send incomming msg (SMS) to VB
Results 1 to 20 of 20
    Sep 2003
    INDIA
    i have a SIMCOM Modem and I give a command AT&W which writes my current setting to the modem. Hope it works and helps.
    Well I am looking for some help in rx SMS using VB6. I have successfully rx the SMS using a PIC Micro and PBP. But don't know how to Rx it in VB.
    I understood the CMGR command but I don't know How I can skip a set of 51 character to escape the SMS details and copy just the message.
    Any Help ?
    Thanks in advance.
    johor,Malaysia
    hello
    charudatt
    i use this code for read the msg and serperate the msg...
    Private Sub Command1_Click()
    Dim buffer$
    DIM newMsg As String, MSG As String
    MSComm1.Output = "AT+CMGF=1" + Chr(13)
    Do
    DoEvents
    buffer$ = buffer$ & MSComm1.Input
    Loop Until InStr(buffer$, "OK")
    Text1.Text = Text1.Text & vbCr & buffer$
    buffer$ = ""
    MSComm1.Output = "AT+CMGR=1" + Chr(13)
    Do
    DoEvents
    Text1.Text = Text2.Text & vbCr & buffer$
    Text2.Text = buffer$
    buffer$ = ""
    newMsg = Text2.Text
    newMsg = Right(newMsg, Len(newMsg) - 51) 'SKIP 51 character
    MSG = Left(newMsg, 100) 'NO 100 DEPEND YOUR MSG LENGTH,IF DONT KNOW U CAN PUT MORE THAN 100
    newMsg = newMsg & "MESSAGE =" & MSG & vbCrLf
    MSComm1.PortOpen = False
    End Sub
    Private Sub Form_Load()
    MSComm1.CommPort = 1
    MSComm1.Settings = "57600,n,8,1"
    MSComm1.PortOpen = True
    MSComm1.Handshaking = comNone
    End Sub
    i hope help u abit.
    but i still problem for read incomming msg.. i still study now
    Sep 2003
    INDIA
    Default Thank you
    Thank you. But my idea is to read a incoming SMS using VB. This includes the following steps.
    (from cell phone): +CMTI: "ME",27
    (from computer): at+cmgr=27
    (from cell phone): +CMGR: "REC UNREAD","+15551234567","John Doe","05/10/18,23:21:45-20"
    Hello World
    This is simple using PIC BASIC Pro but I am not sure how to do this in VB6
    OK step one has definate characters to trap as I am going to keep my SMS's below 10
    Step 2 Is simple as I can just issue a command using VB.
    Step 3 is a bit challengeing as I am interested in only "Hello World"
    Any help. Are there any free ActiveX/OCX for receiving SMS for VB6
    regards
    Charudatt
    an after thought : should i be trapping a carriage return as the EOM (End Of Message) marker ?
    johor,Malaysia
    hello
    charudatt
    u say simple using PIC BASIC Pro for read incomming msg.
    can u share it..
    i want send and read incomming msg.. using pic
    Sep 2003
    INDIA
    OK I shall share it. Give me a day, shall format the text and share it with you. Right now its just small routines.
    regards
    Charudatt
    Sep 2003
    INDIA
    Default Sms Relay Control
    Hi , Hello,
    I have shared my SMS relay control code with all in the Code Example section.
    http://www.picbasic.co.uk/forum/show...9977#post19977
    regards
    johor,Malaysia
    Hi, hello..
    thankQ
    last night i success read sms using Vb..
    u want the code..
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. Please send me a SMS program
    By hjcool in forum GSM
    Last Post: - 17th June 2009, 11:33
  3. how to send and receive sms using vb?
    By shyhigh2002 in forum Off Topic
    Last Post: - 1st April 2009, 10:18
  4. Replies: 0
    Last Post: - 1st September 2008, 08:03
  5. sms send sht11 pic16f876 nokia 6210
    By elektoro2009 in forum GSM
    Last Post: - 9th June 2008, 09:57
