Serial LCD syntax help
Results 1 to 23 of 23
    SWITZERLAND (french speaking)
    Default was very quick
    Thanks, that was quick ;-)
    I'm gone a try this now!
    Roger
    Default Not yet...
    Well,
    I've still some trouble. Characters appears but nothing consitant or logical.
    I have attached both explanations I have about how to send commands to the display (in German "D" and English "E"). Don't be afraid, they're very short.
    The display is directly connected through a 1k resistor to the PIC.
    I've set the baudrate to 300 now; but still strange characters appear.
    I have also tried out all the 300bds and 2400bds modes described in the Compiler's manual without any success.
    Here's my code:
    ' Fuses
    @ DEVICE PIC16F88,INTRC_OSC_NOCLKOUT
    @ DEVICE PIC16F88,PROTECT_OFF
    @ DEVICE PIC16F88,WDT_OFF
    @ DEVICE PIC16F88,PWRT_ON
    @ DEVICE PIC16F88,MCLR_ON
    @ DEVICE PIC16F88,BOD_OFF
    @ DEVICE PIC16F88,LVP_OFF
    @ DEVICE PIC16F88,CPD_OFF
    @ DEVICE PIC16F88,DEBUG_OFF
    @ DEVICE PIC16F88,CCPMX_OFF
    ' Registers
    PORTB       = %00000000  'Drive all ports B low
    TRISB       = %00000000  'Segments - Set Inputs/Outputs on PORTBs (direction)
    OSCCON      = %01100000  'Internal RC set to 4MHz
    ANSEL       = %00000000  'Disable Analogue Inputs
    ADCON0      = %00000000  'A/D converter is OFF
    ' Circuitery
    'PORTB.0 = TX
    ' Init
    DEFINE SER2_BITS 8 'Set number of data bits for Serin2 and Serout2
    'DEFINE SER2_ODD 1 'Use odd parity instead of even parity
    Data_Out VAR PORTB.0
    ' Program
    pause 1000  'Stabilize the PIC (mybe not needed)
    serout2 data_out , 36081, [27,76,$0]
    Any idea what I'm doing wrong?
    Roger
    Mentor, Ohio
    Smile
    Hi Flotul,
    What is the baud rate of the Serial Module on the LCD? Most of the ones I have seen are either 2400 or 9600. With the internal clock at 4mhz the best you can hope for is 2400 because of the not so stable clock freq. I use a Seetron Serial LCD @2400 and it works fine. I have some other Serial LCD's that I am trying that I got from Wulfden.org but he has a different command structure that uses ? in fron of the command letter. I get data displayed but it's all running together. Always the time factor.
    Try putting a crystal or resonator on your PIC and see if theat doesn't help.
    HTH,
    BobK
  1. LCD serial backpacks
    By Archangel in forum Serial
    Last Post: - 30th December 2010, 05:51
  2. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Serial LCD
    Last Post: - 15th November 2007, 09:31
  5. Need help with LCD number display.
