unless you calibrate the internal OSC, it will never be accurate. AND EVEN IF you calibrate it, you'll need to hire someone to fine tune it when temperature shift, wind is going on the other side, when you loose weight etc etc etc.
I already said few times before... for serious serial comm (critical timing), use a crystal. Ceramic resonator are still nice.
