USB to RS232 adapter
Results 1 to 20 of 20
    Jan 2006
    Toronto
    Thanks Darrel. I have eliminated the LEDs all together because there is really no need for them. I was testing it by just using a terminal program on 2 computers so I never noticed the speed problem till now. How do I impliment the circular buffers you mentioned?
    Me and my big mouth.
    I wish I had time to work something up, but I've got too many things going on already.
    You might take a look at this post by Joe S.
    http://www.picbasic.co.uk/forum/showthread.php?p=28233
    He's got a buffer in there for serial RX. Should give you a start.
    But you really need to buffer both RX and TX.
    busy busy,
    Oct 2003
    Australia
    Hi Guys I've been working on the same - I can get a Half duplex data communication going but not full duplex (rs232-> usb and vice versa).
    This program seems to do the trick, but even with the pauses removed I still only achieve a stable data rate at 9600 when sending large text files.
    I'll try using the DT method (DT_int_18) interrupts and see if this speeds things up.
    Circular buffers? The mind boggles!
    Cheers
    i doubt it would be if you used the EUSART but may worth to try..
    PicMultiCalc gaves me...
    DEFINE HSER_SPBRG 225 ' 9600 Baud @ 48MHz, 0.0%
    SPBRGH = 4
    mixing INT_18 and asm would certainly have some great effect.
    USB is a Half-Duplex protocol. There's no way to have TRUE full-duplex. 2-wires, differential levels, can only do one thing at a time.
    However, with the proper buffers in place, you can make it seem like it's "FULL", in that you can send and receive at the same time from the USART. But it never truely will be Full-duplex for the USB.
    Oct 2003
    Australia
    Yeah your right,
    I guess what I should have said was this.
    I can transmit in only one direction usb->usart, or usart->usb, not in the same program. Never mind now. I'm confused... ;(
    Using Int_18 has def. sped things up!
    Now I can transfer from USB->Usart successfully at 57600 baud, however Usart->Usb still only good enough at 9600 when sending text file. (Sending single key strokes is fine both directions at any speed).
    I figure that the usart buffer needs to be increased as this is the bottle neck.
    Cheers
    I think you'll find that while from USB to USART works fine. It's massively buffered by the PC. If you were to send the same text file directly to a com port at 57600, it would take 1/3 as long to transmit.
    This is because the PIC waits untill the last buffer full of data is sent via HSEROUT, before allowing it to receive more from the USB. The PC does the buffering, instead of the PIC.
    And on the other side of it. This program is only sending 1 byte at a time to the USB. You can send up to 64. If it were buffered at the PIC, it could save incomming 232 data while it's busy sending to USB, then send a larger packet on the next time around. I think this would greatly improve the overall speed.
    Theoretically, you should be able to run quasi-full-duplex at 250kbaud, without any problems.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. USB to rs232 emulator
    By Pic2008 in forum USB
    Last Post: - 5th March 2010, 15:54
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  4. Bafo USB to serial adapter
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 29th July 2006, 18:48
  5. USB to Serial Adapter with 9.6v
    By serandre in forum Serial
    Last Post: - 10th May 2006, 20:16
