Why does the clock stop?
Results 1 to 9 of 9
Threaded View
  1. #7
    Hangover, Germany
    Angry
    Quote Originally Posted by Russ Kincaid
    So, why does it run on your test board and not on mine?
    And, I don't understand CIMCON = 7, it is a register so shouldn't it be
    CIMCON = %0001001 ? And what does that do?
    My circuit is this: except the switch only goes to ground since I enabled the internal pullups.
    Hmmm, I just noticed that my schematic is not up to date: the inputs are RB4 & RB5, the outputs are RB6 & RB7.
    1. I see no 0,1uF-ceramic-condensator near the VSS/VDD-pins.
    2. I see no bits to turn on the pull-ups inside your program.
    3. Read the part on the comperators and the CMCON-register in the manual, tell use what you're CIMCON-register is.
    4. Using RB4 ? You has disabled LVP in your fuses ?
    ...I'm dreaming of mr. eng4444 ! (he's back!!!! ;-) )
    Give us more informations, if you want to get some help. Just list your program here!
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. EM4095 Chip, get Clock and Data signals?
    By mindthomas in forum mel PIC BASIC Pro
    Last Post: - 19th August 2008, 06:27
  3. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 11:48
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. LCD Clock, Interrup
    By Patrick in forum mel PIC BASIC Pro
    Last Post: - 16th July 2006, 16:00
