3-wire LCD interface?
Results 1 to 21 of 21
    Dec 2003
    Wichita KS
    Hello Folks,
    I will post the receiver and transmitter part of the 1 pin Xcvr.
    The principal lies upon the receivers timing, in connection with the transmitters timing. You only have two critical points to ponder.
    1. The initial Rcvr *must* be slower than the transmitter until it receives the start bit.
    2. The Rcver *must* be faster than the transmitter after receiving the start bit.
    After #2 starts or begins, you control your Baud rate by the transmitter, *NOT* the receiver, or both.
    I wanted the overhead of the transmitter to be almost zero. The receiver was a 16f648A, and its only job was to control the LCD, so instead of using a interupt (which you can), I left the receiver in a loop, waiting for data communication from the 12f675. When a full byte is received, the 648 checks to see if it is a LCD command byte or a LCD data byte. (x254) if it is a command byte, it tells the LCD to accept next byte as a command, and waits for the next byte.
    Dwayne
    It has been 100 percent reliable so far. When I get home, I will post the code.
    Ability to Fly:
    Pilots that are Flying:
    Jun 2006
    Bangalore, India
    Default code?
    Melanie could you please give me the code to interface your circuit?
    May 2007
    Republic Serbia
    Wink hi vlad
    Pa de si bre Vlad puno pozdrava od Tanga.
    Quote Originally Posted by shahidali55 View Post
    That was over 3 years ago...you know that right?
    And there is code around here...just needs a bit of searching...who knows, maybe you could even write code yourself!
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    That's a good idea - using a Hex D Flip-Flop. So basically when Q6 is low the LCD's disabled, (the diode sinks current from the 4k7) then Q6 swings high allowing the data line to re-enable the LCD after clocking in the bits you want.
    Last edited by T.Jackson; - 5th June 2007 at 17:11. Reason: 174 is certainly not a parallel shift register like I initally first thought
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Give him a break - writing code for this is a lot easier said than done.
    Jun 2006
    Bangalore, India
    Couldn't find anything using search.
    Jun 2006
    Bangalore, India
    I didn't know what PBP was before 3 years.
    I don't think any code in PBP was posted for 3 or 2 wire interface till now.
    I tried to understand the code given on http://www.rentron.com/Myke1.htm.
    But couldn't really understand the command sequence. I didn't really get how the RS and E lines of the LCD are being handled.
    That's the same book/code/idea I was talking about. I picked up that book back in '01 (give or take a few months). Basically you manually preload a shift register with all the data bits, then the rest of the control bits and the last thing to get 'tripped' is the Enable, all done by a shift register.
    Not a new idea by any stretch, but a handy one...
    Look at this thread:
    http://www.picbasic.co.uk/forum/showthread.php?t=4972
    HTH
    JS
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  3. LCD will not start
  4. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
  5. Replies: 6
    Last Post: - 10th June 2005, 08:31
