Problem with manchester code for RF
Results 1 to 12 of 12
    Jul 2007
    Red face Problem with manchester code for RF
    Hi everybody,
    I want to use manchester encode for RF data communication. Coz I heard it will not affected by noises when using such modules. My RF module is 315MHz module its data sheet tells that its range 80m. But it works poperly for 2m for data transmission. Beyond that it works with large noise.
    please tell me weather it is advantageous or not.
    Every RF Module need a good Ground and a good Antenna! did you have near your RF Module other Transmitter ?
    RF Phone,RF Headsset....
    Regard Pesti
    Dec 2005
    Quote Originally Posted by Dhanushka View Post
    Hi everybody,
    Manchester encoding is not immune from noise but does have built-in error detection.
    You haven't indicated just which RF modules you are using but most of the low cost modules use OOK (On-Off Keying) and a superregenerative receiver. The range spec given is usually based on free air line-of-sight. Typical range indoors will be about 20-25% of that if you are using an efficient antenna on the receiving end.
    In the absence of a strong signal it is the nature of superregenerative receivers to output continuous noise.
    For small amounts of data, I prefer to use the NEC protocol which has a fairly long initial pulse to set the receiver AGC and then transmits two payload bytes with built-in error checking.
    I have posted example code for transmitting and receiving in the Code Examples forum http://www.picbasic.co.uk/forum/showthread.php?t=6261
    Jul 2007
    Default manchester encoding
    Hi dhouston and all,
    I'm using ASK RF module, which is similar to dhouston's "http://davehouston.net/modules.htm" list. its antenna 18cm long
    wire for both transmitter and receiver. No any other transmitter or some thing operate nearby.
    Thanks for your example thread, I'll try using that NEC protocol.
    Dhanushka
    The distance problem is most likely from the wrong antenna length.
    315 MHz requires a 22.619 cm antenna. 1/4 wave length. And yes, a couple of cm will make a very big difference.
    The 1/4 wave antenna needs to be worked against a ground plane.
    Dec 2005
    ASK and OOK are essentially the same. The noise issue is illustrated here...It's easy to use your PC soundcard as a storage oscilloscope to view the receiver output. See...As mackrackit has noted, something around 22-23cm antenna length will work best for 315MHz. The exact length is more critical for the transmitter than the receiver but cutting both to the appropriate length works best.
    dhouston, How can you say: Manchester encoding is not immune from noise but does have built-in error detection. What is the "built-in error detection"? This is news to me as I write software for Tire Pressure Monitoring equipment which uses Manchester coding. Please explain.....
    Dec 2005
    If you don't see a change of state at the middle of a bit period, you've detected an error which is usually the result of noise if you are using it over a wireless link or a collision if you're using it over a wired link (e.g. 802.3, X-10). See the last paragraph at http://www.wildpackets.com/support/c...ignal_encoding.
  1. My first DT_INT code has a problem.....
    By E Kizer in forum mel PIC BASIC Pro
    Last Post: - 13th April 2009, 13:37
  2. Weird code problem
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 16th March 2009, 11:16
  3. Making Program Code Space your playground...
  4. Help with serin, serout, Manchester encoding
    Last Post: - 5th April 2007, 13:31
  5. Code problem
    Last Post: - 20th May 2006, 04:43
