USB to RS232 adapter
Results 1 to 20 of 20
    At a quick glace, there's a couple problems. Maybe more, but haven't tested it yet.
    With the first USBIN, if there isn't any incoming data from USB, it just loops back to MainLoop. It never makes it to SERIN, unless it receives data from USB at the same time.
    You really should use HSERIN. The RS232 data may start while the program is sending or receiving USB data, in which case you would not be able to catch it with SERIN.
    Added: And the 100ms timeout on the SERIN will cause it to lose the USB connection, since it isn't servicing it anymore.
    Jan 2006
    Toronto
    Ok, I got it all working now. I took Darrel's advice and switched to using HSERIN and HSEROUT but added the use of hardware interrupts to capture the RS232 data.
    Here's the new code:
    DEFINE    OSC 48
    DEFINE    HSER_RCSTA   90h
    DEFINE    HSER_TXSTA   20h
    DEFINE    HSER_BAUD    9600
    DEFINE    HSER_CLROERR 1
    INCLUDE "modedefs.bas"
    Buffer    VAR BYTE[16]
    Cnt       VAR BYTE
    B0        VAR BYTE
    PIC_TX    VAR PORTC.6     ' Transmit Pin
    PIC_RX    VAR PORTC.7     ' Receive Pin
    LED1A     VAR PORTB.0     ' 2 Color LED #1
    LED1B     VAR PORTB.1
    LED2A     VAR PORTB.2     ' 2 Color LED #2
    LED2B     VAR PORTB.3
    ADCON1 = 15               ' Set all I/Os to Digital
    INTCON2.7 = 1             ' Disable PortB Pullups
    CMCON = 7                 ' Disable Comparators
    ' Interrupt Settings
    RCON.7 = 0                ' Disable Priority Interrupts, 1 to Enable
    ' Enable/Disable Interrupts
    INTCON.4 = 0              ' Disable INT0 (PORTB.0)
    INTCON3.3 = 0             ' Disable INT1 (PORTB.1)
    INTCON3.4 = 0             ' Disable INT2 (PORTB.2)
    INTCON.5 = 0              ' Disable TMR0 (Timmer 0)
    INTCON.6 = 1              ' Enable Peripheral Interrupts
    INTCON.7 = 1              ' Enable Global Interrupt Handler
    PIE1.4 = 0                ' Disable USART Transmit Interrupt
    PIE1.5 = 1                ' Enable USART Receive Interrupt
    PIE2.5 = 0                ' Disable USB Interrupt
    LOW LED1A                 ' Turn LED #1 Green
    HIGH LED1B
    LOW LED2A                 ' Turn LED #2 Off
    LOW LED2B
    PAUSE 500
    USBInit
    ON INTERRUPT GOTO Main_Interrupt_Handler
    ENABLE INTERRUPT
    ' Main Program Loop
    MainLoop:
        USBService            ' Must service USB regularly
        Cnt = 16
        USBIn 3, Buffer, Cnt, MainLoop
        HIGH LED2A
        PAUSE 25
        HSEROUT [STR Buffer\Cnt]
        LOW LED2A
        GOTO Mainloop
    ' Interrupt Handler
        DISABLE INTERRUPT     ' No Interrupts past this point
    Main_Interrupt_Handler:
        ' USART Transmit Interrupt
        IF PIR1.4 = 1 THEN
            PIR1.4 = 0
        ' USART Receive Interrupt
        IF PIR1.5 = 1 THEN
            HIGH LED2B
            PAUSE 25
            HSERIN [B0]
            Buffer[0] = B0
            Cnt = 1
    OutLoop:
            USBOut 3, Buffer, Cnt, OutLoop
            LOW LED2B
            PIR1.5 = 0
    IntDone:
        RESUME                ' Return to main program
        ENABLE INTERRUPT
    That was pretty quick!
    I've been playing with the program here and can say that the two PAUSE 25 statements, have to GO.
    Of course that messes up the LED's, but with the pauses in there, it only picks up every 7 or 8th character when sending continuous data.
    Without them, it works pretty good, but it's still a bit slow.
    Test data of about 1500 bytes takes nearly 3 times as long as it should. Around 1.2 sec.
    I think circular buffers would help speed it up, since it has to wait till it's finished sending the HSEROUT before in can receive more data from the USB. But I guess that depends on how fast you need it to be.
    Jan 2006
    Toronto
    Thanks Darrel. I have eliminated the LEDs all together because there is really no need for them. I was testing it by just using a terminal program on 2 computers so I never noticed the speed problem till now. How do I impliment the circular buffers you mentioned?
    Me and my big mouth.
    I wish I had time to work something up, but I've got too many things going on already.
    You might take a look at this post by Joe S.
    http://www.picbasic.co.uk/forum/showthread.php?p=28233
    He's got a buffer in there for serial RX. Should give you a start.
    But you really need to buffer both RX and TX.
    busy busy,
    Oct 2003
    Australia
    Hi Guys I've been working on the same - I can get a Half duplex data communication going but not full duplex (rs232-> usb and vice versa).
    This program seems to do the trick, but even with the pauses removed I still only achieve a stable data rate at 9600 when sending large text files.
    I'll try using the DT method (DT_int_18) interrupts and see if this speeds things up.
    Circular buffers? The mind boggles!
    Cheers
    i doubt it would be if you used the EUSART but may worth to try..
    PicMultiCalc gaves me...
    DEFINE HSER_SPBRG 225 ' 9600 Baud @ 48MHz, 0.0%
    SPBRGH = 4
    mixing INT_18 and asm would certainly have some great effect.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. USB to rs232 emulator
    By Pic2008 in forum USB
    Last Post: - 5th March 2010, 16:54
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. Bafo USB to serial adapter
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 29th July 2006, 19:48
  5. USB to Serial Adapter with 9.6v
    By serandre in forum Serial
    Last Post: - 10th May 2006, 21:16
