Temp+1
    	Movf    Manch,W
    	Movwf   Temp
    	Movlw   8
    	Movwf   BitCount
    Repeat
    	Rlcf    Temp,F
    	Rlcf    Temp+1,F
    	Rlcf    ByteOut,F
    	Rlcf    Temp,F
    	Rlcf    Temp+1,F
    	Decfsz  BitCount,F
    	Goto    Repeat
        ' Manchester encode ASCII characters "A" to "F"
        Y = 0       ' Start array index pointer at 0
        FOR X = "A" to "F"
         ByteIn = X
         CALL Encode
         Enc_Dat[Y] = Manch
         HSEROUT ["Encoded ",X," = ",IBIN8 X," = ",IBIN16 Enc_Dat[Y],13,10]
         Y = Y + 1  ' Increment array index pointer
        NEXT X
        ' Decode & print results
        FOR Y = 0 to 5
         Manch = Enc_Dat[Y]
         CALL Decode
         HSEROUT ["Decoded ",IBIN16 Manch," = ",ByteOut,13,10]
        NEXT Y
        PAUSE 10000
        GOTO Main
    Here's the output;
    Encoded A = %01000001 = %0110010101010110
    Encoded B = %01000010 = %0110010101011001
    Encoded C = %01000011 = %0110010101011010
    Encoded D = %01000100 = %0110010101100101
    Encoded E = %01000101 = %0110010101100110
    Encoded F = %01000110 = %0110010101101001
    Decoded %0110010101010110 = A
    Decoded %0110010101011001 = B
    Decoded %0110010101011010 = C
    Decoded %0110010101100101 = D
    Decoded %0110010101100110 = E
    Decoded %0110010101101001 = F
    Manchester does have its advantages, but I rarely use it. A big factor is
    getting the receiver/transmitter in synch.
    Like in my previous post, I would definitely use a preamble followed by a
    synch character. That really makes a big difference.
    -Bruce
    tech at rentron.com
    skimask's Avatar
    skimask Guest
    I was doing some reading awhile back on these various modules using On/Off keying, FSK/ASK, whatever. I can see the modules working fine when only sending small data packets that only end up lasting a few milliseconds (with a good preamble of course). But, from what I've read, it seems that the data slicer will lose it's mind after that especially if the data has a lot of repeating 0's or 1's.
    Correct or wrong?
    JDG
    Long periods of 0's will cause problems.
    Short bursts of information like preamble,synch,address,data,checksum etc
    work just fine. The payload is delivered just after everything is stable and in
    synch. Even a few bytes of data with large numbers of 0's works, but you
    wouldn't want to stuff 50 words in there made up of all 0's.
    If you're transmitting long streams of serial data that can vary from all 0's
    to all 1's, then you might want to look into using manchester.
    Here's one example of how a simple remote control encoder works.
    http://www.linxtechnologies.com/docu...datastruct.pdf
    -Bruce
    tech at rentron.com
    Jul 2006
    Default WAIT(Synch)
    Bruce,
    I didn't read your first post carefully enough. In your receiver code you had the SERIN line say:
    SERIN2 D_IN,BAUD,[WAIT(Synch),ADD_IN1,DAT_IN1,ADD_IN2...]
    What does the WAIT(Synch) line do?
    I appreciate your answering, as this is probably a stupid question.
    Thanks!!
    -Mike
    It WAITs for the Synch byte. Look in your PBP manual under SERIN2 for the
    WAIT modifier. This forces the SERIN2 line to wait until this specific byte
    arrives before receiving the rest of the serial packet.
    -Bruce
    tech at rentron.com
    Jul 2006
    Default One last thing...
    Sorry about the late post, and thanks for the help guys! Now I am thinking about the possibility of using the PIC16F628A instead of the 16f84. Will I be able to use the same code and schematics (I think that the PIC16F628A has an internal oscillator; will that mean I can eliminate the external oscillator?)? Thanks for the help!!
    -Mike
    you can use the same schematic and probably the same code. But look at the the 16F628 Specs... it have an internal USART. More reliable than a software solution and produce a tighter code. HSERIN, HSEROUT that's it.
    About skipping the external OSC... it could work good or not. Usually for serial comm i prefer to use a crystal for a better stability upon the temperature variation. The internal OSC is still a RC circuit... But try it before at slow baudrate and it could work great.
  1. Replies: 67
    Last Post: - 8th December 2009, 03:27
  2. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 01:13
  3. RX - TX timming
    Last Post: - 12th February 2009, 01:06
  4. TX RX Buffer Question
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 14th January 2005, 02:49
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 15:55
