Serial LCD syntax help
Results 1 to 23 of 23
    Not another Sim issue? why i'm not surprised?
    BTW, i usually use a Serial communication between my PIC and my PC, OR if there's a LCD attached to the project i could use it and drop some data on. I prefer the serial communication.
    An ICD could be a nice option. PICKIT 2 have a debugger for a really few models listed bellow
    Quote Originally Posted by http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName =en027813
    PICkit 2 MPLAB 7.51 Support
    Debugging & Programming
    * PIC12F683
    * PIC16F684, 685, 687, 688, 689, 690
    * PIC16F883, 884, 886, 887
    * PIC16F913, 914, 916, 917, 946
    I never tried it, so can't comment how good it is.
    Mecanique ICD (comming with the MicroCode Studio PLUS version) works pretty nice even if it's a little bit slow. Example and tutorial bellow
    http://rentron.com/PicBasic/MCS_X3.htm
    O.K i did few test with the PICKIT 2 debugger in MPLAB... not bad but slow and there's no way to modify it's speed like the ICD-2.
    To use the debugger, you need to load the PGD and PGC pins with 2 4.7K pull-down resistors... unless it works erratic or simply do nothing. I fitted 2 smd resistor in it. Fixed forever
    OH and you must have MPLAB 7.52
    SWITZERLAND (french speaking)
    Okay.
    I'm going to try MPLABS again.
    I already tried, but MPLABS is quite complicated to setup (in my opinion).
    This is why I preferred anothe simulator....
    BTW, can you see variables too in this debugger?
    Roger
    Okay.
    Maybe not the variables created by PBP directly, but you can look at the .lst file, get the ram address from that, then pull up a 'watch' window and see them in action there, or since you've already got the ram address of your variable from the .lst file, you can pull up the 'file registers' window and watch everything going on in ram.
    Yes you can look Your variable and the hidden PBP one. You just need to select the right toolsuite and install the PBP plugin
  1. LCD serial backpacks
    By Archangel in forum Serial
    Last Post: - 30th December 2010, 05:51
  2. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Serial LCD
    Last Post: - 15th November 2007, 09:31
  5. Need help with LCD number display.
