Bits, Bytes Words and Arrays
+ Reply to Thread
Results 1 to 25 of 25
    Dec 2004
    USA
    Question words into byte array
    Found this interesting bit of ancient history. It covers all the options except the one I'm looking for. I need to put some words into a byte array.
    settings VAR byte[1]
    counter1.byte1 VAR settings[0]
    counter1.byte0 VAR settings[1]
    -does not appear to work
    Klaus
    6. How can I reference a WORD in a BYTE ARRAY?
    Let's say that you have a WORD located at bytes 3 and 4 of a BYTE array, and Byte 3 is the LowByte. You can use the EXT (external) modifier to assign it to a WORD variable.
    MyByteArray VAR BYTE[10]
    MyWord VAR WORD EXT
    @MyWord = _MyByteArray + 3
    Dec 2004
    USA
    Thanks Darrel,
    Your example will put the low byte into the array. How do I get the high byte in?
    MyWord.byte0 VAR MyByteArray[3]
    or
    MyWord.byte1 VAR MyByteArray[3]
    will work as well.
    I can read in either the high or low byte, but not both of them.
    It creates an Aliased WORD variable, inside the BYTE array.
    When you assign a value to the WORD variable, it puts both BYTEs in the array in a single operation.
    MyWord = $1234
    will make MyByteArray look like this
    [00, 00, 00, 34, 12, 00, 00, 00, 00, 00]
    HTH
    Dec 2004
    USA
    Thanks again Darrel. That's almost too slick to be true. When you start throwing around those "@" signs it becomes a little mystical for me.
    I will try it and let you know.
    Jun 2006
    Bangalore, India
    Thumbs up Thank You
    After searching the whole forum for an hour or so i stumbled upon this page.
    Finally i can dynamically access bits of a variable. This has really helped me a lot.
    Thank you Melanie .
    Isn't this information in the PicBasic Pro Compiler doc's... something like "Variables", "Aliases", "Arrays" and so forth...?
    Mike Tripoli
  1. LP Instant Interrupts Error
    Last Post: - 7th December 2009, 10:13
  2. how to store a very large amount of data
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 07:05
