Bits, Bytes Words and Arrays
+ Reply to Thread
Results 1 to 25 of 25
    Mar 2011
    Default Re: Bits, Bytes Words and Arrays
    Hello,
    I have more information.
    I started commenting all the lines between this code, resulting the same. MR value is 0.
    Next, I continued commenting all the lines outside this code. Result the same. MR value is 0.
    Finally, I decided to comment step by step my array variables.
    After 2 o 3 arrays commented I get MR=65535.
    I repeated this process commenting other variables randomly with the same result. After 2 o 3 steps MR=65535.
    My code is about 8k over a Pic16F877. Very fair but fits.
    My conclusion is PicBasicPro compiler needs more memory for variables than PicBasic.
    The weird is why the compiler gives no errors...
    Many thanks,
    Ricard.
    Feb 2007
    ok... I've built an 8x8x8 LED cube using 18F452, I have encountered a problem with my array
    each of the 512 leds as 1 bit assigned to it from leddata array
    0 = bottom corner
    511 = the top corner of the cube
    leddata VAR BYTE[64]
    litled VAR WORD
    litled = 511
    leddata.0(lilted) = 1
    the above 2 lines lights up an led half way down the cube (I think it would correspond to 255)
    but if I write this:
    leddata.0(511) = 1
    the correct LED lights up at the top corner of the cube
    Any ideas?
    You have an error in the variable litled.
    It appears as lilted.
    Feb 2007
    awww that was an autocorrect on here, not in my code
    changed litled to 'lit' still no change,
    I've changed my code now to address each led using X,Y,Z
    and it is working ok
    xl = 7
    zl = 7
    yl = 7
    GOSUB ledon
    ledon:
    ledonbyte = xl + (yl*8)
    ledtemp = leddata[ledonbyte]
    ledtemp.0(zl) = 1
    leddata[ledonbyte] = ledtemp
    I had a similar issue a couple of years (5) ago. Like you I found that indexing using a constant works but indexing using a variable doesn't (for bits beyond 255). And you, just like me back then, didn't bother to check the manual...
    7.6.4 Accessing Arrays as Multiple Variable-Types
    It is possible for a single array to be declared with multiple names and for each name to be assigned a different variable type. Note that offsets for BITs are limited to a maximum value of 255.
    So, I Think Melanies post where she indicates that using a WORD as the pointer for indexing bits in a BYTE Array really isn't correct.
    Here's my thread.
    Feb 2007
    Thanks Henik
    solved that one
    The other option is a bit of asm code.
    note the code would be slightly different for a pic18
  1. LP Instant Interrupts Error
    Last Post: - 7th December 2009, 10:13
  2. how to store a very large amount of data
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 07:05
Members who have read this thread : 4
