Instant Interrupts - Revisited
Results 1 to 40 of 773
    Aug 2010
    Chiang Mai University, Thailand
    Default Re: Instant Interrupts - Revisited
    Quote Originally Posted by Charlie View Post
    My comment, and Darrel's comment both said the same thing - it is bad form to put a bunch of code in the interrupt routine. Using a GOSUB essentially puts the bulk of your code inside the routine at compile time.
    Thanks, your post cleared it up nicely for me. New strategy now as it is a complex program with dozens of subroutines all invoked via a command from the serial port. As I mentioned, most of my interrupt handler experience has been with large scale mini-computers with realtime OSes and interrupt reentry was the norm. See now the pic architecture & picbasic is limited but still doable with the flags mentioned. That code snippet was just one of dozens of similar subroutines.
    Thanks for the feedback.
    Sep 2006
    Venezuela - Caracas
    Darrel, exist in DTS RTTC INT ??
    i use pic 18F26J50 ..... i need control rtc interrupt
    INT_Handler RX_??, _Relogio, PBP, yes
    @ INT_ENABLE ??_INT ; enable external (RTTC INT) interrupts
    ..: Don't worry, be happy :..
    Sep 2006
    Venezuela - Caracas
    RTTC is correct Darrel ?
    '*  Name    : DT_INTS-18.bas                                    *
    '*  Author  : Darrel Taylor                                     *
    '*  Notice  : Copyright (c) 2003                                *
    '*  Version : 3.3    MAR 24, 2008                               *
    '*  Date    : JUL 11, 2006                                      *
    '*  Versions:                                                   *
    '*   3.3  : MAR 24, 2008                                        *
    '*           Corrects an initialization problem affecting the   *
    '*           first pass if CLEAR is not used                    *
    '*   3.2  : Aug 26, 2007                                        *
    '*           Update for PBP 2.50 using LONG's with PBPL         *
    '*           Added many new INT sources                         *
    '*   3.1  : JUL 18, 2006                                        *
    '*           Modified to handle smaller BANKA in the newer chips*
    DISABLE DEBUG
    DEFINE  INTHAND       INT_ENTRY_H  ' Context saving for High Priority Ints
    DEFINE  INTLHAND      INT_ENTRY_L  ' Context saving for Low Priority Ints
    wsave       var byte  BANKA  SYSTEM   ' location for WREG
    ssave       var byte  BANK0  SYSTEM   ' location for STATUS register
    bsave       var byte  BANK0  SYSTEM   ' location for BSR register
    psaveUH     VAR BYTE  BANK0  SYSTEM   ' PCLATU Hi Pri.
    psaveUL     VAR BYTE  BANK0  SYSTEM   '        Lo Pri.
    psaveH      VAR BYTE  BANK0  SYSTEM   ' PCLATH Hi Pri.
    psaveL      VAR BYTE  BANK0  SYSTEM   '        Lo Pri.
    fsave0H     var WORD  BANK0  SYSTEM   ' locations for FSR registers
    fsave1H     var WORD  BANK0  SYSTEM
    fsave2H     var WORD  BANK0  SYSTEM
    fsave0L     var WORD  BANK0  SYSTEM   ' low priority FSR locations
    fsave1L     var WORD  BANK0  SYSTEM
    fsave2L     var WORD  BANK0  SYSTEM
    RetAddrH    VAR BYTE[3]  BANKA  SYSTEM  ' 21-bit return address Hi Pri.
    RetAddrL    VAR BYTE[3]  BANKA  SYSTEM  '                       Lo Pri.
    INT_Flags   VAR BYTE  BANKA  SYSTEM
      Serviced_H  VAR INT_Flags.0
      Serviced_L  VAR INT_Flags.1
      InHPint     VAR INT_Flags.2
      NoPriority  VAR INT_Flags.3
    INT_Flags = 0
    goto  OVER_DT_INTS_18
    ;____ Check for PBPL (PBP ver. 2.50 and above only)__________________________
    PBPLongs_Used = 0
      if (R1 - R0 == 4)
    PBPLongs_Used = 1
    ;    messg PBPL Used = 1
      nolist
    ;____ DEFINE available interrupt sources_____________________________________
      #define INT_INT   INTCON, INT0IF  ;-- INT External, 16F compatible
      #define INT0_INT  INTCON, INT0IF  ;-- INT0 External
      #define INT1_INT  INTCON3,INT1IF  ;-- INT1 External
      #define INT2_INT  INTCON3,INT2IF  ;-- INT2 External
      #define INT3_INT  INTCON3,INT3IF  ;-- INT3 External
      #define RBC_INT   INTCON, RBIF    ;-- RB Port Change
      #define TMR0_INT  INTCON, TMR0IF  ;-- TMR0 Overflow  18F
      #define TMR1_INT  PIR1, TMR1IF    ;-- TMR1 Overflow
      #define TMR2_INT  PIR1, TMR2IF    ;-- TMR2 to PR2 Match
      #define TMR3_INT  PIR2, TMR3IF    ;-- TMR3 Overflow
      #define TMR4_INT  PIR3, TMR4IF    ;-- TMR4 Overflow
      #define TX_INT    PIR1, TXIF      ;-- USART Transmit
      #define TX1_INT   PIR1, TX1IF     ;-- USART1 Transmit
      #define TX2_INT   PIR3, TX2IF     ;-- USART2 Transmit
      #define RX_INT    PIR1, RCIF      ;-- USART Receive
      #define RX1_INT   PIR1, RC1IF     ;-- USART1 Receive
      #define RX2_INT   PIR3, RC2IF     ;-- USART2 Receive
      #define CMP_INT   PIR2, CMIF      ;-- Comparator
      #define EE_INT    PIR2, EEIF      ;-- EEPROM/FLASH Write Operation
      #define BUS_INT   PIR2, BCLIF     ;-- Bus Collision
      #define LVD_INT   PIR2, LVDIF     ;-- Low Voltage Detect
      #define HLVD_INT  PIR2, HLVDIF    ;-- High/Low Voltage Detect
      #define PSP_INT   PIR1, PSPIF     ;-- Parallel Slave Port Read/Write
      #define AD_INT    PIR1, ADIF      ;-- A/D Converter
      #define SSP_INT   PIR1, SSPIF     ;-- Master Synchronous Serial Port
      #define CCP1_INT  PIR1, CCP1IF    ;-- CCP1
      #define CCP2_INT  PIR2, CCP2IF    ;-- CCP2
      #define CCP3_INT  PIR3, CCP3IF    ;-- CCP3
      #define CCP4_INT  PIR3, CCP4IF    ;-- CCP4
      #define CCP5_INT  PIR3, CCP5IF    ;-- CCP5
      #define OSC_INT   PIR2, OSCFIF    ;-- Oscillator Fail
    ; -- Added for ver. 3.3 --
      #define RTTCC_INT PIR3, RTCCIF    ;-- RTTC
    ; -- Added for ver. 3.2 --
      #define SPP_INT   PIR1, SPPIF     ;-- Streaming Parallel Port Read/Write
      #define BUS1_INT  PIR2, BCL1IF    ;-- Bus 1 Collision
      #define BUS2_INT  PIR3, BCL2IF    ;-- Bus 2 Collision
      #define ECCP1_INT PIR2, ECCP1IF   ;-- ECCP1
      #define LCD_INT   PIR3, LCDIF     ;-- LCD Driver
      #define PMP_INT   PIR1, PMPIF     ;-- Parallel Master Port
      #define SSP1_INT  PIR1, SSP1IF    ;-- Synchronous Serial Port 1
      #define SSP2_INT  PIR3, SSP2IF    ;-- Synchronous Serial Port 2
      #define TMR5_INT  PIR3, TMR5IF    ;-- Timer 5
      #define PT_INT    PIR3, PTIF      ;-- PWM Time Base
      #define IC1IF_INT  PIR3, IC1IF    ;-- Motion Feedback
      #define IC2QEIF_INT  PIR3, IC2QEIF  ;-- Motion Feedback
      #define IC3DRIF_INT  PIR3, IC3DRIF  ;-- Motion Feedback
    ;_____ Comparators __________________________________________________________
      #define CMP0_INT  PIR1, CMP0IF    ;-- Comparator 0 - 1230/1330 only
    CMPIFREG = PIR2                     ;-- Comparator 1
    CMPIEREG = PIE2
    CMPIPREG = IPR2
        ifdef C1IF                      ;     18F24K20  18F25K20  18F26K20
    CM1IFBIT = C1IF                     ;     18F44K20  18F45K20  18F46K20
        ifdef CM1IF
    CM1IFBIT = CM1IF                    ;     several J PICs
        ifdef CMP1IF
    CMPIFREG = PIR1                     ;     1230/1330 only
    CM1IFBIT = CMP1IF
    CMPIEREG = PIE1
    CMPIPREG = IPR1
        ifdef CM1IFBIT
           #define CMP1_INT  CMPIFREG, CM1IFBIT
        ifdef C2IF                      ;-- Comparator 2
    CM2IFBIT = C2IF                     ;     18F24K20  18F25K20  18F26K20
        endif                           ;     18F44K20  18F45K20  18F46K20
        ifdef CM2IF
    CM2IFBIT = CM2IF                    ;     several J PICs
        ifdef CMP2IF
    CM2IFBIT = CMP2IF                   ;     1230/1330 only
        ifdef CM2IFBIT
          #define CMP2_INT  CMPIFREG, CM2IFBIT
    ;_____ USB Module ___________________________________________________________
      #define USB_INT       PIR2, USBIF   ;-- USB Interrupt (funnel)
      #define USB_ACTV_INT  UIR,  ACTVIF  ;-- Bus Activity Detect
      #define USB_ERR_INT   UIR,  UERRIF  ;-- USB Error Condition INT (funnel)
      #define USB_RST_INT   UIR,  URSTIF  ;-- USB Reset
      #define USB_IDLE_INT  UIR,  IDLEIF  ;-- Idle Detect
      #define USB_STALL_INT UIR,  STALLIF ;-- A STALL Handshake
      #define USB_TRN_INT   UIR,  TRNIF   ;-- Transaction Complete
      #define USB_SOF_INT   UIR,  SOFIF   ;-- START-OF-FRAME Token
    ; -- USB Error Flags --
      #define USB_BTO_INT   UEIR, BTOEF   ;-- Bus Turnaround Time-out Error
      #define USB_BTS_INT   UEIR, BTSEF   ;-- Bit Stuff Error
      #define USB_CRC16_INT UEIR, CRC16EF ;-- CRC16 Failure
      #define USB_CRC5_INT  UEIR, CRC5EF  ;-- CRC5 Host Error
      #define USB_DFN8_INT  UEIR, DFN8EF  ;-- Data Field Size Error
      #define USB_PID_INT   UEIR, PIDEF   ;-- PID Check Failure
    ;_____ Ethernet Module ______________________________________________________
      #define ETH_INT       PIR2, ETHIF   ;-- Ethernet Module
      #define ETH_DMA_INT    EIR, DMAIF   ;-- DMA Interrupt
      #define ETH_LINK_INT   EIR, LINKIF  ;-- Link Status Change
      #define ETH_PKT_INT    EIR, PKTIF   ;-- Receive Packet Pending
      #define ETH_RXER_INT   EIR, RXERIF  ;-- Receive Error
      #define ETH_TXER_INT   EIR, TXERIF  ;-- Transmit Error
      #define ETH_TX_INT     EIR, TXIF    ;-- Transmit
    ;_____ CAN Module ___________________________________________________________
      #define CAN_ERR_INT    PIR3, ERRIF    ;-- CAN bus Error
      #define CAN_IRX_INT    PIR3, IRXIF    ;-- Invalid Received Message
      #define CAN_RXB0_INT   PIR3, RXB0IF   ;-* Receive Buffer 0      Mode 0
      #define CAN_FIFOWM_INT PIR3, FIFOWMIF ;-- FIFO Watermark        Mode 1, 2
      #define CAN_RXB1_INT   PIR3, RXB1IF   ;-* Receive Buffer 1      Mode 0
      #define CAN_RXBn_INT   PIR3, RXBnIF   ;-- Any Receive Buffer    Mode 1, 2
      #define CAN_TXB0_INT   PIR3, TXB0IF   ;-- Transmit Buffer 0
      #define CAN_TXB1_INT   PIR3, TXB1IF   ;-- Transmit Buffer 1
      #define CAN_TXB2_INT   PIR3, TXB2IF   ;-* Transmit Buffer 2     Mode 0
      #define CAN_TXBn_INT   PIR3, TXBnIF   ;-- Any Transmit Buffer   Mode 1, 2
      #define CAN_WAKE_INT   PIR3, WAKIF    ;-- CAN bus Activity Wake-up
    asm
    ; -- macro --
    INT_Source  macro  IFR, IFB, IER, IEB, IPR, IPB
        if (IflagReg == IFR) && (IflagBit == IFB)
      list
    INT_Flag_Reg = IFR
    INT_Flag_Bit = IFB
    INT_Enable_Reg = IER
    INT_Enable_Bit = IEB
    INT_Priority_Reg = IPR
    INT_Priority_Bit = IPB
    Found = 1
      nolist
    endasm
    asm
    ;____________________________________________________________________________
    GetIntInfo  macro  IflagReg, IflagBit
      nolist
    INT_Flag_Reg = -1
    INT_Flag_Bit = -1
    INT_Enable_Reg = -1
    INT_Enable_Bit = -1
      ifdef  IPR1
    INT_Priority_Reg = -1
    INT_Priority_Bit = -1
    Found = 0
      ifdef INT0IF  ;----{ INT0 External Interrupt }----------[INTCON, INT0IF]---
          INT_Source  INTCON,INT0IF, INTCON,INT0IE, -1, -1
      ifdef INT1IF  ;----{ INT1 External Interrupt }---------[INTCON3, INT1IF]---
          INT_Source  INTCON3,INT1IF, INTCON3,INT1IE, INTCON3,INT1IP
      ifdef INT2IF  ;----{ INT2 External Interrupt }---------[INTCON3, INT2IF]---
          INT_Source  INTCON3,INT2IF, INTCON3,INT2IE, INTCON3,INT2IP
      ifdef INT3IF  ;----{ INT3 External Interrupt }---------[INTCON3, INT3IF]---
          INT_Source  INTCON3,INT3IF, INTCON3,INT3IE, INTCON2,INT3IP
      ifdef RBIF    ;----{ RB Port Change Interrupt }-----------[INTCON, RBIF]---
          INT_Source  INTCON,RBIF, INTCON, RBIE,INTCON2,RBIP
      ifdef TMR0IF  ;----{ TMR0 Overflow Interrupt }----------[INTCON, TMR0IF]---
          INT_Source  INTCON,TMR0IF, INTCON,TMR0IE, INTCON2,TMR0IP
      ifdef TMR1IF  ;----{ TMR1 Overflow Interrupt }------------[PIR1, TMR1IF]---
          INT_Source  PIR1,TMR1IF, PIE1,TMR1IE, IPR1,TMR1IP
      ifdef TMR2IF  ;----{ TMR2 to PR2 Match Interrupt }--------[PIR1, TMR2IF]---
          INT_Source  PIR1,TMR2IF, PIE1,TMR2IE, IPR1,TMR2IP
      ifdef TMR3IF  ;----{ TMR3 Overflow Interrupt }------------[PIR2, TMR3IF]---
          INT_Source  PIR2,TMR3IF, PIE2,TMR3IE, IPR2,TMR3IP
      ifdef TMR4IF  ;----{ TMR4 Overflow Interrupt }------------[PIR3, TMR4IF]---
          INT_Source  PIR3,TMR4IF, PIE3,TMR4IE, IPR3,TMR4IP
      ifndef TX1IF  ;----{ USART Transmit Interrupt }-------------[PIR1, TXIF]---
          ifdef TXIF
              INT_Source  PIR1,TXIF, PIE1,TXIE, IPR1,TXIP
      ifdef TX1IF   ;----{ USART1 Transmit Interrupt }-----------[PIR1, TX1IF]---
          INT_Source  PIR1,TX1IF, PIE1,TX1IE, IPR1,TX1IP
      ifdef TX2IF   ;----{ USART2 Transmit Interrupt }-----------[PIR3, TX2IF]---
          INT_Source  PIR3,TX2IF, PIE3,TX2IE, IPR3,TX2IP
      ifndef RC1IF  ;----{ USART Receive Interrupt }---------------[PIR1 RCIF]---
        ifdef RCIF
            INT_Source  PIR1,RCIF, PIE1,RCIE, IPR1,RCIP
      ifdef RC1IF   ;----{ USART1 Receive Interrupt }------------[PIR1, RC1IF]---
          INT_Source  PIR1,RC1IF, PIE1,RC1IE, IPR1,RC1IP
      ifdef RC2IF   ;----{ USART2 Receive Interrupt }------------[PIR3, RC2IF]---
          INT_Source  PIR3,RC2IF, PIE3,RC2IE, IPR3,RC2IP
      ifdef CMIF    ;----{ Comparator Interrupt }-----------------[PIR2, CMIF]---
          INT_Source  PIR2,CMIF, PIE2,CMIE, IPR2,CMIP
      ifdef EEIF    ;----{ EEPROM/FLASH Write Operation Interrupt [PIR2, EEIF]---
          INT_Source  PIR2,EEIF, PIE2,EEIE, IPR2,EEIP
      ifdef BCLIF   ;----{ Bus Collision Interrupt }-------------[PIR2, BCLIF]---
          INT_Source  PIR2,BCLIF, PIE2,BCLIE, IPR2,BCLIP
      ifdef LVDIF   ;----{ Low Voltage Detect Interrupt }--------[PIR2, LVDIF]---
          INT_Source  PIR2,LVDIF, PIE2,LVDIE, IPR2,LVDIP
      ifdef HLVDIF  ;----{ High/Low Voltage Detect Interrupt }--[PIR2, HLVDIF]---
          INT_Source  PIR2,HLVDIF, PIE2,HLVDIE, IPR2,HLVDIP
      ifdef PSPIF   ;----{ Parallel Slave Port Interrupt }-------[PIR1, PSPIF]---
          INT_Source  PIR1,PSPIF, PIE1,PSPIE, IPR1,PSPIP
      ifdef ADIF    ;----{ A/D Converter Interrupt }--------------[PIR1, ADIF]---
          INT_Source  PIR1,ADIF, PIE1,ADIE, IPR1,ADIP
      ifdef SSPIF   ;----{ Synchronous Serial Port Interrupt }---[PIR1, SSPIF]---
          INT_Source  PIR1,SSPIF, PIE1,SSPIE, IPR1,SSPIP
      ifdef CCP1IF  ;----{ CCP1 Interrupt }---------------------[PIR1, CCP1IF]---
          INT_Source  PIR1,CCP1IF, PIE1,CCP1IE, IPR1,CCP1IP
      ifdef CCP2IF  ;----{ CCP2 Interrupt Flag }----------------[PIR2, CCP2IF]---
          INT_Source  PIR2,CCP2IF, PIE2,CCP2IE, IPR2,CCP2IP
      ifdef CCP3IF  ;----{ CCP3 Interrupt Flag }----------------[PIR3, CCP3IF]---
          INT_Source  PIR3,CCP3IF, PIE3,CCP3IE, IPR3,CCP3IP
      ifdef CCP4IF  ;----{ CCP4 Interrupt Flag }----------------[PIR3, CCP4IF]---
          INT_Source  PIR3,CCP4IF, PIE3,CCP4IE, IPR3,CCP4IP
      ifdef CCP5IF  ;----{ CCP5 Interrupt Flag }----------------[PIR3, CCP5IF]---
          INT_Source  PIR3,CCP5IF, PIE3,CCP5IE, IPR3,CCP5IP
      ifdef OSCFIF  ;----{ Osc Fail  Interrupt Flag }-----------[PIR2, OSCFIF]---
          INT_Source  PIR2,OSCFIF, PIE2,OSCFIE, IPR2,OSCFIP
    endasm
    asm
      ifdef RTCCIF  ;----{ RTTC }-------------------------------[PIR3, RTCCIF]---
          INT_Source  PIR3,RTCCIF, PIE3,RTCCIE, IPR3, RTTCIP
    endasm
    asm
      ifdef SPPIF   ;----{ Streaming Parallel Port Read/Write }--[PIR1, SPPIF]---
          INT_Source  PIR1,SPPIF, PIE1,SPPIE, IPR1,SPPIP
      ifdef BCL1IF  ;----{ Bus 1 Collision }--------------------[PIR2, BCL1IF]---
          INT_Source  BUS1_INT, PIE2,BCL1IE, IPR2,BCL1IP
      ifdef BCL2IF  ;----{ Bus 2 Collision }--------------------[PIR3, BCL2IF]---
          INT_Source  BUS2_INT, PIE3,BCL2IE, IPR3,BCL2IP
      ifdef CMP0IF  ;----{ Comparator 0 }-----------------------[PIR1, CMP0IF]---
          INT_Source  CMP0_INT, PIE1,CMP0IE, IPR1,CMP0IP
      ifdef CM1IFBIT  ;--{ Comparator 1 }-----------------------------[varies]---
          INT_Source  CMP1_INT, CMPIEREG,CM1IFBIT, CMPIPREG,CM1IFBIT
      ifdef CM2IFBIT  ;--{ Comparator 2 }-----------------------------[varies]---
          INT_Source  CMP2_INT, CMPIEREG,CM2IFBIT, CMPIPREG,CM2IFBIT
      ifdef ECCP1IF  ;---{ ECCP1 }-----------------------------[PIR2, ECCP1IF]---
          INT_Source  ECCP1_INT, PIE2,ECCP1IE, IPR2,ECCP1IP
      ifdef LCDIF   ;----{ LCD Driver }--------------------------[PIR3, LCDIF]---
          INT_Source  LCD_INT, PIE3,LCDIE, IPR3,LCDIP
      ifdef PMPIF   ;----{ Parallel Master Port }----------------[PIR1, PMPIF]---
          INT_Source  PMP_INT, PIE1,PMPIE, IPR1,PMPIP
      ifdef SSP1IF  ;----{ Synchronous Serial Port 1 }----------[PIR1, SSP1IF]---
          INT_Source  SSP1_INT, PIE1,SSP1IE, IPR1,SSP1IP
      ifdef SSP2IF  ;----{ Synchronous Serial Port 2 }----------[PIR3, SSP2IF]---
          INT_Source  SSP2_INT, PIE3,SSP2IE, IPR3,SSP2IP
      ifdef TMR5IF  ;----{ Timer 5 }----------------------------[PIR3, TMR5IF]---
          INT_Source  TMR5_INT, PIE3,TMR5IE, IPR3,TMR5IP
      ifdef PTIF    ;----{ PWM Time Base }------------------------[PIR3, PTIF]---
          INT_Source  PT_INT, PIE3,PTIE, IPR3,PTIP
      ifdef IC1IF   ;----{ Motion Feedback IC1}------------------[PIR3, IC1IF]---
          INT_Source  IC1IF_INT, PIE3,IC1IE, IPR3,IC1IP
      ifdef IC2QEIF ;----{ Motion Feedback IC2QE}--------------[PIR3, IC2QEIF]---
          INT_Source  IC2QEIF_INT, PIE3,IC2QEIE, IPR3,IC2QEIP
      ifdef IC3DRIF ;----{ Motion Feedback IC3DR}--------------[PIR3, IC3DRIF]---
          INT_Source  IC3DRIF_INT, PIE3,IC3DRIE, IPR3,IC3DRIP
    ;  ifdef   ;----{  }-------------[, ]---
    ;      INT_Source  , ,, ,
    ;  endif
    endasm
    asm  ; -- USB sources --
      ifdef USBIF   ;----{ USB  Interrupt funnel }---------------[PIR2, USBIF]---
          INT_Source  PIR2,USBIF, PIE2,USBIE, IPR2,USBIP
                    ;----{ Bus Activity Detect }-----------------[UIR, ACTVIF]---
          INT_Source  USB_ACTV_INT, UIE,ACTVIE, _NoPriority
                    ;----{ USB Reset }---------------------------[UIR, URSTIF]---
          INT_Source  USB_RST_INT, UIE,URSTIE, _NoPriority
                    ;----{ Idle Detect }-------------------------[UIR, IDLEIF]---
          INT_Source  USB_IDLE_INT, UIE,IDLEIE, _NoPriority
                    ;----{ A STALL Handshake }------------------[UIR, STALLIF]---
          INT_Source  USB_STALL_INT, UIE,STALLIE, _NoPriority
                    ;----{ Transaction Complete }-----------------[UIR, TRNIF]---
          INT_Source  USB_TRN_INT, UIE,TRNIE, _NoPriority
                    ;----{ START-OF-FRAME Token }-----------------[UIR, SOFIF]---
          INT_Source  USB_SOF_INT, UIE,SOFIE, _NoPriority
                    ;----{ USB Error Condition Int funnel }------[UIR, UERRIF]---
          INT_Source  USB_ERR_INT, UIE,UERRIE, _NoPriority
                    ;----{ Bus Turnaround Time-out Error }-------[UEIR, BTOEF]---
          INT_Source  USB_BTO_INT, UEIE,BTOEE, _NoPriority
                    ;----{ Bit Stuff Error }---------------------[UEIR, BTSEF]---
          INT_Source  USB_BTS_INT, UEIE,BTSEE, _NoPriority
                    ;--{ CRC16 Failure }-----------------------[UEIR, CRC16EF]---
          INT_Source  USB_CRC16_INT, UEIE,CRC16EE, _NoPriority
                    ;---{ CRC5 Host Error }---------------------[UEIR, CRC5EF]---
          INT_Source  USB_CRC5_INT, UEIE,CRC5EE, _NoPriority
                    ;---{ Data Field Size Error }---------------[UEIR, DFN8EF]---
          INT_Source  USB_DFN8_INT, UEIE,DFN8EE, _NoPriority
                    ;----{ PID Check Failure }-------------------[UEIR, PIDEF]---
          INT_Source  USB_PID_INT, UEIE,PIDEE, _NoPriority
    endasm
    asm  ; -- Ethernet sources --
      ifdef ETHIF  ;----{ Ethernet Module }----------------------[PIR2, ETHIF]---
          INT_Source  ETH_INT, PIE2,ETHIE, IPR2,ETHIP
                   ;----{ DMA Interrupt }-------------------------[EIR, DMAIF]---
          INT_Source  ETH_DMA_INT, EIE,DMAIE, _NoPriority
                   ;----{ Link Status Change }-------------------[EIR, LINKIF]---
          INT_Source  ETH_LINK_INT, EIE,LINKIE, _NoPriority
                   ;----{ Receive Packet Pending }----------------[EIR, PKTIF]---
          INT_Source  ETH_PKT_INT, EIE,PKTIE, _NoPriority
                   ;----{ Receive Error }------------------------[EIR, RXERIF]---
          INT_Source  ETH_RXER_INT, EIE,RXERIE, _NoPriority
                   ;----{ Transmit Error }-----------------------[EIR, TXERIF]---
          INT_Source  ETH_TXER_INT, EIE,TXERIE, _NoPriority
                   ;----{ Transmit }-------------------------------[EIR, TXIF]---
          INT_Source  ETH_TX_INT, EIE,TXIE, _NoPriority
    endasm
    asm  ; -- CAN Module --
      ifdef WAKIF
                   ;----{ CAN bus Error }------------------------[PIR3, ERRIF]---
          INT_Source  CAN_ERR_INT, PIE3,ERRIE, IPR3,ERRIP
                   ;----{ Invalid Received Message }-------------[PIR3, IRXIF]---
          INT_Source  CAN_IRX_INT, PIE3,IRXIE, IPR3,IRXIP
                   ;----{ Receive Buffer 0 }------Mode 0--------[PIR3, RXB0IF]---
          INT_Source  CAN_RXB0_INT, PIE3,RXB0IE, IPR3,RXB0IP
                   ;----{ FIFO Watermark }--------Mode 1, 2---[PIR3, FIFOWMIF]---
          INT_Source  CAN_FIFOWM_INT, PIE3,FIFOWMIE, IPR3,FIFOWMIP
                   ;----{ Receive Buffer 1 }------Mode 0--------[PIR3, RXB1IF]---
          INT_Source  CAN_RXB1_INT, PIE3,RXB1IE, IPR3,RXB1IP
                   ;----{ Any Receive Buffer }----Mode 1, 2-----[PIR3, RXBnIF]---
          INT_Source  CAN_RXBn_INT, PIE3,RXBnIE, IPR3,RXBnIP
                   ;----{ Transmit Buffer 0 }-------------------[PIR3, TXB0IF]---
          INT_Source  CAN_TXB0_INT, PIE3,TXB0IE, IPR3,TXB0IP
                   ;----{ Transmit Buffer 1 }-------------------[PIR3, TXB1IF]---
          INT_Source  CAN_TXB1_INT, PIE3,TXB1IE, IPR3,TXB1IP
                   ;----{ Transmit Buffer 2 }-----Mode 0=-------[PIR3, TXB2IF]---
          INT_Source  CAN_TXB2_INT, PIE3,TXB2IE, IPR3,TXB2IP
                   ;----{ Any Transmit Buffer }---Mode 1, 2-----[PIR3, TXBnIF]---
          INT_Source  CAN_TXBn_INT, PIE3,TXBnIE, IPR3,TXBnIP
                   ;----{ CAN bus Activity Wake-up }-------------[PIR3, WAKIF]---
          INT_Source  CAN_WAKE_INT, PIE3,WAKIE, IPR3,WAKIP
      list
      list
    ;____[ if not using Low Priority INTS, create a dummy handler ]_______________
        ifndef  USE_LOWPRIORITY
    INT_ENTRY_L
            retfie
            if (USE_LOWPRIORITY != 1)
    INT_ENTRY_L
                retfie
    ;_____________________________________________________________________________
    Asm
    asm = 0    ; Assembly language Interrupts
    ASM = 0
    Asm = 0
    pbp = 1    ; Basic language interrupts
    PBP = 1
    Pbp = 1
    YES = 1
    yes = 1
    Yes = 1
    NO = 0
    no = 0
    No = 0
    H equ 'H'  ; High Priority
    h equ 'H'
    L equ 'L'  ; Low Priority
    l equ 'L'
      nolist
    SaveFSR  macro  F, Pr
      list
        if (F >= 0) && (F <= 2)
            if (Pr == H) || (Pr == L)
                movff    FSR#v(F)L, fsave#v(F)Pr
                movff    FSR#v(F)H, fsave#v(F)Pr + 1
              nolist
                ERROR "SaveFSR - Invalid Priority"
            ERROR "SaveFSR - Invalid FSR number"
        list
    Asm
    RestFSR  macro  F, Pr
      list
                movff    fsave#v(F)Pr , FSR#v(F)L
                movff    fsave#v(F)Pr + 1 , FSR#v(F)H
              nolist
                ERROR "RestFSR - Invalid Priority"
            ERROR "RestFSR - Invalid FSR number"
        list
    ;---[Stay compatible with the 14-bit version]---------------------------------
    Asm
    INT_FINISH_H   macro
    EndAsm
    ;---[Create the High Priority Interrupt Processor]----------------------------
    INT_CREATE_H  macro
      local OverCREATE
        goto OverCREATE
    Priority = H
    INT_ENTRY_H
        movff   PCLATU, psaveUH
        movff   PCLATH, psaveH
        SaveFSR  0, H
        SaveFSR  1, H
        SaveFSR  2, H
        bsf      _InHPint, 0
    List_Start_H
        bcf      _Serviced_H, 0         ; Clear Serviced flag
        clrf  BSR
    PREV_BANK = 0
        ifdef INT_LIST_H
            INT_LIST_H                  ; Expand the users list of HP INT handlers
            ifdef INT_LIST
                INT_LIST                ; Expand the 16F Compatible List
                error "INT_CREATE_H - INT_LIST or INT_LIST_H not found"
        btfsc    _Serviced_H,0          ; if anything was serviced
        goto     List_Start_H           ; go around, and check again
        ifdef ReEnterHPused             ; was ReEnterPBP-18.bas included
            GetAddress21  INT_EXIT_H, RetAddrH
            L?GOTO   _RestorePBP_H      ; Restore PBP system Vars
    INT_EXIT_H
    PREV_BANK = 0
        bcf      _InHPint, 0
        RestFSR  0, H                   ; Restore FSR0, if it was saved?
        RestFSR  1, H                   ; Restore FSR1, if it was saved?
        RestFSR  2, H                   ; Restore FSR2, if it was saved?
        movff    psaveH, PCLATH
        movff    psaveUH, PCLATU
        retfie    FAST                  ; Return from Interrupt
    OverCREATE
        bsf   INTCON,GIE, 0             ; Enable High Priority Interrupts
        bsf   INTCON,PEIE, 0            ; Enable Peripheral Interrupts
    INT_CREATE  macro
        INT_CREATE_H
    ;---[Create the Low Priority Interrupt Processor]-----------------------------
    INT_CREATE_L  macro
      local OverCREATE
        goto OverCREATE
        ifdef USE_LOWPRIORITY
           error "'DEFINE USE_LOWPRIORITY 1' required for Low Priority Interrupts"
    Priority = L
    INT_ENTRY_L
        movff   WREG, wsave             ; Wreg
        movff   STATUS, ssave           ; STATUS
        movff   BSR, bsave              ; BSR
        movff   PCLATU, psaveUL
        movff   PCLATH, psaveL
        SaveFSR  0, L                   ; FSR0
        SaveFSR  1, L                   ; FSR1
        SaveFSR  2, L                   ; FSR2
        bcf      _InHPint, 0
    List_Start_L
      clrf  BSR
    PREV_BANK = 0
        bcf      _Serviced_L, 0
        ifdef INT_LIST_L
            INT_LIST_L                  ; Expand the users list of HP INT handlers
            error "INT_CREATE_L - INT_LIST_L not defined, can not create"
        btfsc    _Serviced_L, 0         ; if anything was serviced
        goto     List_Start_L           ; go around, and check again
        ifdef ReEnterLPused             ; was ReEnterPBP-18LP.bas included
            GetAddress21  INT_EXIT_L, RetAddrL
            L?GOTO   _RestorePBP_L      ; Restore PBP system Vars
    INT_EXIT_L
    PREV_BANK = 0
        RestFSR  0, L                   ; Restore saved vars
        RestFSR  1, L
        RestFSR  2, L
        movff   psaveUL, PCLATU
        movff   psaveL, PCLATH
        movff   bsave, BSR              ; BSR
        movff   wsave, WREG             ; WREG
        movff   ssave, STATUS           ; STATUS
        retfie                          ; Return from Interrupt
    OverCREATE
        bsf   RCON,IPEN, 0              ; Enable Interrupt Priorities
        bsf   INTCON,GIEL, 0            ; Enable Low Priority Interrupts
    ;---[Returns the Address of a Label as a Word]--(under 64K)------------------
    GetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
        movlw High Label         ; get high byte
        movwf Wout + 1
    ;---[Returns the Address of a Label as a 3 byte array]---(under/over 64k)-----
    GetAddress21 macro Label, Aout
        CHK?RP Aout
        movwf Aout
        movlw high Label         ; get high byte
        movwf Aout + 1
        movlw upper Label        ; get upper byte
        movwf Aout + 2
    ;---[find correct bank for a PBP BIT variable]-------------------------------
    CHKRP?T  macro reg, bit
            CHK?RP  reg
    ;---[find Assigned Priority for specified INT Source]------------------------
    INT_Count = 0
    FindIntPriority  macro IntFlagReg, IntFlagBit
      local LoopCount
        nolist
    Pfound = 0
    LoopCount = 1
          while LoopCount <= INT_Count
              if  (IntFlagReg == PrList#v(LoopCount)R)
                 if (IntFlagBit == PrList#v(LoopCount)B)
      list
    Priority =  PrList#v(LoopCount)Priority
    Pfound = 1
    LoopCount += 1
          endw
    ;---[Add an Interrupt Source to the user's list of INT Handlers]--------------
    INT_Handler  macro  IntFlagReg, IntFlagBit, Label, Type, Reset
      list
        local AfterSave, AfterUser, NoInt
    INT_Count += 1
    PrList#v(INT_Count)R = IntFlagReg
    PrList#v(INT_Count)B = IntFlagBit
    PrList#v(INT_Count)Priority = Priority
            GetIntInfo   IntFlagReg, IntFlagBit
            if (Found == YES)
                btfss    INT_Enable_Reg, INT_Enable_Bit, 0  ; if INT is enabled
                goto   NoInt
                btfss    INT_Flag_Reg, INT_Flag_Bit, 0      ; and the Flag set?
                goto     NoInt
                if (Priority == H)
                    bsf      _Serviced_H, 0
                    bsf      _Serviced_L, 0
                ifdef NO_CLRWDT
                    if  (NO_CLRWDT != 1)
                        CLRWDT
                    CLRWDT
                if (Type == PBP)                         ; If INT handler is PBP
                  if (Priority == H)
                    ifdef ReEnterHPused
                        GetAddress21  AfterSave, RetAddrH
                        L?GOTO  _SavePBP_H        ; Save PBP system Vars in HP INT
        error "ReEnterPBP-18 must be INCLUDEd to use High Priority PBP interrupts"
                  else ; Priority = L
                    ifdef ReEnterLPused
                        GetAddress21  AfterSave, RetAddrL
                        L?GOTO  _SavePBP_L        ; Save PBP system Vars in LP INT
       error "ReEnterPBP-18LP must be INCLUDEd to use Low Priority PBP interrupts"
    AfterSave
    PREV_BANK = 0
                if (Priority == H)
                      GetAddress21  AfterUser, RetAddrH
                else ; Priority = L
                      GetAddress21  AfterUser, RetAddrL
                L?GOTO   Label                        ; goto the users INT handler
    AfterUser
    PREV_BANK = 0
                if (Reset == YES)                      ; reset flag (if specified)
                    bcf      INT_Flag_Reg, INT_Flag_Bit, 0
                error Interrupt Source (IntFlagReg,IntFlagBit) not found
    NoInt
        clrf  BSR
    PREV_BANK = 0
    asm
    ;---[Returns from a "goto" subroutine]--(21-bit RetAddr? must be set first)---
    INT_RETURN  macro
      local Ret2LP, Ret2HP
          btfsc   _InHPint, 0
          goto    Ret2HP
    Ret2LP
          movff   RetAddrL + 2, PCLATU  ; Load PC buffers with return address
          movff   RetAddrL + 1, PCLATH
          movf    RetAddrL, W, 0
        clrf  BSR                    ; Set to BANK0 before returning
    PREV_BANK = 0                    ; Tell PBP about the BANK change
          movwf   PCL, 0             ; Go back to where we were
    Ret2HP
          movff   RetAddrH + 2, PCLATU ; Load PC buffers with return address
          movff   RetAddrH + 1, PCLATH
          movf    RetAddrH, W, 0
    ;---[Enable an interrupt source]----------------------------------------------
    INT_ENABLE  macro  IntFlagReg, IntFlagBit
          if (Found == YES)
              FindIntPriority  IntFlagReg, IntFlagBit
              if (Pfound == 1)
                  if (INT_Priority_Reg != -1)
                      if (Priority == H)
                          bsf  INT_Priority_Reg, INT_Priority_Bit, 0
                          if (Priority == L)
                              bcf  INT_Priority_Reg, INT_Priority_Bit, 0
                              error "INT_ENABLE - Invalid Priority Specified"
                      if (Priority == L)
                          error "INT0_INT can NOT be assigned to Low Priority"
                  error "INT_ENABLE - Priority State Not Found"
    ;          bcf     INT_Flag_Reg, INT_Flag_Bit, 0        ; clear the flag first
              bsf     INT_Enable_Reg, INT_Enable_Bit, 0    ; enable the INT source
              error  "INT_ENABLE - Interrupt Source not found!"
    ;---[Disable an interrupt source]---------------------------------------------
    INT_DISABLE  macro  IntFlagReg, IntFlagBit
          if (Found == YES)
              bcf     INT_Enable_Reg, INT_Enable_Bit, 0   ; disable the INT source
              error "INT_DISABLE - Interrupt Source not found!"
    ;---[Clear an interrupt Flag]-------------------------------------------------
    INT_CLEAR  macro  IntFlagReg, IntFlagBit
          if (Found == YES)
              bcf     INT_Flag_Reg, INT_Flag_Bit, 0       ; clear the INT flag
              error "INT_CLEAR -  Interrupt Source not found!"
    ; ---[See if we need to save TBLPTR]------------------------------------------
    Save_TBLPTR = 0
        ifdef SIN_USED
    Save_TBLPTR = 1
        ifdef DTMFOUT_USED
    Save_TBLPTR = 1
        ifdef SERDELAY_USED
    Save_TBLPTR = 1
        ifdef CONVBIT_USED
    Save_TBLPTR = 1
        ifdef ERASECODE_USED
    Save_TBLPTR = 1
        ifdef READCODE_USED
    Save_TBLPTR = 1
        ifdef WRITECODE_USED
    Save_TBLPTR = 1
        ifdef LOOKDOWN?BCLB
    Save_TBLPTR = 1
        ifdef LOOKDOWN?BCLT
    Save_TBLPTR = 1
        ifdef LOOKDOWN?BCLW
    Save_TBLPTR = 1
        ifdef LOOKDOWN?CCLB
    Save_TBLPTR = 1
        ifdef LOOKDOWN?CCLT
    Save_TBLPTR = 1
        ifdef LOOKDOWN?CCLW
    Save_TBLPTR = 1
        ifdef LOOKDOWN?WCLB
    Save_TBLPTR = 1
        ifdef LOOKDOWN?WCLT
    Save_TBLPTR = 1
        ifdef LOOKDOWN?WCLW
    Save_TBLPTR = 1
        ifdef LOOK2_USED
    Save_TBLPTR = 1
        ifdef LOOKUP?BCLB
    Save_TBLPTR = 1
        ifdef LOOKUP?BCLT
    Save_TBLPTR = 1
        ifdef LOOKUP?BCLW
    Save_TBLPTR = 1
        ifdef LOOKUP?CCLB
    Save_TBLPTR = 1
        ifdef LOOKUP?CCLT
    Save_TBLPTR = 1
        ifdef LOOKUP?CCLW
    Save_TBLPTR = 1
        ifdef LOOKUP?TCLB
    Save_TBLPTR = 1
        ifdef LOOKUP?TCLT
    Save_TBLPTR = 1
        ifdef LOOKUP?TCLW
    Save_TBLPTR = 1
        ifdef LOOKUP?WCLB
    Save_TBLPTR = 1
        ifdef LOOKUP?WCLT
    Save_TBLPTR = 1
        ifdef LOOKUP?WCLW
    Save_TBLPTR = 1
    endasm
    OVER_DT_INTS_18:
    ENABLE DEBUG
    Nov 2007
    West Covina, CA
    You are on the right track. Darrel did add this interrupt:
    Setup as:
    INCLUDE "DT_INTS-18.bas"     ; Darrel Taylor's Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"  ; Include if using PBP interrupts
    INT_LIST  macro ; IntSource,         Label,  Type, ResetFlag?
        INT_Handler   RTTCC_INT,      _Relogio,   PBP,  yes
        INT_CREATE             ; Creates the interrupt processor
    @   INT_ENABLE  RTTCC_INT         ; Enable RTCC interrupt
    The RTCC interrupt flag is PIR3.0 found in Register 9-6 of the data sheet.
    Louie
    Nov 2007
    West Covina, CA
    I happen to also be working with the PIC18F24J50 for the RTCC and just tried DT's Interrupts for it and got an error. It may have already been addressed in this thread that has become short of a book but here it is:
    Symbol not previously defined (RTTCIP)
    Found a typo here:
    asm
    endasm
    Data sheet Register 9-12 shows IPR3.0 labeled as RTCCIP, so I changed it to the following and error message gone.
    asm
          INT_Source  PIR3,RTCCIF, PIE3,RTCCIE, IPR3, RTCCIP
    endasm
    By the way, many thanks to Darrel for this extremely fine piece of work that looks like it took a lot of time and doing then to just give it to everyone.
    Louie
    Jun 2015
    Where can I download the latest DT-Ints-18 AND ReEnterPBP-18? PIC18F67K90, PBP3 - Thanks - DarrelTaylor.com is all links, no beef.
    As in chat box,
    http://www.picbasic.co.uk/forum/showthread.php?t=19638
    Under 18 bit link.
    Then DOWNLOAD link at very top.
    Links are there.
    Jun 2015
    Thanks - just what I needed! Now the fun starts...
    Jun 2015
    Thanks a lot, Robert. I have installed them and they do exactly what I needed. Thanks Darrel...
    Now I have a question. I added the RTCC interrupt to the DT-INTS-18 coding by adding a define and the "ifdef" statement (using an 18F67K90). I noticed that after I return from my RTCC_INT handler, the RTCCIF flag bit is cleared, apparently by the INT_RETURN macro. Did I leave out more changes to the DT-INTS-18 code, or are all interrupt flags cleared by INT_RETURN? My work around was to create a copy of RTCCIF and poll it instead.
    Clock_Int: 'RTCC ISR
    RTCC_IF = 1 'set the interrupt flag copy because macro INT_RETURN clears RTCCIF
    @ INT_RETURN
    Howard
    As in chat box,
    Under 18 bit link.
    Links are there.
    Howard, you must be setting the reset flag to TRUE by entering YES in the interrupt declaration ResetFlag field like this:
    INT_LIST macro ;IntSource Label Type ResetFlag
    INT_Handler IC3DRIF_INT, _InputSignal, ASM, yes
    INT_CREATE
    EN82fn
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
Members who have read this thread : 4
